Old 03-17-2019, 09:11 PM #1
Turtle420 Turtle420 is offline
Turtle420 is an unknown quantity at this point
Intermittent strong pull to the left during hard braking
Hi all,
I'll apologize in advance for the lengthy post.
I've been having a strong pull to the left when braking for a couple years. Since then the rig has had a ton of work done. A lot of what was done was to try and eliminate the issue but it's still pulling, albeit not as strong and less frequent but it still happens and scares me because when it pulls I have to correct at the wheel and when I correct and then the steering snaps back the truck wants to go right cause thats where the wheel is pointed.
The massive mistake I made was lifting the truck and having a bunch of work put in before the braking/pulling issue got resolved. Not sure where to go from here, I've gone to a couple different mechanics and after a bunch of work they say "when you lift a truck sometimes issues like this come up and you just have to live with it."
The trucks been through a lot but long story short is, the truck was totaled in 2016 and I ran out of cash so I sold it to a friend, a year later he sold it back. When I got it back it had this issue along with a horrible steering problem.
This is the work that was done before the pulling issue, but the truck was in possession of a friend:
Front brake hoses
Bilstein 5100s
Moog Upper and lower control arm bushings
ball joints
This is the work that's been done since the pulling was an issue, trying to get it in order:
1st Mechanic
Steering column yolk
Extend rear brake lines
Toytec 3" springs
Lower diff
Pan hard bar drop
2nd gen tie rods
Tundra brake upgrade, rotors, pads, calipers
SRS F5s and tires 285/75/R16 Yokohama Geolanders
Rear brake cylinder, and shoes
Rack and pinion
Power steering pump - Pump ran dry about 15 miles after rack job
2nd Mechanic
LCA bushings (again)
ABS actuator unit - didn't fix anything
Brake pads (again) - made a world of difference
Troubleshooting done. Steel braided lines swapped from side to side, calipers swapped, ABS replaced
After the pads were replaced for the second time, the pull became way less frequent, almost non-existent. However, now I took it on my second road trip since all the work was done and I had to emergency stop on the freeway and it pulled, scaring the crap out of me. Afraid to take it back to a shop and expect a different response. I'm not very mechanically inclined but these are the possible causes I can think of. Hard steel line kinked or bent (but if this were the case I don't the issue would be intermittent), possible frame damage (but it didn't do this after it was totaled), maybe the M/Ts are biting when the weight shifts forward causing it to go with the camber of the road (but it has pulled before when going straight).
Has anyone seen this issue before or maybe has an idea of what could be causing this? Any help is appreciated.
96' SR5 4WD 5-Speed Manual
Turtle420 is offline   Reply With QuoteReply With Quote
Old 03-17-2019, 09:36 PM #2
baja1 baja1 is offline
baja1 is on a distinguished road
following...my '97 with SS lift has started front end shaking at highway speeds and when braking feels like the wheels are loose pulling side to side. replaced rotors and pads but not calipers.
baja1 is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 02:09 AM #3
Sherwood4Runner's Avatar
Sherwood4Runner Sherwood4Runner is offline
Sherwood4Runner is on a distinguished road
Maybe one or more of the pistons on your front brake calipers are frozen causing one corner of the car to "brake harder". That caused the steering to pull on my 4R under hard braking. Though, one would think that a mechanic would notice this when replacing the brake pads if that was the issue.....
98 Limited V6 w/310k Miles l 4X4 l Rear Locker l Goodyear Duratracs 265/75/16 l 199mm Tundra Brake Mod l Cobra 800 Watt Power Converter l Uniden Pro 520 XL CB Radio l Bilstein HD Shocks l CS 144 Alternator
Sherwood4Runner is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 06:10 AM #4
jman11788's Avatar
jman11788 jman11788 is offline
jman11788 is on a distinguished road
jman11788's Avatar
If you’re not replacing those LCA bushings with OEM or poly that could very well be the issue. All the others seem to be total S*** from what I’ve heard.
Also, make sure the rear brakes are adjusted correctly and all 4 corners are properly bled.
