Originally Posted by phattyduck
You'd have to swap the wiring harness from the '99 on to the '02 motor, among other small things.
This.
You will definitely need to swap the engine harness over. I had to do this when swapping a 99 motor into my 97. All of the connectors are the same on the engine side but are completely different on the ECU side. You'll have to pull the upper/lower plenum off to get the some of the connectors off.
I thought it was going to be a real PITA but it wasn't bad at all. Took me maybe an hour since both engines were on stands in my garage.
