Old 02-22-2019, 09:38 AM #1
Myrunr2010's Avatar
Myrunr2010 Myrunr2010 is offline
Real Name: Dave
Myrunr2010 is on a distinguished road
Myrunr2010's Avatar
Real Name: Dave
Electrical Drain
So I’ve been fighting some sort of electrical drain on my truck for quite some time (and by fighting I mean jumping it if I don’t drive it regular enough and just dealing with it), but I recently started trying to figure out what’s wrong with it. As a start, I gutted all the extra electrical components I’ve added: front/rear fog lights, extra switch for rear window, extra 12v outlets. I had an issue with my rear hatch to where the sensor wouldn’t recognize the door as being shut, that’s been fixed.
Before removing all those, if I didn’t drive it every 2 days, the battery would be so dead on the 3rd day that the door locks wouldn’t even work the battery was so dead. Now, I let it sit for a weak, and it still had power, but not enough to turn the motor over. I’ve replaced the battery, and the starter/alternator have both been replaced at some point over the last year.
I hate electrical, and have hit all the obvious fixes, and I’m not real sure where to look now. Any suggestions or “smoking guns” I could look for?
97 4runner SR5 3.4 manual
Tundra/LC Lift with Bilstein 5100's on 285/70/17 BFG KO2
2" "Fat Pats" body lift; 1.25" All Pro wheel spacers
Turbo Build; Rear Bumper Build; Front Bumper Build
Myrunr2010 is offline   Reply With QuoteReply With Quote
Old 02-22-2019, 01:59 PM #2
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
I would start with the engine cold and see what kind of amp drain you have, if more than 30 mA give or take a few.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 02-22-2019, 02:09 PM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Take an multimeter ($10) and switch it to dc amps and disconnect the negative battery wire, then clamp the leads of the multimeter to the negative battery terminal and the ground wiring and switch it to DC amps. Measure the amp load, it should be only a few mA. Then, start pulling fuses one at a time and putting them back in until you find the culprit. Once you find the offending circuit and fuse, identify what fuse it is and hunt down your issue.
EDIT: Eric the Car Guy explains it better than I can:
How To Perform a Parasitic Draw Test - EricTheCarGuy - YouTube
326WHP 347TQ
Old 02-22-2019, 04:46 PM #4
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
Here's the best video I know of for tracking down a parasitic drain. If you have a drain you'll find it this way.
MStudt is offline   Reply With QuoteReply With Quote
Old 02-26-2019, 05:48 PM #5
Myrunr2010's Avatar
Real Name: Dave
Myrunr2010's Avatar
Real Name: Dave
We’ve had pretty nasty weather ever since I posted this, but I was able to get out and fool around with it today. I followed the advice in the YouTube clip and this is what I got.
When I initially connect the leads, I would get a small spark, not sure if that’s normal or not. When I initially connect it the amps would momentarily spike to bewteeen 0.15 and 0.26 amps (150-260 milliamperes according to google). Then it would drop to 0.06 for 3 seconds, and then drop to 0.02.
I followed his advice of popping fuses until the amps were normal. The “dome fuse 15A” under the hood seems to be the culprit. None of my dome lights are on (in fact I have them all set to off). I looked at the wiring diagram in the Haynes manual and couldn’t find anything that looked like it would be a smoking gun. I went ahead and pulled the fuse to see if in fact the battery drain stops. I noticed that my door locks no longer work, which I don’t see where the dome fuse is connected to the locks in the wiring diagram.
Maybe one of you is better at reading wiring diagrams than I am and could shed some light (no pun intended). Or could tell me if the spike followed by a drop, followed by another drop is normal?
Old 02-26-2019, 09:00 PM #6
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
I'm not 100% sure about a 97, but on a 99/2000 etc the dome light fuse is integral to the function of the door locks. It provides power to the circuit which tells the body ECU what doors are open or closed.
That said, the dome fuse isn't your problem. YES the spike and subsequent drop in amps is normal. And .02 amps won't kill your battery in a week.
You need to go back to basics, have your battery checked!
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 02-26-2019, 09:12 PM #7
+1 on having the battery tested. I have to ask when you added the fog lights, outlets, did you add them to the dome circuit? Fuse is good?