Does your steering rack have play?
2000 Limited 4wd Supercharged with E-Locker
jman11788 is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 07:01 AM #5
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
If the LCA itself is bent in the slightest, that may be the problem. I saw such on a truck once.
How does the tread look on the tires?
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 02:47 PM #6
I haven't got the side to side pulls when braking, it's always to the left. Did replacing the rotors and pads fix the issue?
Old 03-18-2019, 02:48 PM #7
I think this has been ruled out by now but we were thinking the same thing before the caliper replacements and even after they were replaced, I had a mechanic swap them thinking we'd see the pull going right.
Old 03-18-2019, 02:49 PM #8
They were originally replaced with Moog and yeah they were crap, failed within a year. Got OEM installed now.
Old 03-19-2019, 12:07 AM #9
Road Bull's Avatar
Road Bull Road Bull is offline
Real Name: Ryder
Road Bull is a jewel in the rough Road Bull is a jewel in the rough Road Bull is a jewel in the rough Road Bull is a jewel in the rough
Road Bull's Avatar
Real Name: Ryder
Jack up the front of you vehicle so that both front tires can spin. Give each a spin. If there is resistance, more than likely on the side you are pulling towards, I would say check your caliper. Mine was pulling driver, so I replaced the Napa TBU caliper on the driver's side. I decided to throw some new pads on the next weekend and noticed the passenger side was also frozen and not letting me mount the new pads. So over two weeks I replaced both front calipers and pads and bled the brakes. Now they feel FANTASTIC and don't pull.
2002 SR-5 in Millennium Silver.
Timeline>> http://www.toyota-4runner.org/3rd-ge...-timeline.html DEAD
2002 SR5 Changeling Build https://www.toyota-4runner.org/3rd-g...ing-build.html
Road Bull is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 11:57 AM #10
I took a look at the LCAs and I couldn't see a bend but I'm not sure a good way to look. Any advise on the best way to measure for a bend would be?
Tread looks the same, no unusual wear.
Old 03-20-2019, 09:43 PM #11
WWRD99's Avatar
WWRD99 WWRD99 is offline
Real Name: Rich
WWRD99 will become famous soon enough
WWRD99's Avatar
Real Name: Rich
This might not be it but almost every car I dealt with that had some weird random pull was the proportioning valve sticking...I know the 2nd gen used a level sensor for the rear for rolling but the 3rds don't afaik...I would brake flush a few gallons through the system and sometimes it would work ok...sometimes replace was the only thing that worked.
Bought this 99 in 01 and haven't let it go since! Valve dropped at 195k so I rebuilt it with reman heads, new rings and one new piston...tough to find the correct numbered one but I did...still had the original hatch...I soaped it and did a light hatch to help the new rings seat...that was in 2015...since then I did a basic lift and put some VTX 18x9 inch wheels with 0 offset...Ive grounded the rear locker, ran a diff extension into the gas cap, did the hood piston mod...GM Alternator...13WL brakes..30 year ASE Master Tech with more tools than sense, so I quit everything and work at home now.
WWRD99 is offline   Reply With QuoteReply With Quote
Old 03-20-2019, 09:45 PM #12
Kotletachka Kotletachka is offline
Kotletachka is on a distinguished road
Check alignment. Could be a bad master cylinder as well
Kotletachka is offline   Reply With QuoteReply With Quote
back , brake , issue , truck , work
Quick pull to one side while hard braking mwrohde 3rd gen T4Rs 35 07-11-2020 10:37 AM
Hard left while braking plus Traction lights/leak gaber6 4th Gen T4Rs 4 04-12-2018 03:14 PM
Hard Pull to the right under braking jsmith21 4th Gen T4Rs 18 07-14-2015 07:13 AM
She pulls to the left when braking harder, but not when normal braking... Goyo 3rd gen T4Rs 6 11-30-2012 08:21 PM
04 V8 Sport pulls hard left under normal braking natevans65 4th Gen T4Rs 5 07-12-2012 09:45 AM
