Originally Posted by 2000se
Now you've just reminded me of the my own timing belt/wp ...
15 pcs Aircabinman TB kit is legit on my 3rd kit. Broke TB can cause damage to lower cover crank sensor leave you broke down in the hood, on side of interstate where idjits use E-lane for passing.
If you still have old BJ's rotate stud in housing, if you can rotate with bare fingers you got your money's worth,
new ones you'll need a punch or nail in cotter pin hole to rotate.
If stud can be pushed n pulled in housing with noticable movement between ball n housing your past .5mm wear limit.
