Old 02-28-2019, 03:36 PM #16
rorikk's Avatar
rorikk rorikk is offline
rorikk is on a distinguished road
rorikk's Avatar
UPDATE: Might have been solved by IAC cleaning!
UPDATE: After testing my way home last night and way back into work this morning trying to recreate the warm starts after half hour of driving, I haven’t seemed to have an issue whether 5, 10, or 15 minutes after shutting off.
Soooo...looks like it was the IAC valve gummed up. Even though it looked pretty darn clean, cleaning it and the TB a tad more seems to have done it. Not celebrating yet, but I think it may be solved! (Bummer it took me that long to get to it. Kept thinking it couldn’t be since it’s newer and I’d already cleaned the TB). Glad I asked for all the help when I had just cleaned the IAC and that may have solved it...
If it’s not solved, I still have the fuel filter on hand to replace in the next few days regardless.
Originally Posted by AntleredRuin View Post
When warm (like after driving for a bit) and then shut off for 10-20 minutes, this check valve slowly fails and completely closes (not just one-way like a check valve should), which lowers fuel pressure. This makes it hard to start, and keeps the idle real low and sketchy for a minute or so, until the valve opens again (due to actual fuel flow, I'm guessing).
Let it cool down for 45 minutes and the check valve fully releases and you get easy starts again.
FYI keep a can of starter fluid on you. If it stalls and dies after a quick errand, you might not be able to restart it without waiting the 45 minutes. Ask me how I know.
The check valve sounds like exactly what it might be if the IAC cleaning proves to not have been the solution. Fuel filter will be my first go to as that’s a simple swap i'm planning on anyways.
And yep, I know how you know! I got stranded like that trying to pump the gas pedal several times before starting and still having no avail, leading me to replace the TPS as I thought was the fix.
Originally Posted by huski View Post
I have a jumping off point now. I'll report back with findings.
Thanks!
I hope it helps! I was finding threads similar to this all suggesting different things but they all had different solutions haha so I was a bit confused as to what to tackle next. Hopefully this helps you out!
You all have given some great suggestions on other things to check as well! I’ve mostly just read threads for info as it seems all things from 3rd gens have been discussed and researched extensively, but it’s so useful to have quick responses for questions that are still a little fuzzy! Thank you all!
‘97 4Runner SR5 4WD 5spd Manual
rorikk is offline   Reply With QuoteReply With Quote
Old 02-28-2019, 04:56 PM #17
Spktyr Spktyr is offline
Spktyr is on a distinguished road
Pumping the gas pedal prior to a start attempt does absolutely nothing good on any port fuel injection vehicle. At best, you just wasted your time and calories. I don't know why people still do this as there hasn't been a new design car or truck sold in America for more than 20 years that pumping the pedal would do anything on, once GM's TBI system was taken out back and shot. At worst, on some systems, doing that tells the computer the TPS is broken and that it should go into limp home mode - making it even harder to start.
The only pedal work that does do something prior to start is flooring the pedal and holding it while attempting to start. This is the universal "clear flood" method and tells the computer to turn the fuel injectors off entirely while cranking to clear a flooded engine. This has been the case on all port fuel systems since at least 1980 and I'm sure even further back.
2000 4Runner Limited - 2WD, 3.4L V6, Automatic - Bilstein 4600/Moog 'Tall' Springs, Manik brush bar, PowerStop Tundra Brake Upgrade w/ Stoptech SS Brake Lines, KC Hilites 6" Pro-Sport HID Spread Beam Pair Pack System w/ KC Lexan covers, 4th gen 17" wheels w/ Spidertrax and Rugged Ridge 1.25" spacers, oEdRo LED headlight bulbs, BMW E92 seats, ScanGauge II, Prodigy TBC
Spktyr is offline   Reply With QuoteReply With Quote
Old 11-09-2020, 12:01 AM #18
JohnOfTheJungle JohnOfTheJungle is offline
JohnOfTheJungle will become famous soon enough
Did this issue ever get solved? I had something similar happen to me today after wheeling all weekend and then driving 150 miles on the highway home.
Was running fine, stopped a gas station to fill up, restarted it to move it to a parking spot and went inside. Came out 5 minutes later and it didn’t want to start. Giving it gas with low idle kept the engine barely going for 5 seconds then it ran like normal and I drove home another 100 miles fine.
1997 Limited 4x4 3.4l 199k E-locker Blue Wire Mod | 255/85 r16 Maxxis Bighorn MT - LX450 9 wrap + Tokico black rear | Front: 2.5" King Coilover set @ 2" lift | True North Fab Front Bumper + Warn m8000 + Baja Designs Squadron Sport | Custom Sliders | NguyenWorks Rear Bumper + Tire Swingout
JohnOfTheJungle is offline   Reply With QuoteReply With Quote
Old 12-31-2020, 11:50 PM #19
jzarech's Avatar
jzarech jzarech is offline
jzarech is on a distinguished road
jzarech's Avatar
What year is your 4Runner?
I just went through the EXACT same thing a few weeks ago. Turned out to be my fuel pump.
There's a check valve in it that is supposed to keep the fuel in the fuel lines when the truck is shut off, to avoid slow starts.
I successfully recreated this 'no start' issue in my driveway, and a spritz of starter fluid got it going again.
Sent from my XT1080 using Tapatalk
I have a 1997 4Runner that dies upon start after it's hot --
I looked online and didn't see a check valve for a 97 3.4 Liter -- only a fuel pump. If I buy a fuel pump will it have the check valve built in?
Thanks.
ja
jzarech is offline   Reply With QuoteReply With Quote
Old 01-01-2021, 02:20 AM #20
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Thanks.
ja
Look into or search cleaning your Idle Air Control valve that's under the throttle body. There's some videos and write ups on here to help. When hot the valve will stick and not open which kills the engine at a stop or idle.
Also look into cleaning the Mass Air Flow sensor, also lots of good photos and writeups on here.
Both of those solutions are basically free (except for a new gasket for the IAC) and waaay less work than replacing a fuel pump. Our DENSO units are known to last 300K easy.
326WHP 347TQ
Old 01-01-2021, 11:25 AM #21
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Originally Posted by JohnOfTheJungle View Post
Did this issue ever get solved? ...
A careful read shows Post #16 from the OP says Yes.
Old 01-06-2021, 06:30 PM #22
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
Thanks.
ja
Yes, the fuel pump has a check valve built into it that fails.
My factory Denso unit lasted just shy of 200K miles. A new one cost around $100
AntleredRuin is offline   Reply With QuoteReply With Quote
idle , measured , start , warm , work
1997 warm start problems tobers 3rd gen T4Rs 6 07-08-2015 08:52 PM
2007 v8 sr5 4wd issue when stopping please read 07sarasotav8 4th Gen T4Rs 2 10-22-2010 07:14 PM
Dies after start/low idle on warm start Hogmoss 3rd gen T4Rs 3 10-19-2009 11:36 AM
1997 4Runner (3.4L V6) Warm Start Stall Problem? axhoaxho 3rd gen T4Rs 4 02-28-2006 07:14 PM
