Old 03-14-2019, 12:25 PM #1
lefty556 lefty556 is offline
lefty556 is on a distinguished road
Need help!
All,
I've got a weird issue on my 2000 T4R. I'm getting a weird surge out of the engine. I'll be holding the accelerator steady, but you can feel and hear the engine revving up and idling back down. It doesn't show up on the tach, but it can be heard and felt. It's almost like it's not getting enough gas or enough air. It's happening on a daily basis, and been happening for about two weeks.
Different brands of fuel. Everything has been mid grade or premium. I swapped out the air and fuel filters about 2500 miles ago. I did the ISR mod at the same time I replaced the plugs and wires, about 1100 miles ago. No change in fuel economy or performance, but it's weird and annoying.
I did get a P0420 code last weekend. I cleared it out, filled up with premium, and haven't seen it since (180 or so miles).
Any ideas on what to look at to try and figure out what's going on?
Thanks!
2000 Silver SR5 4X4
lefty556 is offline   Reply With QuoteReply With Quote
Old 03-14-2019, 12:39 PM #2
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
Could it be something like the AC compressor kicking on/off repeatedly?
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 03-14-2019, 12:43 PM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I agree, it sounds like it could be an accessory cycling. Battery voltage is good? Alternator isn't acting up? A/C and defroster is off?
If it was the engine, you'd see the tach move. You could also try turning overdrive off (button on the shifter) and then see if the tach moves at all or cycles. It's hard to tell with OD on at highway speeds if it really is the engine since the torque converter sometimes doesn't allow the RPM's to move much.
326WHP 347TQ
Old 03-14-2019, 12:48 PM #4
It's not the A/C. I haven't been running the A/C yet this year.
As far as I can tell, the alternator is good, but I haven't been eyeballing the voltmeter on the dash.
I'll try kicking the OD off and see what happens.
2000 Silver SR5 4X4
Old 03-14-2019, 02:15 PM #5
Real Name: Jerod
Real Name: Jerod
I don't know the climate where you are at, but if you have the front defroster on the A/C will turn on without the light turning on. I didn't believe someone when they mentioned it a few weeks ago until I tried it and sure it enough it does! I rarely ever use my front defroster though.
Also, if it's at all possible to get a sound or video clip (safely) that you could upload that would help immensely.
326WHP 347TQ
Old 03-14-2019, 02:29 PM #6
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
It makes sense given that the AC is used to remove the moisture in the air.
APhelps is offline   Reply With QuoteReply With Quote
Old 03-14-2019, 03:27 PM #7
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
I'd get some better diagnostics with an OBD scanner. It'll tell you how much the RPMs are jumping around, and you can also monitor exciting things like LTFT and STFT, O2 sensor data, etc, to see what might be changing with the RPM surges.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 03-14-2019, 03:58 PM #8
cfranck1's Avatar
cfranck1 cfranck1 is offline
cfranck1 is on a distinguished road
cfranck1's Avatar
I was having a similar symptom with my 02 Taco.
At highway speed around 62-65 mph, throttle held at a certain spot to keep speed on the highway, the engine would hiccup/skip for just a second. Could feel it but to small for the tachometer to pick it up.
Found out it was the Throttle Position Sensor had a dead spot and every time I hit that certain spot it make the engine "hiccup"
I think the previous owner did a lot of highway miles since I bought it with 215K on it and it would only happen at a certain position of the TP sensor while keeping the truck at a certain speed.
01 SR5 - 187k+/- 285 BFG A/T KO2 - 99 talls & front Trekmasters / Rear KYB - Hella fogs - Taco Mod - Fixed gaping hole in frame {SOLD}
02 Taco - 197k +/- BFG A/T KO2 285s + rims from 4Runner - saving up for suspension - House gets priority over Taco (for now)
cfranck1 is offline   Reply With QuoteReply With Quote
Old 03-15-2019, 01:33 AM #9
nissanh nissanh is offline
I suspect TPS as well. When TPS goes bad, you can notice the RPM jumping up and down. I noticed a faulty TPS on idle and the RPM went up and down on my 5 speed toyota. Stay with an OEM TPS.
Old 03-15-2019, 10:55 AM #10
The CEL hasn't come on, but there is a pending P0420 code in there. My scanner shows a constant 0 volts for the Bank 1, Sensor 1 O2 sensor. Bank 1 Sensor 2 shows anything from .1 to .7 volt.
I can't see the RPM bouncing on my scanner, but it's a WiFi scanner and has a little lag, plus it's kinda hard to watch that and drive.
The RPM surging/bouncing doesn't happen sitting still and idling. I only encounter it while moving. Typically when the engine is between 1800 and 2200 RPM.
2000 Silver SR5 4X4
Old 03-15-2019, 11:37 AM #11
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
I totally agree with this. I had same symptoms, no codes, my 4runner ran great, except at a certain speed, about hiway speed. On the other hand my x-wifes volvo did the same thing and finally determined it was the TPS. ( the volov one was about 300) So I thought , what the heck,its not a ton of money ( under 50 if I remember correct) and had gone through everything, cleaning maf, cleaning throttle body , full tune up, fuel filter adjusting slack out of the cables so thought, why not try it
problem solved
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 03-16-2019, 10:23 PM #12
So, I'm still having the issue. It occurs between 1900 and 2100 RPM, regardless of speed. I haven't had any form of A/C or heat going, as the weather has been nice.
I replaced the TPS last night. Did a double check on both the battery and alternator. They're both A-Okay.
No CEL. No pending codes.
Any other possibilities?
2000 Silver SR5 4X4
Old 03-17-2019, 09:57 AM #13
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
In our beloved FSM, surging has one culprit listed: Fuel Pump Control Circuit. Testing is described on pages 327-332. Complete 4Runner Service Manual 1996-2002.pdf - Google Drive
Luck and enjoy the runner.
2001 Limited 4WD - 350+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
Old 03-19-2019, 10:23 AM #14
Thank you! Question - is the Toyota handheld tester just a multimeter in a red box with a Toyota logo, or is it something special?
2000 Silver SR5 4X4
Old 03-23-2019, 05:35 PM #15
I don't have access to a Toyota Handheld Tester.
I went ahead and replaced the fuel pump. Based off of everything I know on this thing, it was bound to be original, so replacing can't hurt. I used a Denso 950-0100 pump/strainer kit and a Denso seal.
No joy. Still getting the surge. Still not pulling any codes.
I did notice that I have an exhaust leak. There's a partial failure of the gasket where the Y-pipe goes into the front cat. Could that be causing my problem?
2000 Silver SR5 4X4
ago , air , engine , miles , premium
