Old 03-12-2019, 10:02 PM #1
Cole T Cole T is offline
Cole T is on a distinguished road
Cellular Ipad in-dash installation
Hey all,
I installed an Ipad in the dash of a Honda Element I used to have and it was awesome. The only thing that didn't work well is I had no access to the head unit because it was stuffed behind the ipad. This time around, I am going to make room to have access to the head unit so I can still plug in an AUX cord and use the volume knob.
Obviously, with an iPad in the stock head unit location, it would be super awkward to use. I'll be using wood and fiberglass to angle the ipad up about 45 degrees. I have a 5-speed, and my hand is often resting on the shifter, so this should make it ergonomic to use.
On the Honda install, I 3D printed the frame to hold the ipad. This was super inconvenient because the ipad wasn't removable. I don't really plan to remove it often, but it will be nice to be able to take it out from time to time when route planning on long trips. This time, I'll be using a frame by Fifield fabrications which allows for easy removal of the ipad.
The head unit will go under the ipad, and I'm hoping the CB radio will fit underneath that.
This will be my first time with fiberglass so I have no idea what to expect. we will see how it goes!
1998 V6 SR5 MT with 90k. Shrockworks rear bumper, Air-lift, Rocky Mountain Racks, Smittybilt 9.5 winch, General ATx
Cole T is offline   Reply With QuoteReply With Quote
Old 03-12-2019, 10:10 PM #2
Pics!
Here are the beginning stages. I'm not great at remembering to take pictures.
Also if anyone has some pointers with fiberglass, PLEASEEEE help me out! haha
Cellular Ipad in-dash installation-capture-jpg  Cellular Ipad in-dash installation-capture-2-jpg  Cellular Ipad in-dash installation-capture-3-jpg  Cellular Ipad in-dash installation-capture-4-jpg  Cellular Ipad in-dash installation-capture-5-jpg  Cellular Ipad in-dash installation-capture-6-jpg  Cellular Ipad in-dash installation-capture7-jpg
Old 03-12-2019, 10:22 PM #3
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
Hey, I've done some fiberglass, but I've been following these two dudes on Youtube that are mating a 80s mini and a Celica GT4. In Episode 22 they're using something called Milliput to build up the edges.
I've used similar 2 component putties (plumbers putty) for non structural carbon fiber repair (space filler really). https://www.amazon.com/Milliput-Supe...44921095&psc=1
Here's the video, it should be starting at the point where they do the forming. I think it could be a great and less messy way to do it: YouTube
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 03-12-2019, 11:01 PM #4
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
Take this as constructive criticism, but I’m doubting that you won’t have interference with the shifter with that iPad sticking out from the dash that far. I have a Ram Mount holding my phone and it comes out from the dash half as far and when I’m in first gear my hand is almost touching the phone/ Ram mount. Have you mocked it up and gone through the gears?
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 03-12-2019, 11:09 PM #5
Damn, Now I'm debating not using fiberglass at all and just trying that stuff or Bondo. Just to smooth over the corners as they did. Thanks a bunch for this!
Old 03-12-2019, 11:11 PM #6
Huh, I'm surprised that yours is so close. I've mocked it up by holding the ipad there and seeing that there is still plenty of room. However, I haven't confirmed if the bulk of the frame will be too much. Before I continue I'm going to install it to confirm. I'll let you know!
Old 03-12-2019, 11:15 PM #7
Real Name: Evan
Real Name: Evan
My phone comes up and out from the radio location right where the hand and shift knob meet the mount, and yours actually comes down and out so you might be avoiding the bulkiest spot which is the shift knob and have enough clearance. It just looks like it sticks out far so I’d definitely mock it up and check clearances before putting any more work into it.
Old 03-13-2019, 10:01 PM #8
I'm glad I test fit it!
Thanks for prompting me to check the fitment! The ipad itself is fine, even with the play in the synchros. However, the 3D printed piece where I had been planning on putting the single din head unit would have gotten in the way. I moved it back 1.5" from its original spot and now it will clear.
Cellular Ipad in-dash installation-capture-8-jpg  Cellular Ipad in-dash installation-capture-9-jpg
Old 03-14-2019, 01:32 AM #9
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Have you considered a short shifter?
Does the 4WD lever go into 4LO without interference?
JZiggy is offline   Reply With QuoteReply With Quote
Old 03-14-2019, 01:48 PM #10
Reinout's Avatar
Real Name: Reinout
Reinout's Avatar
Real Name: Reinout
I can't wait to see what this ends up looking like. Keep us up-to-date.
Old 03-14-2019, 01:55 PM #11
Hepar's Avatar
Hepar Hepar is offline
Hepar is a jewel in the rough Hepar is a jewel in the rough Hepar is a jewel in the rough Hepar is a jewel in the rough
Hepar's Avatar
Expect to be itchy!
2001 4Runner 4WD Sport Package, Millennium silver, 110,000 miles, 2nd gen TRD Supercharger, Toytec BOSS coilovers, 890 OME rear springs, Bilstein 5125 rear shocks, custom Baldlands front bumper, PIAA 520 driving lights and fogs, 4x Innovation Sliders (welded on!), 18" Magnaflow muffler, JDM corners, 65" Thule bars, 20% tint, 16x8 FJ80 wheels on 265/75-16 Duratracs, Husky mats w/ cargo, rear diff breather mod, 3M clear bra, remote start, Pioneer AVIC-8200NEX
Hepar is offline   Reply With QuoteReply With Quote
Old 03-14-2019, 04:36 PM #12
Coward's Avatar
Coward Coward is offline
Coward is on a distinguished road
Coward's Avatar
I like where your headed but it looks like a tight fit. I still want someone to take this idea and clean it up. Re-use the factory vents and if possible mount them vertical on either side of the double din instead of the gauge pod on the side.
Cellular Ipad in-dash installation-dash-jpg
96' 4x4 5spd-SS1.2
Coward is offline   Reply With QuoteReply With Quote
Old 03-14-2019, 04:40 PM #13
sogoood's Avatar
sogoood sogoood is offline
sogoood will become famous soon enough sogoood will become famous soon enough
sogoood's Avatar
damn, thats ugly. Ill wait for final pics. good luck brother
2002 Dorado Gold 4runner SR5 fully loaded/leather/JDM goodies
OME 882 fronts.LC 8 wrap rears/SCS Ray10 17x9" -38 Copper/Falken 285.70.17 P-rated/1.25" Spidertrax/TBU/JDM Hilux Surf Window Visors+LED Spoiler+Power Fold Mirrors/Hilux Surf Corners+Headlights D2S 5.0 x Panamera 2.0/Jaos Mud Flaps/Viper 5901/Blackvue dr750s 2ch/quarter tank of gas
Awaiting install of TrueNorthFab plate bumper and useless cool jdm parts
sogoood is offline   Reply With QuoteReply With Quote
Old 03-14-2019, 10:10 PM #14
HAHA, once I confirm that everything seems to fit, Ill be cleaning it up with sandpaper and Bondo. as long as its clean, I don't really care if it's bulky.
Old 03-14-2019, 10:12 PM #15
That actually looks really good! seems like a lot of work to relocate the vents though. Also, I learned from the element that it's impossible to use an ipad without your wrist being able to lean on something. Therefore, the shifter should be perfect.
access , head , ipad , time , unit
FS NJ: iPad Air2 128GB WiFi+Cellular - Unlocked $300 SteveNJ For Sale: Non-T4R Items 0 08-15-2018 08:43 AM
iPad in Dash? Kanger328 3rd gen T4Rs 7 11-06-2012 01:07 AM
