03-30-2018, 12:31 PM
Coolant leak at WP - oil cooler hose
Just got finished my TB/WP/VCG and all associated parts. Had the truck running for maybe 3 hours and it appears there is a coolant leak at the hose coming off the water pump ( at the stat ). I believe it is P/N 15777A.
I cant even really see where this hose goes and if it is a replaceable part. Kind of pissed that I need to tear everything apart again.
Has anyone replaced this hose?
SOLD. 1997 SR5 auto w/ factory E Locker - purchased June 2017, tranny cooler, 60A Blue Sea Fusebox, deck plate mod, rear heat delete, 99+ headlight swap, 99+ console/cup holder, PIAA Fog Lights 55W, LED dome/map/reverse lights, Firestone Air Lift, KYB shocks/struts,MOOG front springs, OME 906 rear springs, 265/75/16 E Duratracs, Tundra Sport Rims, Kenwood KDCX700, pioneer 2 way front speakers, Rear Diff Breather EXT
2012 SR5 - tranny cooler, Bilstein 4600's, OEM Trail wheels, 1.5" wheel spacers, Duratracs
03-30-2018, 12:50 PM
How big is your leak? Curious to know how difficult this hose is to replace. Mine had minor weeping at the connection, so I just added another clamp next to the existing spring clamp which has fixed the weeping. I plan on replacing the hose the next time I do a coolant drain.
Also, if you're going to replace this hose there is also another U shaped hose in there for the oil cooler which makes sense to replace too.
03-30-2018, 12:54 PM
Yes, there are two hoses that go to the oil cooler. One long one that connects to the oil cooler and water pump, and one short "U" shaped one that connects to the oil cooler and block. Everyone said they are a pain to get to and change, but I just did mine and the worst part is draining the coolant because it always seems to go everywhere but where you want it to go... Replacing the hoses only took a few minutes.
All you need is a couple different pliers so you can figure out which one works best for each hose clamp. Then pull the hoses off, slide the new ones on and put the hose clamps back on. While you are in there you may want to consider replacing the O ring that goes between the block and oil cooler and "washer seal" that goes between the oil cooler and bolt that holds it onto the block. They can leak (oil) as they get hard and old.
I just did this job as I had a very slight oil leak from the oil cooler, but I also changed out those oil cooler hoses while I was in there.
The best way to get to the oil cooler is through the driver side wheel well. It's the big round thing towards the back of the block.
Oil cooler hoses part numbers are:
Short "U" shaped on: 15777-62020
Long one that goes to WP: 15778-62030
O ring for oil cooler: 90301-67004
washer seal for bolt to oil cooler: 90210-22001
Check these part numbers before you order just to be safe!
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
03-30-2018, 01:50 PM
Ok thanks for the info. Im more pissed that the entire truck is back together. I dont want to have to remove everything all over again.
I think if I unbolt the oil dipstick from the WP neck, i should be able to get to that clamp. Cant even see where the other end goes to.
The leak is large enough for me. Ran the truck for 3 hours, no issues. Drove it around the block and when I came back it was leaking.
03-30-2018, 02:20 PM
Don't even need to take the dipstick out, just work the pliers so the two handles are between the upper alternator belt. I used a medium sized pair of channel locks for that one. When you take off the driver side front wheel. There's a little splash shield there that blocks the view of the oil cooler. Take that off, and you'll see the oil cooler and other end of that hose. You will most likely have to break the clips holding that piece on if they are the OEM ones. I replaced mine with some from autozone that you can get out without breaking...
03-30-2018, 02:21 PM
Thanks for the advice. Are the hoses, washer, o-ring all serviceable through the driver's wheel well? Other than taking the wheel off, does anything else need to come off?
03-30-2018, 06:35 PM
Anyone know the inside diameter of the hose?
Im not paying $100 for a rubber hose.
03-30-2018, 07:08 PM
These hoses have custom bends and tight turn radiuses. If you use a normal hose with the U shaped hose you risk collapsing the hose and cutting off the flow.
03-30-2018, 07:12 PM
Not the U shaped one, the long one that comes off the Water Pump.
03-30-2018, 11:26 PM
Real Name: John
Real Name: John
TOYOTA 4RUNNERVZN185L-GKMGKA - TOOL-ENGINE-FUEL - ENGINE OIL COOLER | Japan Parts EU
$100 for the hose??
1577862030 $26.89
Camelback Toyota price
EDIT: Just saw you were in Canada. I guess prices are 400% higher?
Here's both hoses Ships worldwide
https://www.ebay.com/itm/NEW-GENUINE...NYGScs&vxp=mtr
When I did this I did the whole replacement of the Oring, bonded washer, and 2 hoses through the wheel well. Disconnect hoses from the block and WP and take the bolt out. Take it out and note the hose position. Put the new hoses on in noted position and feed it back in. I can't remember if the large oring fits tightly in the oil cooler (I think it doesn't) Use some grease to hold it in the groove. Even then be careful it doesn't come out when you snug up the cooler.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
03-30-2018, 11:28 PM
Im in Canada. Camelback doesnt ship to Canada.
Most of the US places that sell OEM parts will not ship to Canada ( even amazon ). Cheapest I found in Canada was $56, plus $30 shipping and wait 2 weeks.
03-31-2018, 07:41 AM
I saw that ad on ebay. So after the exchange, its $55. Plus $64 shipping. Plus plus plus.
03-31-2018, 12:09 PM
Real Name: Leon
Real Name: Leon
I'd be willing to help out a forum bro - it looks like shipping to Canada from me is under $20. If you tell me exactly what hoses you want, and your postal code, I can see what it would cost. I don't need to make money on this, I'd do it as a favor.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
03-31-2018, 10:45 PM
Hey man thanks a lot! Ive been trying to make friends with anyone in Northern NY so I can go pick up parts from them haha.
I ended up going to an Auto Parts store today and grabbing a chunk of 1/2" heater hose and 2 gear clamps. Cost me $4.
I did a test fit first and I determined I could remove the old hose ( from the WP to the oil cooler ) and replace it with my new piece. It was not super easy, but it worked. Was able to make a nice bend radius with no kinks. No leaks as of yet.
04-28-2018, 12:10 AM
Just did my hoses and oil cooler gaskets today. WOW what a huge pain the arse it is to get those hose clamps off! It's all accessible via the driver's side wheel well, but still extremely difficult. What really saved me was the specialty locking hose clamp pliers I got off eBay. I would NOT want to attempt this job with standard pliers!
Also, I highly recommend going the extra step and replacing the oil cooler gaskets. After 20 years of heat, the factory O-ring is guaranteed to be shot. Mine was hard/brittle and broke apart as soon as the cooler was removed.
