Originally Posted by Hammer_Man
It's a little different than that. I know delayed shifting from 2nd to 3rd is normal when cold, however my truck won't get out of 1st gear. It'll go to 4k RPM trying to do 20mpg (not that I do that - i keep it under 3k).
on my GM truck cold 1-2nd 20MPH 2-3rd 30MPH.. goes up to 3KRPM.. 4K must be a pressure / fluid flow problem ..have the transmission shop do the pressure testing when it is cold.. or change the fluid/filter see if it improves .. when I converted to synthetic the upshifts and reverse engaged much faster ..the cold temp delay did not change because of the PCM program ..normal up shift on my GM truck and runner is the same 1-2 12 mph 2-3 around 20 MPH ..
