Old 03-07-2019, 03:23 PM #1
schmauster schmauster is offline
schmauster is on a distinguished road
Slow rear windows, multiple things acting up
I've had this problem for a while but it's gotten wild lately...
The rear windows have always been slow to roll up since I met my gf who owns said 4runner about 5 years ago.
Lately it's been cutting off the radio with the door unlock and the rear cargo light will come on. Which circuit should I be looking at and any common issues?
It's got about 300k miles on it and runs great.
Other issue I'm working on is figuring out why only 4H doesn't work. It's had a transmission or two replaced in the past.
I know there's a small computer looking thing on the outside of the transmission. Thinking maybe it needs a different one.
I thought 4HI was more of a physical process like shifting gears?
Thanks for reading guys
schmauster is offline   Reply With QuoteReply With Quote
Old 03-07-2019, 03:31 PM #2
2000 SR5... It's red
Old 03-07-2019, 03:55 PM #3
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
Windows being slow could easily just be dirty/sticky window tracks. I've had great luck with numerous cars using some silicone spray into the rubber window tracks and working the window up and down a few times.
rightyouareken is offline   Reply With QuoteReply With Quote
Old 03-11-2019, 05:59 PM #4
Thank you! I didn't know if there was anything I could use to lube those.
The driver's side screeches horrible noises and gets stuck... It works great besides that.
Old 03-11-2019, 07:06 PM #5
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Originally Posted by schmauster View Post
Other issue I'm working on is figuring out why only 4H doesn't work....
It is a physical thing you do on 3rd gens to move the center diff lever to shift between the two (while stopped, in neutral). Luck and enjoy the runner.
Old 05-10-2021, 01:10 PM #6
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
so my drivers window and pass rear window are real slow.......plus the auto up does not funtion correct on driver side...., goes up then comes half way back down, so I dont use the auto up part and it works fine.....but the slow speed bugs me the most now that temps are above 40...hit 60 the other day
Question:
I guess Ill try to spray silicone in channels as I have read, hope that fixes it...but do wonder/ask
the front windows have had tinting added....I know amonia eats them, .........
but will the silicone hurt the tinting material ?
Old 05-10-2021, 05:11 PM #7
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Question:
I haven't had any problems with silicone lubricant reacting with window tint. I've used it with probably a dozen vehicles with tinted windows.
Old 05-11-2021, 09:52 AM #8
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Question:
Check to make sure your window is still aligned in the channel. I've had my front driver side window get slightly off track when the window was down all the way & the door was shut a little too forcefully. I had to take my door panel off to confirm. Realigning everything was pretty straightforward.
I haven't noticed silicone spray harming window tint but would also try to avoid getting it all over the place.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
great , rear , slow , transmission , windows
Sigh - slow power windows KellyJ 3rd gen T4Rs 11 08-20-2019 11:18 AM
Right rear brake acting funny jman11788 3rd gen T4Rs 2 02-26-2019 09:30 AM
1990 4Runner back windows very slow. Du6 Classic T4Rs 5 07-15-2013 03:16 PM
-Video- Silicone Spray on Slow Power Windows MaverickH1 Classic T4Rs 8 04-08-2013 02:01 AM
Rear window acting really funny. atomic punk 4th Gen T4Rs 3 03-07-2010 12:40 AM
