Old 02-23-2019, 01:45 PM #1
HappyHooligan's Avatar
HappyHooligan HappyHooligan is offline
HappyHooligan is on a distinguished road
Sudden Squealing Belt Update . Need advice
so yesterday one of my belts just started squealing like crazy and would stop when I let off the gas but go back on when I applied the gas. So figures a loose belt. They feel pretty tight today, but the thing is now my brand new battery (1 month old) is completely dead. no door chimes or anything dead. Did my alternator go out and that was the squeal I heard? Or are they completely un related. if I left a light on (which I didn't see I did) I remember in past cars there was still some power but not enough to start the car. I'm completely dead. I have a charger on it now and I'm hearing the door chimes at least. Did my Alt go out or something else?
_________________
2000 Sport
2882/5100 906/5100
HappyHooligan is offline   Reply With QuoteReply With Quote
Old 02-23-2019, 02:17 PM #2
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
Get the battery charged and start the truck. Take a multi-meter and check voltage at the battery. I'd bet your alt is shot but it's easier to find out then throw parts at it.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 02-23-2019, 02:50 PM #3
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
After you get it started check to see if the alternator pulley is turning.
It may be the cause of the squealing.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 02-23-2019, 03:07 PM #4
HiLife HiLife is offline
How long did you drive with the dead battery? Sometimes dead batteries fry good alternators. Alternators are not meant to go full charging amps for too long trying to charge up a dead battery.
The dead alternator could co inside with the belt squealing. A locked up alternator bearing can make that noise.
Are the belts dry and not glazed? No oil, antifreeze or other contaminates on the belts?
Old 02-23-2019, 03:23 PM #5
The battery was brand new. It wasn't dead when I parked last night. Belts are good and clean. Once it's charged up I'll test it with the meter.
_________________
2000 Sport
2882/5100 906/5100
Old 02-23-2019, 03:37 PM #6
Hmm ok.
I had a good new battery die on me after replacing a 4 year old one. I'm my situation it turned out I didn't tighten my battery terminals enough. I put the battery on a charger to charge back up and reinstalled with clean and
tight terminals. That did the trick for me.
Old 02-23-2019, 08:25 PM #7
finally got it charged up. started it and the squeal was deafening. The alternator was not spinning so it's looking like I need a new alternator. And yes the sound was coming from it.
I guess it just locked up? So which brand replacement should I get? Toyota stock or another one? How much time does it take to replace? or what would someone charge for it to figure out which is best for me?
thanks
_________________
2000 Sport
2882/5100 906/5100
Old 02-23-2019, 08:48 PM #8
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
thanks
Replacing the alternator is not too hard at all. There's the wiring harness and a couple of bolts and it's out. You just have to pry a little bit to get the top out, there's a compression ring that hold it in the alternator bracket that you have to bump back in to get the new one in.
Stay with a stock DENSO unit. Even a junkyard unit would do better than those awful reman'd units from a part store.
326WHP 347TQ
Old 02-23-2019, 11:40 PM #9
I did a new Denso alternator from Amazon when my diode went out.
Alternator change outs can be done with the batter in place. But you'll have a whole lot of more room to work with if you remove the battery.
Keep your old alternator!! Don't turn it in to get your core charge back. If you want money you should sell it on here. Someone could rebuild it or use the voltage regulator or the diode trio to get a dead alternator back on the road. Those two parts are the usual suspects that go out when the alternator dies, and also alternator brushes if the alt has high mileage.
completely , dead , door , gas , squealing
Sudden Squealing Belt HappyHooligan 3rd gen T4Rs 2 02-23-2019 11:33 AM
Belt Squealing XJeepguy 3rd gen T4Rs 45 11-06-2018 03:41 PM
Sudden oil loss. UPDATE sawguy 3rd gen T4Rs 34 03-22-2018 10:50 AM
Squealing Belt BRUIN8124 4th Gen T4Rs 6 11-09-2016 09:45 AM
AC belt squealing..bad compressor? durrell 3rd gen T4Rs 15 04-09-2010 06:36 PM
