Old 10-01-2020, 10:29 AM #31
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Originally Posted by pluton View Post
This was my thought as well.
Same.
Based on your description, I'm not sure what is pointing to a head gasket failure here, especially with good compression test results. Is the truck overheating or losing coolant or oil? Is the smoke white or grey? Is the smoke constant or just on start up?
I'd think the thinner oil could be getting past the valve seals which would cause some smoking after sitting a few days on initial startup or you might be getting some ring blow-by which could be causing some smoking.
I'd consider getting the leak down test done, put the correct weight of oil back in, and run it a few times to see if the smoking goes away while watching the temperature gauge like a hawk.
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 10-01-2020, 12:45 PM #32
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
Something that can point you in a direction is a simple cooling system pressure tester that you can rent for free at some parts stores. I think it is best to test the system when it's cold so check it after the system is stone cold. When you pump up the system let pump let it sit and see if the needle drops. Some tools leak a little giving you a false reading but to check it you can try it on another vehicle to see if the tool is faulty. If the pressure holds that's a good sign if the pressure drops and your system has been using coolant and you see no external leaks hitting the ground or a wet carpet on the passenger side then there is a very good chance that the head gasket has gone bad. I would lean toward a head gasket job including a head reconditioning. If you do a engine swap unless you have a good history you maybe looking at doing a head gasket job on that engine. Another thing that a DIY person can do is when the engine is cold you can start the engine if the steams (not smoke ) and is more than just condensation in the muffler you can turn the engine off before it gets warm then pull the spark plugs if to see if they are wet with coolant. Or stated earlier a leak down test is works to the other methods allow you to do the checks without a leak down tester.
plcfcng is offline   Reply With QuoteReply With Quote
engine , gasket , head , replace , truck
Blown head gasket 3RZ-FE 2.7 L - - Replace engine? pendragon 3rd gen T4Rs 14 03-02-2019 03:04 PM
Will Toyota Replace My Head Gasket? YotaGirlUW Classic T4Rs 4 04-14-2014 08:39 AM
head gasket repair leads to piston through head theresa4586 3rd gen T4Rs 37 03-20-2013 01:20 AM
91 4runner head gasket replace- help! runnerC2 Classic T4Rs 4 12-08-2010 01:20 AM
Head gasket, how to replace? prodigy2k7 Classic T4Rs 2 02-09-2008 08:38 PM
