Also, a lot of companies are offering these larger bead wheels that grip the tires better without needing a bead lock ring.
https://cdn.shopify.com/s/files/1/01...g?v=1546443365 https://cdn.shopify.com/s/files/1/01...g?v=1546443365 |
https://cdn.shopify.com/s/files/1/01...g?v=1534870045 https://cdn.shopify.com/s/files/1/01...g?v=1546443369 https://cdn.shopify.com/s/files/1/01...g?v=1546443369 The only model currently offered in a 16" is the MR701, comes in bronze or black https://cdn.shopify.com/s/files/1/01...g?v=1546443369 https://cdn.shopify.com/s/files/1/01...g?v=1546443365 $780 for a set of 4, delivered |
4.5BS, 0 Offset :biggrin2:
That's a shame, I need 3.5 BS. |
I have yet to pop a bead on my stock rims. running 285/70r16 (32x11.5 r 16) nitto trail grapplers (mud terrain) |
I normally air down to 5ish on stock wheels. Haven't lost a bead yet (but won't be surprised when I do). I've burped a bead a couple times at speed (driving way too fast for that pressure) but nothing major.
not sure they will clear things however with the wider bead. looks like the 16x8 with 0 offset have a 1/2" wider bead than normal wheels so... most tire calc stuff uses standard beads width and so these really need to be figured as 16x9 with 0 offset giving them a 4.5 backspace. that is not going to clear the UCA at full droop, unless special custom wheel spacers were used. bummer. because I would totally be on board with these. |
I was thinking about all of this last night; using that calculator, wouldn't it be more useful to consider offset than BS? The important clearance is the tire (for truck purposes tire is much wider than the wheel, after all) and the wheel offset is what determines the centerline of the tire relative to the hub face, fender, suspension, etc...
Wheel bead wall thickness and its implications for BS doesn't affect the tire clearance.. particularly when comparing a theoretical tire/wheel setup with a known one? |
Damn, beadlocks I want are still $500 each, guess I'll be sticking to what I'm running till lottery pays.
@sleepydad You may also want to consider DOT compliant beadlocks, like Hutchinson’s Rock Monster Wheels - they are pretty badass! |
These were designed specifically for Toyota platforms and have been mounted to FJ, Tacoma, Land Cruiser, 4Runners, etc without issue. I wouldnt take those liberties with the math, figure them as what they are, 16x8 0 Offset, 4.5BS. We have 27 sets with not one of our customers having a fit problem. Check Method's gallery for more images. |
If you are trying to compare clearance to UCA or the frame, backspace is what you want to look at to compare apples to apples between wheels. Offset will change with different wheel widths so you end up having to calculate backspace in order to figure out distance from WMS to back side of wheel. |
Search Engine Optimisation provided by
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
Advanced User Tagging (Lite) -
