Originally Posted by MStudt
The bolt is a M12-1.25, but I'm not sure on the length. If you can get 5 threads in you're in pretty good shape. The OEM part number for the bolt w/washer is 91619-G1222.
Mike
Thanks for this info on the part number, much appreciated.
Originally Posted by jremus
Like Jack just said above me.. replacement shocks come with new hardware
As for the lower bolt... they shouldn't be different sizes. It would likely be worth replacing those with matching bolts either new or perhaps from a junkyard if you're really in a pinch?
Yeah, my biggest concern is that the shock mounts on the axle were threaded differently on each side. Has anyone ever run into this before??
