03-14-2019, 10:43 PM
Bought a pair of used LC coils >>>>
Found these on Craigslist for $75. I think they are 7 wrap. looks like two pink, light blue & white on one and two pink, dark blue, and white on the other <- I think this goes on driver side as it's a little taller
Can any of you guys who have installed these give me an idea how much lift I can expect installing in back of my 2000 T4R?
Thanks
2000 SR5 Sport 4Runner 4x4 5vze w/5 speed manual
Millennial Silver paint. Moon roof, Cloth Moon Mist interior
Still stock but not for long
03-14-2019, 11:19 PM
Did you try searching? There are a bunch of threads on this.
Just one of them -https://www.toyota-4runner.org/3rd-gen-t4rs/66753-lc-coil-spring-color-codes.html
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
03-15-2019, 12:33 AM
I have read every thread I could find on this forum regarding LC coils and suspension lifts at least once.
I think the two dots on my coils look pink. If the top two dots are purple then some members refer to them as 7.5 wrap. I have not been able to find any thread with info on how much lift 7 wrap or 7.5 wrap gives
03-15-2019, 12:43 AM
You’ll sit at 25” + ish hub to fender.unsettled with no extra weight. Keep in mind they are soft and linear so more weigh the more the compres.
I ended up taking out the internal cone bumosops which took away ~3/8-1/2” plus I have a storage box and full size BFg spare. It’s settled a bit.. trust me you will get a good 4-5 “lift unless you are running a constant 300-400 lbs in rear then you’ll be closer to 3.5 -4 “. I couldn’t be happier with the flex and ride especially with the price point it just takes research and trail to get it what you like/want
I have 3” lift in front and I get a 1” rake when not fully loaded. When loaded I level out or have a slight rake. That is the nature of these because they are,again, linear.
Also springs I got from a rig that had 280k springs will very depending on age and wear.
Tried to find pics that would represent.
IG: @4runnerfiend- 1999 SR5: TRD Supercharger, ELocker, Wheelers T1 Coils-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, Savage skids, Hot Metal Fab Front Tube bumper, Savage Rear tube bumper, TruckShopSD Sliders, DuroBumps, RidgeGrapplers, Doug Thorley Headers, yellow top, XRC 12k, ARB single compressor.
03-15-2019, 01:41 AM
great info, many thanks!
03-15-2019, 10:01 AM
No prob. The answers are out there I spent hours researching and was still shocked but how much lift I got. I even switched back to my old set up and the switch again to the LC springs. Happy I did
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
