Old 03-20-2019, 12:11 PM #16
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
Originally Posted by cblock406 View Post
Pics are all good now. Got to check this out last weekend and it is very clean. I thought mine was clean but this is a definite step above. Well bought my friend!
Thanks sir! Glad you came by. I was able to do some good touch up on a few of the body dings and scratches. Paintscratch.com's color match was very good and it's looking even sharper now
I'm planning to do some preventative work on the cooling system this weekend. Got a new Toyota radiator, thermostat, radiator cap, and Aisin fan clutch coming. After hooking up the scan gauge the water temp is a bit higher than I'd prefer (195-205F) and my money is on the thermostat jiggle valve being at 12'oclock. I also did a few tests on my fan clutch it it's pretty weak at operating temp. Was planning on swapping the original radiator out anyway to head off pink milkshake syndrome so figured I'd toss in a few other new parts. It's already got a new water pump, upper and lower radiator hoses and fresh Toyota red in it from a dealer TB service so I should be good for years to come after tossing in these parts.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 03-24-2019, 06:14 PM #17
Ever since installing my scangauge I haven't been totally pleased with the coolant temps I've been seeing. I was averaging in the 195-207*F range in normal in town and highway driving. Going up brief hills would see the temp increase by up to 10*F pretty quickly. Though the timing belt had been changed recently, the thermostat hadn't been replaced since 2008 at the previous timing belt replacement. It was done at a local Toyota dealer, and I was very suspicious that they'd installed the jiggle valve at 12 oclock instead of 6 oclock.
Also, I wanted to replace the original radiator (has 165k miles on it) as well as the original fan clutch. I'd done some tests on the fan clutch and it seem to pinwheel too easily at operating temp so I decided just to replace it while I was in there. Finally, I also wanted to do a trans fluid drain/fill since I was going to have to top off due to the fluid loss in the radiator anyway. It had been about 5 years since the last transmission drain/fill at the dealer by the PO, so I figured it was due.
For the radiator I decided to go with the Toyota supplied Denso "made in Taiwan" version since it's so reasonably priced. It seems like good quality and the fit was perfect.
I also went with the Aisin FCT-013 fan clutch.
First things, first, up on the Rhino Ramps and drain the coolant. It kinda splashed everywhere, but the bulk was captured in the drain pan. Kinda a shame since the coolant was only about 600 miles old, but oh well.
Radiator out! Hmm, that dirt couldn't have been good for airflow!
The Aisin FCT-013 appears identical to the original as I expected.
Now for the moment of truth...did the dealer install the thermostat correctly per the FSM? Of course not! They installed it with the jiggle valve at 12 oclock
So, new thermostat and gasket in, with the jiggle valve correctly positioned at 6 oclock.
New radiator in and connected. I decided to buy the Lisle Spill Free Funnel on the recommendation of a forum member to make burping the system easier. It worked great! Just fill it with water/coolant until it stops going in, then run the engine with the front and rear heaters on until the thermostat opens. Then run the engine, blipping the throttle until you no longer see any bubbles coming up. It took a good 20 minutes for me, and I found squeezing the upper radiator hose helped free a bunch of bubbles quickly. When done, it includes a stopper rod which lets you take the funnel and excess coolant off the radiator without a major spill and dump it back into another container for later use.
Made in Taiwan...oh well. I would have preferred the Made in Japan version, but decided for 3x the price it wasn't likely worth it.
All closed up, check for leaks, and time for a test drive!
Test drive results
In short, wonderful. Where previously I would cruise in town in the 195-200 range, and see peaks up to 205-207 on hills, today's test drive including highway and hills saw my temps pegged at 186 with brief fluctuations to 184-188. They appeared MUCH more stable and resistant to rise, and when they'd go up to 188 on a climb, they'd drop right back to 186 on flat roads. So happy with the results!
Also, the transmission seems to be shifting smoother after the drain/fill. I think because I was on ramps, I was able to drain 6qts out of the transmission and it was pretty dark in color. I used Valvoline MaxLife ATF and it seems fine so far. I'm definitely going to do another drain/fill at my next oil change in a few thousand miles.
All in all a very successful day!
1998 BMW M3/4/5
Old 03-24-2019, 09:40 PM #18
cblock406's Avatar
cblock406 cblock406 is offline
Real Name: Christian
cblock406 is a jewel in the rough cblock406 is a jewel in the rough cblock406 is a jewel in the rough
cblock406's Avatar
Looking good man! My temp stays right around 188 all the time too.
Build Thread: http://www.toyota-4runner.org/3rd-ge...ce-thread.html
@projects_always
cblock406 is offline   Reply With QuoteReply With Quote
Old 03-25-2019, 12:17 PM #19
That slight variation is totally normal - remember, the thermostat is controlling the *inlet* temperature to the motor (82*C/180*F) and the temp sensor is on the outlet of the motor. When you are on it, the coolant will be absorbing more heat from the engine.
As for the jiggle valve - glad to hear it. It is very understandable that mechanics would miss this. Basically every other engine is 12 o'clock for installation of the jiggle valve, so they wouldn't even look at a service manual for that step.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-11-2019, 03:05 PM #20
Today I finally got some modern tunes in the 4runner. I particularly wanted a double din with a volume knob, no flashy graphics (wanted a more period correct look), adjustable lum color (this one is infinitely variable), bluetooth (of course) and HD Radio if possible. I found all of these in the Kenwood eXcelon DPX793BH head unit for only $179. It also has both a front and rear USB port, as well as a Qualcom aptX chip for increased bluetooth audio quality, for whatever that's worth. I doubt I'll be able to hear a difference but I'll take it. I installed it this morning with a plug and play wiring harness from Crutchfield that worked great. I also hooked up both the mast antenna and the diversity antenna using a Metra 40-UV43 Y adapter and a Scosche MDAB GM micro antenna adapter (for the smaller diversity antenna plug). Seems to work great so far.
The sound of this unit, even with the stock speakers, is sooooo much better than the factory head unit/amp. I can't believe how much more low/high end I'm getting actually. I also ordered some new 6 1/2" Kenwood seperates for the front doors and some 5 1/4" Kenwood coaxials for the rear doors that I'll be installing soon, so I can't wait to hear it with those installed.
1998 BMW M3/4/5
Old 01-13-2020, 08:54 PM #21
nerraw nerraw is offline
nerraw is on a distinguished road
running board
hello, wtb sunfire red running board. thanks
nerraw is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 09:19 PM #22
Sorry, im gonna hang onto them for now.
1998 BMW M3/4/5
4runner , bit , box , golf , time
JBD's '97 Sunfire Red SR5 T4R jbrentd 3rd gen T4Rs 68 03-17-2022 08:47 AM
FS: 2002 3rd Gen Sport - 4WD - Sunfire Red - $7000 - Boise, ID HaloArchive For Sale: Vehicles 17 07-20-2016 07:33 PM
WTB: Sunfire Red 96-02 Hood SCRunner12 Want to Buy/Trade 0 11-23-2015 01:58 AM
sunfire red? 4runit 3rd gen T4Rs 16 03-01-2009 08:56 PM
For Sale: 2002 Sunfire Red Sport Edition PunkRunner Classifieds - buy & sell (no commercial ads please) 0 12-11-2008 03:06 PM
