Originally Posted by jeredcollins
Gents pulled the trigger finally after 15 months of deliberating went with this lift. Wheelers Offroad has phenomenal customer service as well.
Front:
Tundra TRD Progressive Coils (2" lift)
Tundra 5100 Bilsteins
10mm Trim (.5" lift)
Rear:
OME 890 springs (3" lift)
I'm trying for around 2.5" up front and 3" in the rear for a slight rake. Does anyone have anyone ran this exact setup before? Are my numbers correct?
Last but not least I have the OEM trail rims and would like to run a 285/70R17. Will I need to get wheel spacers to run this setup?
I've been running this setup for years. My measurements are in a previous thread I started over 3 years ago. 3" in the back at least 2.5 in the front. No trim packers. The rake doesn't bother me. Really don't notice it. When you get some passengers in the back it levels out instead of sagging so that's a plus.
I'm running 275 70 17s and I don't rub. I tried spacers and did rub. Spacers make it worse. I finally got SCS Ray 10s which about perfectly balanced the backspacing to eliminate rubbing. Can't comment on rubbing with OEM UCAs with that size tire. I would think you would rub. A well setup alignment with LR UCAs and proper rim backspacing all help.
