Old 03-10-2019, 03:22 PM #16
BamaDrewski BamaDrewski is offline
BamaDrewski will become famous soon enough
Originally Posted by LittleCaesar View Post
I try to keep BD’s postings somewhat on the lighter side of humorous, though many of his engine oil additives in one way or another do have merit.
I have these installed and can feel a firmer brake. I did this for two reasons: (1) update the 20 year old lines and (2) get a firmer brake.
For some reason, I have a "soft spot" in the middle of my braking. Firm on the start of the pedal push, soft in the middle and firm at the end. (I had this before the StopTech's). I have bled these brake at least 15 times and still have this weird mushy spot in the middle of a full brake thrust. Anyone know what causes this?
BamaDrewski is offline   Reply With QuoteReply With Quote
Old 03-10-2019, 09:40 PM #17
WWRD99's Avatar
WWRD99 WWRD99 is offline
Real Name: Rich
WWRD99 will become famous soon enough
WWRD99's Avatar
Real Name: Rich
When I did mine a few days ago some air found it's way up to the abs motor...it would bleed on a few pumps, drive it and get weak then do it again...had my son pushing the pedal...I had to dig out my old brake bleeder to get it to break free and bleed out...not sure if you have one but it worked in about 5 minutes for both sides...it's a hose that plugs onto the bleeder then goes into a bottle that pushes the fluid out then sucks it back in when you move the pedal...I can't remember what tool guy I got it from and it's not marked to get a number off...I'll do a quick search and see if I can find it.
Bought this 99 in 01 and haven't let it go since! Valve dropped at 195k so I rebuilt it with reman heads, new rings and one new piston...tough to find the correct numbered one but I did...still had the original hatch...I soaped it and did a light hatch to help the new rings seat...that was in 2015...since then I did a basic lift and put some VTX 18x9 inch wheels with 0 offset...Ive grounded the rear locker, ran a diff extension into the gas cap, did the hood piston mod...GM Alternator...13WL brakes..30 year ASE Master Tech with more tools than sense, so I quit everything and work at home now.
WWRD99 is offline   Reply With QuoteReply With Quote
Old 03-10-2019, 10:19 PM #18
WWRD99's Avatar
Real Name: Rich
WWRD99's Avatar
Real Name: Rich
Found it...not sure if I'd buy it from this seller...never used them before but this is the KD tool 3982 that I use...have had it for probably 15 years...I like it since it's not vacuum it won't pull air into the system like my shop air vacuum tool does really bad...it works so good that I don't need anyone else to bleed brakes.
KD Tools 3982 One Man brake Bleeder Kit 82171039829 | eBay
Old 03-11-2019, 04:48 AM #19
YOTAGUY93's Avatar
YOTAGUY93 YOTAGUY93 is offline
YOTAGUY93 is on a distinguished road
YOTAGUY93's Avatar
Originally Posted by 96RedRunner View Post
Since were on subject of brake lines I'm looking for extended lines.
@LittleCaesar are StopTech's any longer than stock length?
Web site doesn't say or have option, Tech service not open today.
Wheelers has them, which I have used they are SS braided extended performed well. Price not bad.
ToyTec has them along with crazy price and shipping.
same size as stock from what i recall. make sure to change out front and rears to ss i only changed the front and i get pull when i brake.(im assuming its that)
00' Toyota 4runner Limited 4x4-Adventure/Camping Rig
17' Toyota Camry XSE- DD
98' Toyota Corolla- SOLD
87' Toyota Tercel- SOLD
YOTAGUY93 is offline   Reply With QuoteReply With Quote
Old 03-11-2019, 02:15 PM #20
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Thanks,
Yea I don't like opening brake system any more than I have to. Rear axle I'm putting in soon will be dry, front diff swap happening same time.
Perfect time to change all four lines flush system. Had wheeler's lines on 96Red for 150k mi looked new, guess I'll go with what's worked.
Old 08-02-2020, 11:29 PM #21
hawkcharmer's Avatar
hawkcharmer hawkcharmer is offline
hawkcharmer is on a distinguished road
Anyone know the stop tech part number for rear stainless brake lines? There are a left/right that run along the rear axel. One of mine is leaking.
I have 199mm upgrade on my 99 4runner. Need to replace front and rear brake lines with stoptech stainless.
Front is 950.44014???
Rear ??
Any feedback is greatly appreciated
1999 4Runner SR5, 3.4L 5VZ-FE V6 | Tundra/890 coils | 5100 Bilsteins all around l 199mm Tundra brake upgrade | 265/75/16 Falken Wildpeak AT3 tires | ARB Bull Bar
hawkcharmer is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 06:33 AM #22
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
I thought only the 2001-2002 came with the two rear lines. And that the 1996-2000 came with one line on the pumpkin.
Or are you referring to the hard lines?
Rear ??
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 11:31 AM #23
Yes, Im referring to the hard lines that run left and right from the center connection to each drum.
Thanks
Old 08-03-2020, 10:47 PM #24
not sure if StopTech makes them, but here are the Toyota part numbers:
RH - 47325-35282
LH - 47326-35062
Thanks
Old 08-03-2020, 11:25 PM #25
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I believe stoptech only sells replacements for the soft rubber lines: Automotive and Truck Search | APC Automotive Technologies
326WHP 347TQ
brake , front , lines , steel , stoptech
recommendations for braided front brake lines 2ndhandyotaman 3rd gen T4Rs 2 08-09-2018 08:59 AM
Extended Brake Lines -steel braided, any recomendations on a place to get some? the great him 3rd gen T4Rs 16 01-27-2018 10:55 PM
Advice/opinions on SS Braided brake lines DMX512 4th Gen T4Rs 0 03-11-2017 07:29 PM
Hawk LTS + stoptech SS brake lines Ti-Ben 4th Gen T4Rs 0 04-29-2012 04:06 PM
Stainless Steel Braided Brake Lines - Are They Worth It? 4RNNR Engines / Suspension / Wheels / Tires / Audio / Accessories 5 03-20-2011 11:17 PM
