Old 10-06-2023, 09:30 AM #16
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by chilipeppermaniac View Post
I have a 2017 4 Runner Limited.
The car has basically only been driven every so often in the yard in the past 4 years. I have 32k on it and just got the title and began to drive it. All the switches work except the Main switch for the front Passenger window.
3 of the 4 main ones work, plus each switch on the corresponding doors. I tried the 5 minute, 5 second reset, but either did something wrong or it is something else. I will try again tomorrow.
Has anyone ever just had 1 switch that actually was a bad switch and can just the one be replaced?
Unfortunately, this is the 3rd gen section. So the information only pertains to 3rd gens 1996 to 2002. Might have in the 5th gen section...
Old 10-11-2023, 09:10 PM #17
chilipeppermaniac chilipeppermaniac is offline
chilipeppermaniac is on a distinguished road
Thanks Brillo.
I actually did find another place where some folks posted a solution. I am pretty sure it must be in a 5th gen place because the fix worked.
This one was to Use the switch on the actual door and put the window down, then hold the switch down for 10 seconds. At this point, the driver's switch for this door began to work again.
chilipeppermaniac is offline   Reply With QuoteReply With Quote
Old 02-13-2024, 01:16 PM #18
Tigersquid Tigersquid is offline
Tigersquid is on a distinguished road
Originally Posted by shadow247 View Post
Try this.
First disconnect the battery, let it sit for 5 minutes, and reconnect.
Now turn on the ignition, but do not start the engine.
Push down on the passenger window MAIN SWITCH only for 5 seconds.
Pull up on the Passenger window Main Switch only for 5 seconds.
This should reset the switch module. I had to do it on mine after I left the dome light on for a few weeks and drained the battery.
Looking through older posts and came across this. Will this work for a 2005 4runner also? The windows will work intermittently from their respective window controls. However they all work without issue from te drivers panel. For example most of the time my passengers will be able to roll down their window but I will have to roll it up for them. Or sometimes it will be in reverse where I will have to roll it up for them.
Tigersquid is offline   Reply With QuoteReply With Quote
driver , passenger , switch , window , work
One window switch not working- 5th gen BZ_T4R Problems & Warranty Issues 1 10-31-2020 09:25 PM
Passenger power window not working right abw73 3rd gen T4Rs 2 06-10-2018 04:58 PM
Passenger window not working? Revosickness 3rd gen T4Rs 0 11-15-2011 10:01 AM
1992 passenger window stopped working duner Problems & Warranty Issues 1 07-06-2005 02:00 PM
Gen4 Passenger Power Window Switch Mod? Mike552 4th Gen T4Rs 17 08-24-2004 06:34 PM
