Old 02-28-2019, 09:11 PM #16
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree has a spectacular aura about thezentree has a spectacular aura about
thezentree's Avatar
Originally Posted by kolelt View Post
How are your lbj?
Like a year and a half old with maybe 15k miles on them. No vertical play at all that I can tell.
Originally Posted by dogtail View Post
Yup mine was very loud and could feel it thru the column. Felt like a metal to metal harmonic grind. But.......my power steering pump was getting loud to. It was I guess having trouble passing the fluid, gunked up, fighting itself when I turned the wheel. mine got progressively worse, it wasn't all of a sudden.
I just did a lazy flush, pulled the rack line, ran some fluid thru it running, closed it up ran it, flushed it again. Took under 30 minutes. Worked like a champ after that with well over 300K on all steering components. I think power steering flush is out of most peoples thoughts for maintenance.
Interesting. I've got no PS pump whine and it just all of a sudden started doing it so I don't think that's what caused it, but this is a good reminder to flush mine and clean the screen anyway.
I got it aligned yesterday and it seems like it's much better but I did get a little groan/creak out of it when I was trying to replicate it. I'll try to remember to shoot a short video and put it on youtube tomorrow.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 03-01-2019, 01:05 PM #17
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
you said it did it when only partially turned, but it sounds like it may be the steering stops. 1 half of which is built into the lower ball joint. it may just need a bit of grease.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 03-01-2019, 07:02 PM #18
Fontain Fontain is offline
Fontain is on a distinguished road
Sounds like your steering rack bushings, especially if you can get to the point where it creaks, then move it off and back on duplicating the creak.
Fontain is offline   Reply With QuoteReply With Quote
Old 03-01-2019, 08:53 PM #19
thezentree's Avatar
thezentree's Avatar
Ugh I hope not, but that sounds plausible. I replaced them last year with poly bushings and it was such an annoying job. I'd almost just rather deal with the creak than do that again haha.
afternoon , creak , moving , replaced , steering
Is it normal for power steering to squeal at full lock? 5VZFE 3rd gen T4Rs 7 02-04-2015 01:22 AM
steering screeching at full lock Cow_doc.308 3rd gen T4Rs 1 11-10-2014 02:06 AM
Getting godawful mileage and funky steering goro 3rd gen T4Rs 1 09-20-2013 08:38 AM
Steering creak Bighead2001 3rd gen T4Rs 4 01-08-2013 01:33 AM
turn signal steering column creak Bourbonator 5th gen T4Rs 1 11-15-2012 03:41 PM
