03-21-2019, 06:22 PM
Keeping out exhaust with back window down
I like to drive with the back window down sometimes. If I drop it more than an inch or so I get exhaust coming in the cab. If I adjust the windows up front I can minimize it but if I change speeds I have to readjust.
My rig did not come with a rear deflector...does it help at all with the exhaust smell coming in?
1996 4Runner with a 3rz-fe, e-locker and 5spd
2005 Passat TDI 5spd swapped
1997 E350 4x4 7.3 Powerstroke
03-21-2019, 07:03 PM
Official Vendor
Official Vendor
I think that's what it's specifically for, no?
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
03-21-2019, 07:07 PM
Cleans dust off the rear window at speed too...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
03-21-2019, 07:10 PM
That rear deflector you don't have - that's exactly what it does. It keeps exhaust from blowing into your cab! I bet you can pick one up pretty easy, online
03-21-2019, 07:31 PM
Real Name: 3 Bears
Real Name: 3 Bears
also , I think , that the stock exhaust coming out the side helps. back in the "olden" days..to keep the exhaust from coming in the back tailgate window was to reroute the exhaust to the side. Ive seen a lot of cars with exhaust out the back, when they originally came out the side. Some of the early performance exhaust systems for the 4runner came out the back instead of right behind the pass rear tire
03-21-2019, 07:56 PM
I just open sunroof part or all way for super sweet flow thru out the rear and no noise from side windows cracked or down all the way, works except maybe when stopped but that's what the Up button is for, eh?
I'm pretty sure Toyo got rid of the rear window deflector towards the end of the 3rd gen run cuz of fuel mileage lowered via the Parachute effect it also has. :^(
03-21-2019, 08:48 PM
The issue is were to mount it. There’s no bolt pattern.
03-21-2019, 08:51 PM
Do you think the BURTMAN Euro JDM Style Rear Spoiler would work? I don’t have a stock spoiler and been debating on getting this for a couple years now. Burtman Industries
03-21-2019, 09:48 PM
Real Name: C8H18 Mike
Drive everywhere in reverse, two problems solved
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
03-22-2019, 06:26 AM
Thanks, I'll start looking around for one. I thought they mostly helped keep the rear window clear of rain and dust. I can't see it helping with the window wide open but maybe it's worth a shot.
On the other hand do they get ripped off or damaged trail riding by trees and such? I don't have a factory roof rack either...
Sent from my SAMSUNG-SM-G870A using Tapatalk
03-22-2019, 08:26 AM
Amen on the sunroof/rear combo. My 02 came with a rear deflector tho. Love it.
02 Thundercloud Sport, 155k.
03-22-2019, 08:58 AM
Odd.
I drive with my rear window down/cracked all the time and I've never experienced this both on the road or the trails.
Full disclosure, I do have the deflector thingy though.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
03-22-2019, 10:27 AM
I noticed this the other day too.
So, i have the deflector and still get some fumes(enough that the wife brought it up, so probably not that much) but depending on the speed i'll just roll the windows down further and it cancels it out. My sunroof doesnt currently work so maybe i need to address that and try the blow through effect
i should note, i only get the fumes over like 20 mph with the windows up or mostly up. lower speeds is just fine
– 96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
03-22-2019, 11:30 AM
The 2nd Gen I used to have and my 3rd both have the rear window deflectors and neither ever had a problem with exhaust in the cab.
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
03-22-2019, 01:13 PM
Real Name: Jerod
Real Name: Jerod
Embrace the carbon monoxide, I heard it's good for you.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