Old 02-26-2019, 10:03 PM #8
Myrunr2010's Avatar
Real Name: Dave
Myrunr2010's Avatar
Real Name: Dave
The battery is ~2 months old. Still think it’s worth having it tested?
Fog lights had their own circuit straight from the battery. I don’t remember what I grabbed from for the outlets, did those years ago. I think I pulled straight from the battery on them too though.
Old 02-26-2019, 10:46 PM #9
WWRD99's Avatar
WWRD99 WWRD99 is offline
Real Name: Rich
WWRD99 will become famous soon enough
WWRD99's Avatar
Real Name: Rich
Do you have a stock radio? I've had those wake up by themselves and the CD runs unit lights up...rarely, an alternator field coil will get juiced too....that was a tough one to find...the draw you're showing isn't enough to zap a battery in a couple days...so battery junk or something freakie.
Bought this 99 in 01 and haven't let it go since! Valve dropped at 195k so I rebuilt it with reman heads, new rings and one new piston...tough to find the correct numbered one but I did...still had the original hatch...I soaped it and did a light hatch to help the new rings seat...that was in 2015...since then I did a basic lift and put some VTX 18x9 inch wheels with 0 offset...Ive grounded the rear locker, ran a diff extension into the gas cap, did the hood piston mod...GM Alternator...13WL brakes..30 year ASE Master Tech with more tools than sense, so I quit everything and work at home now.
WWRD99 is offline   Reply With QuoteReply With Quote
Old 02-27-2019, 12:26 AM #10
The battery is probably good then.
Ok. Done any repair work lately? I am thinking it would be better to run the fogs and outlets off a fused circuit but if has worked well for you all these years, keep doing it unless a component (the fog light has water in it) is junk. But that would not explain why the 15amp dome circuit is making things screwy.
When did you tackle the rear window work?
Old 02-27-2019, 12:36 PM #11
nissanh nissanh is offline
The 2 months old battery is good for good brands and not for some autopart store batteries. Please check the battery. I see A-zone battery going bad on my cousin's pathfinder just in 6 months.
If your alternator is warm to touch even after engine sitting cold can imply it is draining battery. Is your alternator OEM or aftermarket?
Old 02-27-2019, 08:23 PM #12
Myrunr2010's Avatar
Real Name: Dave
Myrunr2010's Avatar
Real Name: Dave
Well, fog lights have been completely removed at this point, including all their wiring. They hadn’t been working for some time, and Va state inspection decided to ping me on it this year.
I “fixed” the rear hatch light a few weeks back, same time I gutted all my wiring. Since then it’s gone from ~3 days to drain to a week.
Old 02-27-2019, 08:24 PM #13
Myrunr2010's Avatar
Real Name: Dave
Myrunr2010's Avatar
Real Name: Dave
I’ll have to check the alternator next time I get a chance (the 4runners not my DD, the vstrom is). I did replace it ~6 months ago. It’s just a replacement alternator from autozone.
Old 02-27-2019, 10:52 PM #14
Keep an eye out on that alternator. You may be using that lifetime warranty sooner than later. What voltage output are you getting at the battery with the engine running?
I would still believe that something on the circuit is still open.
Old 02-28-2019, 08:45 PM #15
YES
What is your aversion to having the battery tested? Just curious.
Pointing the finger at parts that somebody's cousin in Manitowac once found to be their problem is just silly. 2 one hundredths of an amp will not drain your battery in a week.
My Landcruiser draws about twice that and it sits for a month easily.
battery , electrical , extra , i’ve , rear
Coolant drain and fill. Block drain plugs. lj4r 4th Gen T4Rs 2 11-24-2018 07:11 PM
Electrical issue / battery drain Levitan 3rd gen T4Rs 2 12-11-2016 07:04 PM
Weird electrical problem. Parasitic drain? jpeaslee 3rd gen T4Rs 6 02-16-2016 11:43 AM
Electrical short?? Random electrical issues? Fanman47 4th Gen T4Rs 5 06-09-2014 03:12 PM
Electrical Drain djmedik91 Problems & Warranty Issues 2 04-20-2009 05:55 PM
