03-01-2019, 04:02 PM
97 to 99 maf swap now check engine light??
I did a maf swap to 99 now i have a p0171 lean code. Anyone has the same experience. Check tube for crack, clean new maf sensor. Light come on about a day later.
(DD)-97 4runner limited Green. Camburg uca, Icon w/700 Rear 210v w/ Foxs, Arb locker, Gear- 4.88 F&R. Tundra Trans cooler. All armor BFF
(Crawler) 95 Toyota pickup 22re, dualcases 4.7, Longfields, 37s, Dual Arbs.
IG: Jaysen4runner
03-01-2019, 04:42 PM
Real Name: Jerod
Real Name: Jerod
Nope. Either you really do have a vacuum leak somewhere in the new intake or the sensor is no bueno. I'm guessing you already looked up the wiring change that you need to do on the connector?
03-01-2019, 05:39 PM
Apologies for the noob question - but just curious what the benefit of this swap would be? Better fuel economy? More power?
1997 SR5 5-speed + factory locker
03-01-2019, 07:57 PM
Real Name: Jerod
Real Name: Jerod
If your MAF fails, the newer style ones can be had new for about $60.00, as opposed to $400.00 for the old turbine style. It's an easy swap if you can also get your hands on a 99+ air box.
For those of us that have a supercharger that craves more air flow, yes it's about power.
03-01-2019, 08:02 PM
Thank you guys! Found the problem, the part number was wrong on the mass air flow sensor. Part number from evay Denso 22010 wrong, correct 21010. I know some or you guys are familiar with some previous post on the right maf!
IG: Jaysen4runner
03-01-2019, 08:03 PM
I just change the air tube part from a Volvo instead of the while box! Yes i readed one of your previous posts on the right maf sensor from ebay!😁
IG: Jaysen4runner
03-01-2019, 08:07 PM
Real Name: Jerod
Real Name: Jerod
Glad you caught it! I'm surprised it actually ran with the wrong part number, the ECU was probably seeing voltage readings that were out of normal operating range.
03-01-2019, 09:30 PM
@ gamefreakgc
glad we have guys like you in here to give out good informations!
IG: Jaysen4runner
03-02-2019, 03:24 AM
@ gamefreakgc
@ gamefreakgc
for t4r president!
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
