Old 03-15-2019, 05:04 PM #1
Bigmd Bigmd is offline
Bigmd is on a distinguished road
Did my AC compressor crap out?
So today I went to top off my refrigerant for the AC. I bought the kit with the gauge and proceeded to fill. Before i knew it it was in the yellow of the gauge close to red part. I stopped and compressor made a weird noise and started blowing redrigerant out of a valve on compressor. Now the ac will not work and blows warm air out. Should i start shopping for a new one ?
Bigmd is offline   Reply With QuoteReply With Quote
Old 03-16-2019, 10:44 AM #2
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
My guess is that it never needed anymore refrigerant in the first place and you over filled it. I don't know if you ruined it or not. It might have too much fluid now and has no room to expand and contract. Might just want to spend the $100 and have a shop drain and fill properly. Can always try and bleed some off and see if a/c starts to work a little with lower pressure.
Chrisfix on YouTube did an awesome how to fill your ac properly if you want to try yourself again.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 03-16-2019, 10:59 AM #3
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Top off???
guess it wasn't cooling properly in all this Heat? I'd suggest taking it to a Pro, they're good at this stuff.
Old 03-16-2019, 11:29 AM #4
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
Sounds like you over pressurized it. Will the compressor turn on when you turn on the A/C? If not, will it turn on if you jump the relay terminals? If so then at least you know the circuit and the clutch is working. You may want to just take it to a shop that does A/C and have it recovered, vacuumed and recharged to the proper amount. Sometimes A/C in a can just doesn't work. Having it vacuumed removes air and moisture from the system. It is possible you will need a new compressor, having it professionally charged would confirm that.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 03-16-2019, 12:10 PM #5
Well it got up to 75 In Nj. My AC had never been ice cold. Will usually feel cold and then cycle to cool and then back to cold. By top off i meant when I had a can of AC PRO in garage . When i put the gauge on it was low , a little overs 15 lbs. I filled and kept checking the pressure . All was fine until I checked and it was in the yellow area of gauge. Compressor started making weird noise. Liquid shot out of the Schrader valve looking thing. I let some pressure off and checked it today. Seems fine , no noise and it’s blowing cold air. But it’s also 40 degrees out. So not sure what to do now. Funny thing is the passenger vents feel very cold while the driver side does not feel very cold.
Old 03-17-2019, 03:27 AM #6
calimobber's Avatar
calimobber's Avatar
One way to test is to get the car nice and hot from the heater. Then turn on ac cold with recycle mode. That will pull the hot air from the car. Worth a try if your curious.
You can also use a meat thermometer and stick it in the vent. It should cool the air a good amount more than outside temps.
Old 03-17-2019, 02:35 PM #7
Ok i did that . Got the heat nice and hot . Switched to AC and it got nice and cold. Also there is no more noise from compressor and clutch seems to be working. But I now have a new problem. I found a small puddle of antifreeze dripping from up top. Looks to be coming from the heater valve on firewall. i can’t see it dripping but there is some antifreeze below it on plastic shielding.
Old 03-23-2019, 12:33 PM #8
Ok a week later it seems to be ok. AC blows between 37-40 degrees. So I’m assuming it’s ok.
compressor , gauge , noise , started , weird
a/c compressor "screech" wen compressor engages or cycles? xspsi6 3rd gen T4Rs 9 06-14-2014 04:51 PM
Crappity-crap-crap! Help, Charcoal Canister damaged! DiskDoctr Problems & Warranty Issues 0 03-25-2014 05:11 PM
Well crap... Bfaulken 3rd gen T4Rs 19 05-30-2012 11:20 AM
Oh crap.... JeremyH Off Topic 4 11-17-2009 09:43 AM
strut compressor vs. spring compressor jmrwd3 3rd gen T4Rs 6 05-19-2008 03:03 AM
