Old 02-12-2019, 02:57 PM #1
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
What PM can be done while the transmission is removed?
Rear main seal, flex plate, anything else?
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 02-12-2019, 03:04 PM #2
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Great time to change steering parts or put a fresh coat of paint on the frame.
Old 02-12-2019, 04:57 PM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Flex plates don't go bad that much, but I guess you can if you want.
Rear engine mount (transmission mount) is easy to do with it out and will help the shifts be a bit smoother with less vibration. Changing all your differential fluids or addressing any leaks will be much easier as well.
326WHP 347TQ
Old 02-12-2019, 05:05 PM #4
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
Call me crazy but since you've removed the transmission I'd pull the timing belt, water pump, oil pump and oil pan. I get that it is quite a bit of extra work but the configuration of how the oil pump, pan and rear main all bolt together is less than ideal unless the paper/felt gaskets don't actually do anything.
APhelps is offline   Reply With QuoteReply With Quote
Old 02-12-2019, 09:24 PM #5
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
huh? Not trying to be mean but those two jobs have nothing to do with each other. Pulling the transmission will not make the timing belt any easier.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 02-12-2019, 10:47 PM #6
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
If it has not been done...STARTER CONTACTS!!!!!!!!!!
My Backyard Frame Swap
Old 02-12-2019, 10:52 PM #7
calimobber's Avatar
calimobber's Avatar
thats a good one. The starter is a freaking pain to remove.
Old 02-12-2019, 11:38 PM #8
I could be mistaken but there is a gasket under the rear main seal cover. Perhaps its just a dust cover and isn't necessary to be pulled off then. If that is the case you are correct.
Old 02-13-2019, 01:20 AM #9
vipergrhd's Avatar
vipergrhd vipergrhd is offline
vipergrhd is on a distinguished road
vipergrhd's Avatar
Really?
What caused you to take so long? I did mine in my drive way in 35 min. that is in and out of the vehicle. Did you remove the dipstick tube?
vipergrhd is offline   Reply With QuoteReply With Quote
Old 02-13-2019, 02:22 AM #10
calimobber's Avatar
calimobber's Avatar
Its been maybe 6 years since i did mine but I remember it was just a tight fit and took a lot of manipulating to get the alternator out.
Annoying thing it I replaced it because it was making a crazy noise when I started the car. Turned out it was just the dust seal on the shaft was dislodged and was being pushed out and hit the spinning gears when starting. At the time I just replaced with auto zone special since I already had it out. I should have just fixed it and reinstalled the oem. Oh well auto zone special still working fine today.
Old 02-13-2019, 12:23 PM #11
TheDurk's Avatar
TheDurk's Avatar
Well, then you hold the land speed record. Most people with auto trans find it a nightmare. I did mine as PM during a clutch job, so it was a piece of cake.
Old 02-13-2019, 12:45 PM #12
nissanh nissanh is offline
I did my starter contacts and it took me about 2 hours to get all done. Taking the tire off and putting on jack stands will take about 5 minutes. You need to properly set the contacts inside the solenoid and with that tight spot, it took more time than doing it with starter out.
OP, make sure to use OEM rear seal. NEVER use aftermarket seals for any part of the truck.
You could also replace the shift lever bushings with OEM parts. What about the transfer case F and R oil seals?
Old 02-13-2019, 02:09 PM #13
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
35 minutes???
It took me 35 minutes just to figure out how to get the right amount of swivels and extensions on that top starter bolt.
Granted, now that I know how to do it I could probably get the starter off and out in under an hour but 35 minutes start to finish? Come on.....
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 02-13-2019, 02:09 PM #14
Real Name: Jerod
Real Name: Jerod
There's two different kinds of starters. Most autos have the larger kind which cannot be removed from that tight spot without removing part of the frame.
Manuals and some lucky dudes with autos have the smaller kind that slips right out and can be rebuild very easily. I'm guessing you are one of those lucky few.
326WHP 347TQ
Old 02-13-2019, 02:12 PM #15
thegipper's Avatar
thegipper's Avatar
If I remember correctly when I did my rear main, there is not a gasket just a bead of RTV/FIPG.
I don't think it holds any oil back so it is essentially a dust cover. I believe I just left it alone and bolted it back up.
I did clean up the portion of the oil pan that gets exposed when you pull the rear main seal "cover" off.
Don't forget that two of the oil pan bolts hold that cover on. I pried the hell out of that cover until I realized two of the oil pan bolts hold it in place (in addition to the other botls).
It's probably the reason why I have a small leak in that area now....
2011 Camry SE V6
flex , main , plate , removed , seal
HCF removed 810moto 4th Gen T4Rs 13 12-08-2020 04:59 PM
Removed Crossbars, removed caps too! rktroutbum 5th gen T4Rs 12 11-11-2015 07:24 AM
Has anyone removed 3rd row seats? 03_4x4Runner 5th gen T4Rs 2 06-08-2014 11:41 AM
Sorry you removed X-REAS? marlin driver 5th gen T4Rs 40 07-28-2013 03:17 PM
ABS removed? rolling blackout Classic T4Rs 8 02-06-2012 05:05 PM
