Old 03-07-2019, 12:58 PM #1
DaStuph DaStuph is offline
DaStuph is on a distinguished road
"Fixed" p1135 now getting p1130...2001 4Runner
After cruising the forums, I replaced the Air Fuel Ratio Sensor (234-9002 Upstream) just before the single cat and after a few minutes of running it kicked out a p1130 code Bank 1/Sensor 1.
I searched quite a bit trying to identify an answer before posting, but found a lot of cloudy information. Near as I can tell, I need to replace the o2 sensor in the exhaust manifold on the passenger side of the vehicle (part #234-4261)???
Is that correct? Just need some confirmation here before I end up in a cycle where I replace every damn sensor on the truck to no avail.
Thanks ahead of time!
DaStuph is offline   Reply With QuoteReply With Quote
Old 03-07-2019, 03:03 PM #2
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
Not sure if you are wrong or right but I'd pull out an ohmmeter/multimeter and spec it out according to the factory service manual. I'm unaware of an 02 sensor in the exhaust manifold (must be a 99+ thing if it exists).
What you could also do is pull the mass airflow sensor and throttle body and give them a good cleaning as well. It is possible that one of them is dirty causing the whole reading to be off.
APhelps is offline   Reply With QuoteReply With Quote
Old 03-07-2019, 04:10 PM #3
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
The next things I would check would your MAF, and o2 sensor. The o2 sensor will be passenger side, and pre cat. I'll be your o2 sensor is causing the problem.
MStudt is offline   Reply With QuoteReply With Quote
Old 03-08-2019, 12:34 PM #4
Thanks for the input!
Been a couple days driving with the CEL since I replaced the one before the cat. Started it this morning and there where no CEL lit at all. Weird. Started driving it and on acceleration it would pulse till you got on the highway. Made it all the way to work with no CEL...WTHeck!
The ONLY thing I've done is change the Air/Fuel sensor. Been too cold and wet to clean the MAF as suggested. Now I'm completely lost. Going to crawl under it this weekend and check my connections to make sure everything is tight and clean the MAF. We'll see. I hate tracking down these sensor issues.
Thanks again.
p1130 , replace , sensor , side , vehicle
00Spork's 2001 4Runner SR5 "Nebuchadnezzar" 00Spork 3rd gen T4Rs 77 05-08-2019 11:35 AM
I fixed my "broken" tailgate latch and made a video. bigskyeric 4th Gen T4Rs 1 10-17-2016 07:38 AM
Got my STEERING fixed... a little story, and an "after repair" observation TSO 4th Gen T4Rs 7 03-26-2012 12:00 PM
Sprucing up my "new" 2001 4Runner, need advice razlcat 3rd gen T4Rs 21 09-26-2010 08:01 AM
