02-22-2019, 05:03 PM
#16
Also, a lot of companies are offering these larger bead wheels that grip the tires better without needing a bead lock ring.
02-22-2019, 06:35 PM
#17
Real Name: Mark
Real Name: Mark
Originally Posted by Battle Born Offroad
We can do those KMCs for $260 a pop, delivered...
Damn had know idea price had dropped to that. Thanks for throwing that out there.
02-22-2019, 09:23 PM
#18
Do you guys carry these? Anything in 16x8?
'99 Millenium Silver SR5 | 5.29 Nitrogears/ARB lockers | 35s | Supercharged
Build Thread
02-22-2019, 09:30 PM
#19
We do!
The only model currently offered in a 16" is the MR701, comes in bronze or black
$780 for a set of 4, delivered
02-22-2019, 09:35 PM
#20
We do!
What's the backspacing and offset on these?
Build Thread
02-22-2019, 10:18 PM
#21
4.5BS, 0 Offset
02-23-2019, 01:34 AM
#22
4.5BS, 0 Offset
That's a shame, I need 3.5 BS.
Build Thread
02-23-2019, 02:09 AM
#23
Originally Posted by Black798
1 33s hold beads really well, I routinely ran my 33s down to 8psi and never had a problem without beadlocks. They aren't that much bigger than stock tires and on a decent rimthey hold just fine
ABSOLUTELY!!! people need to know a 16 inch rim can REALLY hold a stiff walled tire, I too routinely air down to 10 on rocks/dirt and 6 in snow...
I have yet to pop a bead on my stock rims.
running 285/70r16 (32x11.5 r 16) nitto trail grapplers (mud terrain)
1999 3rd gen Ltd 4wd 3.4 auto dif lock - Build Thread SOLD!
2019 Tundra Sr5 CrewMax - 1 owner
Doubt kills more dreams than failure ever will.
02-23-2019, 02:58 AM
#24
I normally air down to 5ish on stock wheels. Haven't lost a bead yet (but won't be surprised when I do). I've burped a bead a couple times at speed (driving way too fast for that pressure) but nothing major.
97 4Runner - SR5 - 5spd - Factory E-locker - 285/75R16 Duratracs - Allpro Upper Control Arms - Allpro Coilovers - LC Coils - CBI Rear Bumper
02-23-2019, 10:17 AM
#25
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
4.5BS, 0 Offset
hmmm ok these are cool I did not know they existed. kind of the better of both worlds for those of use who do not need the best of one world by sacrificing the road world.
not sure they will clear things however with the wider bead.
looks like the 16x8 with 0 offset have a 1/2" wider bead than normal wheels so... most tire calc stuff uses standard beads width and so these really need to be figured as 16x9 with 0 offset giving them a 4.5 backspace.
that is not going to clear the UCA at full droop, unless special custom wheel spacers were used. bummer.
because I would totally be on board with these.
02-23-2019, 10:44 AM
#26
Official Vendor
Official Vendor
I was thinking about all of this last night; using that calculator, wouldn't it be more useful to consider offset than BS? The important clearance is the tire (for truck purposes tire is much wider than the wheel, after all) and the wheel offset is what determines the centerline of the tire relative to the hub face, fender, suspension, etc...
Wheel bead wall thickness and its implications for BS doesn't affect the tire clearance.. particularly when comparing a theoretical tire/wheel setup with a known one?
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
02-23-2019, 11:21 AM
#27
Real Name: Mark
Real Name: Mark
Damn, beadlocks I want are still $500 each, guess I'll be sticking to what I'm running till lottery pays.
02-23-2019, 12:18 PM
#28
This is EXACTLY why I argue that offset is the key factor in determining UCA clearance, not backspace. I’m sure someone will chime in soon telling me why I’m wrong...
@ sleepydad
You may also want to consider DOT compliant beadlocks, like Hutchinson’s Rock Monster Wheels - they are pretty badass!
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s ( thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
02-23-2019, 12:23 PM
#29
These were designed specifically for Toyota platforms and have been mounted to FJ, Tacoma, Land Cruiser, 4Runners, etc without issue. I wouldnt take those liberties with the math, figure them as what they are, 16x8 0 Offset, 4.5BS. We have 27 sets with not one of our customers having a fit problem. Check Method's gallery for more images.
02-23-2019, 12:37 PM
#30
Chime! Actually you can use either number...
If you are trying to compare clearance to UCA or the frame, backspace is what you want to look at to compare apples to apples between wheels. Offset will change with different wheel widths so you end up having to calculate backspace in order to figure out distance from WMS to back side of wheel.
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
