03-09-2019, 11:16 PM
3rd gen winch ready bumpers?
What’s a good brand bumper, or brush guard that has a winch, or is winch ready, that’s not insanely expensive?
Just bought a 2001 4runner on 33’s
3 inch rough country lift.
Looking to learn, and do a lot more to this 4Runner!
03-10-2019, 02:00 AM
Cheap and easy way is buying a winch plate and welding it to the front frame rails I have a winch and plate still in my garage I have yet to mock up and weld..Crazy how fast time goes. I would get rid of the rough country lift if your gonna add weight to the front. If not definitely upgrade your spring weight for the added weight. Theirs plenty of write ups and threads on different setups. Go with a good Bilstein/OME/toytech setup. You cant just throw weight on the front and expect it to all be good it's a lot of stress and strain on your front end suspension especially your LBJ's!
2000 Limited 4wd Millenium Silver Metallic, E rear locker, KYB Monomax All around, '99 tall coils up front with daystar 1" spacer, OME 890's in back, Weathertech Floor and cargo Mats, Track decal shackle Brackets, Satoshi grill mod (wahoo), Diff breather mod, 200k+ and still going strong!
03-10-2019, 06:50 PM
Don't know if I'll mount a winch or not, but the 4XInnovations bumpers are super strong and winch ready. They have many mounting points, but they are expensive at about $800 + shipping and are bare steel so you would have to decide what you want to coat them with right away to avoid rust. I powder coated mine, but now kinda wish I bed-lined them.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
03-13-2019, 05:07 PM
Real Name: The Native Explorer
The world is your oyster for winch bumpers, but most will run you 7 or 8 hundred plus possible extra for shipping/finish. very happy with my 4xinnovations setup. But cheaper, yeah, weld up a nice mounting bracket or even a front hitch tube. Good luck!
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
