02-28-2019, 04:10 PM
Tundra 5100s with Tundra Eibach Coils (UPDATE with PICS)
Ok guys and gals, I tried searching but didn't find what I was looking for. My current setup is Tundra 5100s with Factory Tundra TRD coils. A lot of us are running with this setup. I am on the 3rd perch and with full armor, winch, and 861s in the rear. I need a little more lift up front without going to the 4th perch because the preload would be too much.
While doing a search, there are some people who are running the Tundra 5100s with Eibach coils but are running them with 4runner 3" Eibach coils. I was wondering if anyone is running the 5100s with the Tundra Eibach coils? I believe the part number is E30-82-066-04-20. If so how much lift are you getting? What perch are you on? What is the ride quality like? My theory is that with these tundra coils I should be able to set the perch on the very bottom and achieve the lift in need.
Reason: Update
03-01-2019, 01:16 PM
Nobody has tried this setup?
03-01-2019, 02:31 PM
In the name of scientific research I ordered the Eibach Tundra coils. I will post an update with measurements and a review on how they ride. If all goes well, hopefully the mods can add this combo to the lift section. If all else fails, I will surely report back as well. Wish me luck.
Pro-Lift Performance Front Coil Spring Set for 2000-2006 Tundra (E30-82-066-04-20)
03-06-2019, 06:09 PM
***UPDATE with PICS***
Ok guys and gals, I just installed the Tundra Eibach coils (part # E30-82-066-04-20) with my Tundra Bilstein 5100s. Not to be confused with 4runner / Tacoma Eibach coils, which is the combo everyone seems to be using. I installed them on the second perch and the ride quality is amazing. Smooth and comfortable. Total lift from hub to limited fenders is 23.5”. This is after settling which was very slight btw. My previous setup was the Tundra TRD factory coils on the 3rd perch along with a ¼” top plate spacer. This gave me around the same amount of lift but the ride was extremely harsh.
Needless to say, I am very happy with this setup and my only regret is not doing it sooner. I spoke to Eibach and they said this coil is not progressive but linear and the coil is rated at 645 lbs. The angles all look good and the flutes on my cv boots don't touch, this is of course after doing the boot slide mod.
Keep in mind I have a front bumper with winch, rear bumper with tire carrier, skids, and sliders. If you are stock, these numbers would definitely change. You could probably get away with the same amount of lift on the first perch.
I hope this helps anyone that wants to go this route.
03-06-2019, 08:41 PM
Just bought the Tundra TRD coils and Tundra 5100s with top spacer and 890s in the rear. Did you try running the first perch at all? Curious to know what the ARB bumper and winch on the front setup feels like and how tall the lift is on that setting.
03-06-2019, 08:45 PM
Real Name: roGer
Real Name: roGer
damn dude how is the underside of your truck so damn clean?!
2002 Toyota 4[thedog]Runner Limited BFGoodrich KO2's | Taco whip | Paranoid Fabrications switch panel | full length roof rack | Tundra brakes with SS lines | ARB Awning | ARB compressor and f/r lockers | ToyTec lift (ugh) upgraded to Kings | Total Chaos UCAs | WARN winch | 4xInnovations armors | Method Grids | KC Roof Lights | Lotus Development CV Axles | Whiteline Bushings | Spidertrax spacers | SnoMaster Fridge | ReadyLight | holy shit this adds up fast
Insta: wkendnomad | this is where the adventure begins
03-06-2019, 08:52 PM
Also what size tire are you running?
03-06-2019, 09:04 PM
Real Name: Rich
Real Name: Rich
That looks great! I gotta ask, what year are the shocks from,,,I found the tundra part number for Eibach struts E60-82-066-02-10-P on Eibach website for 230 a pair and 140 for the springs,,,are the Bilstein struts better??,,,found Bilstein part number 24-188265 for the strut 240 a pair,,,do I need the upper a arm or will stock work and the limit strap setup...do I need that...what bump stops are needed.//I would be embarrassed to admit what lift I have up front but I've ridden in duece n halfs that ride better.
Bought this 99 in 01 and haven't let it go since! Valve dropped at 195k so I rebuilt it with reman heads, new rings and one new piston...tough to find the correct numbered one but I did...still had the original hatch...I soaped it and did a light hatch to help the new rings seat...that was in 2015...since then I did a basic lift and put some VTX 18x9 inch wheels with 0 offset...Ive grounded the rear locker, ran a diff extension into the gas cap, did the hood piston mod...GM Alternator...13WL brakes..30 year ASE Master Tech with more tools than sense, so I quit everything and work at home now.
03-06-2019, 09:37 PM
I went straight to the 2nd perch thinking that if it was too high I could always change it to the 1st. I basically rolled the dice and it worked out in my favor.
03-06-2019, 09:38 PM
My CV Axles are pretty new and I always use the pressure washer at the coin carwash.
03-06-2019, 09:39 PM
285/75/16 (33s)
03-06-2019, 09:52 PM
Thanks, the struts were part of a complete lift kit from Sonoran Steel (Kit 1.2), the kit included factory TRD Tundra coils which on the 3rd perch was too much preload for my liking to obtain the height I wanted. With the Tundra Eibachs I was able to obtain the same amount of lift on the 2nd perch (less preload) which equates to a softer ride.
You can get away with not getting UCAs but if you do it helps correct the caster on your alignment. It also alleviates the extreme angle on your upper ball joint.
The limiting strap helps alleviate stress on the the strut at full droop and also prevents the cv joint from binding at full droop. I have it set right before full droop.
03-06-2019, 10:07 PM
Real Name: Rich
Real Name: Rich
Perfect!!! Do my part numbers look ok for the struts...used 2005 tundra,,,seems used alot here...and do the stock runner upper mounts work on the coils?? I'm clicking to buy if that's a go...I really don't care about caster lol.
03-06-2019, 11:44 PM
Thanks man all good info. After reading this it will most likely be the way I go when I change out what I have. Currently 99 talls on the 3rd perch of Tundra 5100.
IG: @4runnerfiend- 1999 SR5: TRD Supercharger, ELocker, Wheelers T1 Coils-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, Savage skids, Hot Metal Fab Front Tube bumper, Savage Rear tube bumper, TruckShopSD Sliders, DuroBumps, RidgeGrapplers, Doug Thorley Headers, yellow top, XRC 12k, ARB single compressor.
