Old 02-15-2019, 06:41 PM #1
gebomartin gebomartin is offline
gebomartin is on a distinguished road
Changing how my door Locks work
When I get out of my 4Runner, the only door that unlocks in the driver's side.
The other doors 3 stay locked.
Is there a way to set my locks so that when I stop my car and put it in park that all 4 doors will unlock?
2002 4Runner SR5 265K
gebomartin is offline   Reply With QuoteReply With Quote
Old 02-15-2019, 06:45 PM #2
ToyotaBrah's Avatar
ToyotaBrah ToyotaBrah is offline
ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about
ToyotaBrah's Avatar
So when you take the key out of the ignition, the driver side door unlocks automatically? Mine doesn't do this and my locks were just fine. I wonder if this was a feature specific to 2002.
ToyotaBrah is offline   Reply With QuoteReply With Quote
Old 02-15-2019, 06:47 PM #3
When I put it in "Park".
Old 02-16-2019, 02:26 AM #4
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
I have a 2002 and mine doesn't do that........... Interesting.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 02-16-2019, 11:59 AM #5
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Do you have a remote starter or alarm?
If so, those items can control door lock functions.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 02-16-2019, 01:17 PM #6
stuckinthemud stuckinthemud is offline
stuckinthemud will become famous soon enough
All 5 of my doors lock when I put the key in the start position, and unlock when I turn the key off. I do have the factory remote key system with an after market key fob remote.
97 SR5 4x4 3.4 automatic
stuckinthemud is offline   Reply With QuoteReply With Quote
Old 02-17-2019, 01:04 PM #7
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
This has worked for my 2000 SR5. Here's another thread: Turn off door lock feature
Automatic Door Locking / Unlocking Function:
The factory setting for the automatic door locking and unlocking function is on.
1: Sit in the drivers seat with the drivers door open.
2: Insert the key into the ignition switch and turn it to on (not acc) 5 times (on-lock, on-lock, on-lock, on-lock, on) within a 10 second period. The status monitors LED turns on, and the piezo chirper sounds once.
***You must perform the next steps within 30 seconds***
Select the operating mode:
Automatic door locking and unlocking on: Close the drivers door. Turn the ignition switch to the lock position. The piezo chirper sounds once, and the exterior lights flash once.
Automatic door locking and unlocking off: Close the drivers door once, then open and close it one more time. Turn the ignition switch to the lock position. The piezo chirper sounds twice, and the exterior lights flash twice.
If you do not turn the ignition key to lock, or exceed 30 seconds during the programming steps, the status monitor's LED will turn off and the previous operation mode will remain.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 05-03-2019, 12:10 PM #8
GoreD GoreD is offline
GoreD is on a distinguished road
I’ve tried this about a dozen times on my 2001 sr5 and it never chirps to enter the programming mode. Could 2001 be different?
2001 4Runner SR5 4X4
GoreD is offline   Reply With QuoteReply With Quote
Old 05-03-2019, 03:44 PM #9
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
From inside, and while the lock button is pressed down or in the "lock" position, can the driver's and front passenger doors be opened while pulling on their respective lever?
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 05-03-2019, 06:11 PM #10
NO, I tried it and realized you need to actually unlock the door (both driver and passenger) before you can open it from the inside.
A bit scary, it feels like your stuck inside.
Old 05-03-2019, 07:07 PM #11
wemslie97's Avatar
wemslie97 wemslie97 is offline
Real Name: Bill
wemslie97 is on a distinguished road
wemslie97's Avatar
Real Name: Bill
It could also be that you're piezo chirper is set to "off" or not working at all.
'97 T4R LTD 4WD desert dune, bone stock, factory E-locker, RS3000, Scangauge II, Hella 450's, 191k
wemslie97 is offline   Reply With QuoteReply With Quote
Old 05-03-2019, 07:12 PM #12
It chirps when I lock and unlock with the fob.
The red security light comes on after 5 key turns so I thought the chirp might just not be working but the lights don't flash and it won't allow me to change the programming by closing and opening the door twice either.
It's almost like it's only half entering the programming mode ...
Old 05-03-2019, 10:51 PM #13
wemslie97's Avatar
Real Name: Bill
wemslie97's Avatar
Real Name: Bill
Have you tried a full reset?
Old 05-04-2019, 01:27 AM #14
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
What I really want is for all of my doors to unlock on the first pretty of the unlock button on the remote. I have all of my other cars set up this way and it always annoys me when I go to the back door or hatch and it's still locked after I hit unlock. Anyone know of a way to get one click unlocking on these cars?
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 05-04-2019, 10:06 AM #15
The only thing that comes to mind is whether or not the system knows when the door is opened. The switch that actuates the dome light also signals the system for other things, such as turning off headlights and as a trigger for security programming. Be sure that this switch is working 100% before suspecting anything else.
Just yesterday I discharged my battery when my headlights didn't turn off because of this switch.
_________
door , doors , locks , set , stop
Power locks don't work without ignition on saurkraut 3rd gen T4Rs 3 02-27-2016 11:44 AM
question about hitch locks and trailer door locks wadeanderson 4th Gen T4Rs 2 11-11-2014 11:55 PM
2001 T4R door locks dont work--help NorcalChris 3rd gen T4Rs 2 05-21-2011 11:20 AM
Door Locks rnjoe1 4th Gen T4Rs 15 08-19-2009 03:22 PM
Power locks dont work 98 sr5 hvguy 3rd gen T4Rs 1 01-29-2008 03:51 PM
