Old 03-13-2019, 05:35 PM #1
TOY builder TOY builder is offline
Real Name: Al
TOY builder is on a distinguished road
Real Name: Al
transfer case interchange?
Hi Guys, I tried a search and did not see what I was looking for, so I figured I just ask. I have a friend with a 1999 limited automatic transmission and the push button on the transfer case shifter and I have a 2000 SR5 automatic transmission and no button on the transfer case shifter, can we swap my transfer case and shifter (2000 SR5) into his 1999 Limited?
Will it bolt up directly?
Any small parts need changing?
Front and rear outputs to the drive shafts the same?
Thanks in advance for any help.
TOY builder is offline   Reply With QuoteReply With Quote
Old 03-13-2019, 06:05 PM #2
It will bolt up fine. Driveshafts F/R are different lengths.
The real challenge is fooling the electronics - the transfer case/4WD wiring is totally different between the Limiteds and the base/SR5's on the '96-'00 trucks (and between the '96-'98 and '99-'00 Limiteds).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-13-2019, 06:23 PM #3
Real Name: Al
Real Name: Al
Thanks Charlie.
Old 03-13-2019, 08:44 PM #4
MandAtaco's Avatar
MandAtaco MandAtaco is offline
MandAtaco is on a distinguished road
MandAtaco's Avatar
I swapped a limited t-case for a standard J-shift case in my 00 Limited. Besides the driveshafts being different lengths, the truck needs to be changed to turn the front diff on and off. It's not hard to do, I used a 5 pole relay to control the front diff actuator. The wires are all part of the harness that goes to the transfer case computer for the limited case. I found schematics for each truck and did the switch.
To go the other way would be a pain, you would need the harness for the transfer case and computer, not sure if its part of the chassis harness or a separate harness. It could be done though if you REALLY wanted too.
OverlandNV
-2000 4Runner Build Thread
-2004 4Runner
MandAtaco is offline   Reply With QuoteReply With Quote
Old 01-01-2020, 05:39 PM #5
szulbor szulbor is offline
szulbor is on a distinguished road
Can you put more details. About the swap?
Part numbers or something?
Thanks
Wysłane z mojego EVA-L09 przy użyciu Tapatalka
szulbor is offline   Reply With QuoteReply With Quote
button , case , shifter , sr5 , transfer
v8 transfer case swap to 6cyl transfer case? V8RUNN 4th Gen T4Rs 23 09-11-2020 01:40 AM
RCI Transfer Case Skid doesn't have Transfer Case Drain Hole boyfester RCI Metalworks 1 01-09-2018 08:35 PM
transfer case interchange between t100 and 3rd gen 4runner Chris Luciano 3rd gen T4Rs 8 10-10-2014 04:20 PM
transfer case interchange question topdown4runner 3rd gen T4Rs 0 10-18-2010 10:47 AM
Advance Adapters 50-5705 Transfer Case Adapter 700R-4 To A Toyota Transfer Case 21 To NMRunner Classifieds - buy & sell (no commercial ads please) 0 08-18-2010 11:42 PM
