03-05-2019, 03:15 PM
Real Name: Evan
Real Name: Evan
New OME rear 3rd Gen spring design/ numbers?
Ive seen a lot of posts recently regarding 890s being a 2 Lift spring. I saw in Bilsteinlifts.com and Wheelers that the 2890 is a 2 Lift spring, and the 2891 is a 2.5-3 Lift spring. They list 890s as a stand alone 3 spring. I swear the 890s actual part number used to be 2890 and people always refer to them without the 2 in front. There was 2906 (2 heavy load), 2890 (3 medium load) & 2891 (3 heavy load), which were their selections for 3 lifts and under for years. I had a set of 890s and they were 3 unloaded.
The spring design is different on the stock photos too than what my 890s were. There was a dual rate coil at the bottom like the Toytec Superflex and like the 891s still show, and now the stock photos show no dual rate coil like they used to. They appear to have relabeled the 2890s as a 2 spring and still offer the 3 version as the 890. Its becoming very confusing to reference these at this point when discussion spring options. Anyone else notice this?
2890
ARB 2890 Old Man Emu Black 2" Rear Lift Coil Springs for 1996-2002 Toyota Prado 90 Series/4Runner
890
Rear OME 890 Coils for 1996-2002 Toyota 4Runner
2891
OME 2891 Coils 2-2.5" Rear Lift for 1996-2002 Toyota 4Runner
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8 RR/ Anonymous Fab lower uniball McNeil Racing fenders Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps 315/70/17 BFG KO2 on Robby Gordon wheels 231mm TBU / Wheelers SS lines MStudt rear swaybar links Tom Woods driveshaft Satoshi K&N FIPK w/ AFE dry filter Borla Pro XS URD short throw shifter & Ellis Precision shift knobs Uniden PRO 520XL & 3' Firefly on custom mount Prinsu full rack Baja Designs Squadron Sport Sae & combo beam lights Paranoid Fab switch panel with Ram mounts Extended rear diff breather 01-02 tail lights Stubbs HD-SKO sliders Any 7 Offroad gas tank skid @Assburns custom tube front bumper Nguyen Works swing out bumper FROR rear links
03-05-2019, 03:31 PM
Real Name: Evan
Real Name: Evan
This link to Wheeler’s shows none of their rear springs have the dual rate coils on one end of the springs. The 2890, 2891 and 2906 are all there, and missing is the 890 that the Bilsteinlifts.com shows as a separate coil. Are they getting rid of the 890 offering?
Shop By Vehicle - 4Runner - 96-02 4Runner - Suspension - OLD MAN EMU - 4Runner Suspension
03-06-2019, 01:10 AM
Originally Posted by Dezert4Runner
I ordered Trail Gear ARB-2890: OME SPRINGS 4RUNNER REAR | JEGS
These back in August (because they had free shipping and like 15% off)
And They were the correct ones with the Dual rate springs at the top even though they look basically like a front coil spring without the stacked/rolled coils at the top. Is that what you're trying to figure out? I doubt their getting rid of the 890's Its just Probably different photos floating around between different distributors/sellers. Still a little strange though because I do remember wondering if I would get the correct springs based on the photo being different.
2000 Limited 4wd Millenium Silver Metallic, E rear locker, KYB Monomax All around, '99 tall coils up front with daystar 1" spacer, OME 890's in back, Weathertech Floor and cargo Mats, Track decal shackle Brackets, Satoshi grill mod (wahoo), Diff breather mod, 200k+ and still going strong!
03-06-2019, 01:24 AM
Real Name: Evan
Real Name: Evan
The coil design is part of it, but Im trying to figure out of the 2890 is in fact a 2 lift coil (new offering?) and the original 890 is still a 3 lift coil. Wheelers doesnt offer the 890 only the 2890, and Bilsteinlifts.com offers both. Pretty confusing.
03-06-2019, 03:33 AM
Real Name: Blair
Real Name: Blair
I just checked the Bilsteinlifts.com website and I only see the 890 offered for 3 lift. Maybe I had it filtered too much. I did notice that they list the other sprintings with a 2 in front but list the 890 without it. Ive got the 2890 springs that I got about a year ago and theyre a 3 lift with the dual rate looking coils.
2001 SR5 - ProComp 69 series wheels, 285/75/16 Pro Comp Xtreme MT2 Tires, King extended travel front coilovers, 890 rear coils, King remote reservoir with CD adjuster in rear, Total Chaos UCAs, 4x Innovation sliders, Gobi Stealth rack, Savage rear bumper and skids, ARB onboard air, ARB rear locker, EIMKieth PCK, Pioneer head unit
03-06-2019, 03:38 AM
Real Name: Blair
Real Name: Blair
Wait, the plot thickens. When I searched 2890 on their site both springs come up but they list the 890 for the Prado and 2890 for the 4Runner. Pictures are different but maybe its the same spring which gives a different lift depending on the vehicle.
03-06-2019, 02:57 PM
The official word from OME is that the 2890's are 50mm lift (2") with 250 kg (550 lb) constant load. All OME springs have 4 digit part numbers, most of the PNs for the the coil springs start with a 2, so it is often omitted.
They are listed as 190 lb/in spring rate, which means 550lb load between the two springs would be about 1.5" of 'sag'. It never quite works out that way (spring rates are never 100% constant) - so 3" no weight seems about right.
ARB 4x4 Accessories - Old Man Emu International Application Catalogue | Edition 39 - Page 120-121
ARB 4x4 Accessories - Old Man Emu International Application Catalogue | Edition 39 - Page 154-155
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
