03-18-2019, 01:39 PM
Timing kit price
03-18-2019, 01:46 PM
cant speak from experience with this kit, but with the great reviews it has on Amazon for this platform - i'd say it's legit
2000 4Runner SR5 Sport
1998 Lexus LX470
03-18-2019, 03:32 PM
Don't forget thermo, gasket, new bolts and perhaps toyo red....
03-18-2019, 04:21 PM
Real Name: Jaz
Real Name: Jaz
yes definitely go with Aisin. i work at an auto shop and sell price at my cost is 220. Thats usually what it will cost.
03-18-2019, 04:53 PM
Real Name: Scott
Real Name: Scott
Originally Posted by jgue467
Don't forget thermostat, gasket, new bolts and perhaps toyo red....
^^This and might consider doing the crank seal while you're in there for good measure.
03-18-2019, 05:25 PM
That's the one I went with. Click the "Used and New From..." link and buy from Amazon Warehouse Deals.
They list open box items as "Used"
My Aisin TKT-025 kit was $141.54 shipped. Everything was in original packaging, but the outer box was dented.
Check out my website https://69thstreetgarage.com/
03-18-2019, 08:10 PM
That's the kit I used and it's a good kit. I suggest buying an OEM front main seal and do both of the cam seals (OEM). My front main seal wasn't leaking but both of my cam seals were leaking.
Also, buy this seal puller. It's works perfect for this job. https://www.amazon.com/Lisle-58430-S...omotive&sr=1-5
Toyota red coolant or Zerex Asian works fine also.
Might as well do the 3 drive belts and upper/lower radiator hose. Thermostat wouldn't hurt either...lol
That should just about do it...
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
03-21-2019, 12:00 PM
Thank you all very much I'm going to take your advice and get everything and do the whole nine yards you guys are a wealth of knowledge and I really appreciate it
03-21-2019, 12:22 PM
Real Name: Keith
Real Name: Keith
The best kit I could find was the Aircabinman vendor on Ebay. Didn't want to mess around with counterfeit parts. Good ratings. Not the cheapest, but chasing price has its price sometimes.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
05-03-2020, 08:51 PM
Ok I will buy the kit from Aircabinman. He has 2 available.#1 is complete toyota kit. #2 is a mix of Denso, Mistsiboshi and Aisin. Now my other question is about gaskets used in waterpump or something else. I have been reading about a "metal gasket". What exactly is this about on 98 4runner. Thank you.
05-04-2020, 01:40 AM
Metal water pump gasket is the one front and center in the aircabin kit. It’s the new style you want.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
05-04-2020, 12:35 PM
I've used multiple Aircabinman kits. Very happy with his kits, the parts in them and the price. Used them on 4Runners, a couple of Highlanders (tall Camry wagons), and a V6 Camry too.
One time I tried to save money on eBay buying aa part with what they said were 'OEM ' parts. I got the big box, and inside were a bunch of plain white boxes with black lettering on it. 'OEM' was the brand name. Hahahah. Very funny. It was all cheap knockoff crap, I returned it for a full refund and bought the Aircabinman kit.
