03-11-2019, 08:33 PM
What’s a good way to get more clearance on the front bumper?
So I recently purchased a 2001 4 runner, and it has 33” tires with a 3” lift, the tires are pretty close to the front bumper.
What is a good way to get more clearance without spending $100’s of dollars.
I am a noob.
03-11-2019, 09:15 PM
Real Name: Blair
Real Name: Blair
I am a noob.
The lower portion is plastic and really easy to trim with a Dremel, die grinder, or even a serrated knife.
2001 SR5 - ProComp 69 series wheels, 285/75/16 Pro Comp Xtreme MT2 Tires, King extended travel front coilovers, 890 rear coils, King remote reservoir with CD adjuster in rear, Total Chaos UCAs, 4x Innovation sliders, Gobi Stealth rack, Savage rear bumper and skids, ARB onboard air, ARB rear locker, EIMKieth PCK, Pioneer head unit
03-11-2019, 09:21 PM
Agreed, trim the plastic, it's easy to cut.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
03-11-2019, 09:22 PM
Sawzall for the win
03-12-2019, 08:55 AM
You could just remove the entire plastic valence so you only have the metal part..
Check out my website https://69thstreetgarage.com/
03-12-2019, 02:45 PM
official vendor
official vendor
You shouldn't rub the bumper unless you have wide flares. At full lock I would rub the wide flare portion on the bumper. I just removed those, and the problem was solved.
03-13-2019, 12:40 AM
Thanks!
I will definitely just trim the plastic!
03-13-2019, 12:54 AM
Real Name: Jerod
Real Name: Jerod
If you start noticing it's rubbing on the other side next, others have had luck hammering down the pinch welds just a bit to get enough clearance. If you search "tire rubbing" in the forums there's a lot of helpful threads.
03-13-2019, 05:03 PM
Real Name: The Native Explorer
Definitely trim the plastic valence with a dremel or cutoff wheel! And like everyone else is saying, hammer back the pinch weld on the rearward side. Here is a pic of how I trimmed the valence, feel free to check out my build thread for more pics.
Hope this helps!
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
03-13-2019, 06:07 PM
Real Name: Robert');DROP TABLE Students;
Here's some giant sideways pics of how I cut mine. Doesn't rub with 33s and about 2.25" lift.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
03-13-2019, 06:09 PM
Or not. Image hosting sucks here now.....
