Old 03-22-2019, 08:51 PM #1
monolithmotors monolithmotors is offline
monolithmotors is on a distinguished road
post apocalyptic build thread
Howdy folks,
The starting point is a 2001 Limited with 200K miles and a solid frame. Going for a overland/post apocalyptic vibe.
In addition to the bigger tires, a roof rack, rock sliders tubular front and rear bumpers, I want to upgrade to the 2014 and later headlights from a 5th gen 4runner. I did a quick mock up in Affinity Photo and I think it looks cool - I like the 'angry eyes' look of the headlights. Will need to graft on the front part of the Gen 5th gen hood to make headlights look right.
I mixed up and sprayed a few samples of flat black and flat white paint. Looking to get something like cement grey / battleship grey / the post apocalyptic world covered in ash grey - leaning towards the darker shades. And yes, there will be a big skull on the hood...
Will post more pics as things progress.
post apocalyptic build thread-4runner-front-mock-up-6lowq-jpg  post apocalyptic build thread-img_4890-2-jpg
monolithmotors is offline   Reply With QuoteReply With Quote
Old 03-23-2019, 01:47 AM #2
hounddogman's Avatar
hounddogman hounddogman is offline
Real Name: Levi
hounddogman is on a distinguished road
Real Name: Levi
OK , I actually like the post apocalyptic , darker shades of gray idea . But 5th gen headlights ? Is it time or money you have a excess of ?
96 SR5 5 speed, 4:88s with rear ARB , 255/85/R16s , some armor and lights
hounddogman is offline   Reply With QuoteReply With Quote
Old 03-23-2019, 02:07 AM #3
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
I saw a long travel 3rd with a newer tacoma front end on ig which looked legit.
just incase @rednose1 is on here
ill save any opinions until after its done, Im all for something different when executed well
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 03-23-2019, 03:21 PM #4
4Reak Show's Avatar
4Reak Show's Avatar
Sounds about how my 2nd gen has become. Don't underestimate the power of some custom TRD quarter panel decals
And matching custom door panel patches ($5 per on eBay, and the driver's door one actually covers up a damaged area of the door panel)
Then there's also the "zombie lights" and "apocolypse light" switches on eBay as well. A bit cheesy but might as well go all in.
The whole end-of-the-world vibe is a slick slope so be ready to go down a rabbit hole!
Old 04-07-2019, 08:07 PM #5
Thanks for all the comments. Bought some used 5th gen headlights off ebay and a cheapie aftermarket hood - I am in for about $450 on that which is not bad compared to the other costs in the build. The time to make the headlight mod look good may be prove to be unreasonable - we'll see soon...
@4Rreak Show - awesome sticker - agree on slick slope with this look - will aim for a clean look initially. This build is for my sister in law, Marilyn, so she can add more details over time...
I did make some progress over the last two weekends. Bought a Trail Gear Rock Defense bumper for a 95-04 Taco. It fits the 4Runner with a few mods - needed to break out the plasma cutter, angle grinder, and the sledge hammer (perhaps my fav tool) to get the bumper support on. I had to trim down the plates on the end of the frame rails and notch the TG bumper support for the AC line and then run a longer ground wire from the frame to the body. The TG bumper support was too narrow to fit about the flanges outboard of the front body mounts - I stretched the support a bit with a bottle jack and some round bar and then hammered her home once she was close to fitting. I put a primer coat and then settled on the apocalyptic grey shade for the truck and sprayed that on the new parts. Took about 2x the time I expected.
post apocalyptic build thread-img_5001-2-jpg  post apocalyptic build thread-img_5007-2-jpg
Old 05-04-2019, 08:08 PM #6
Making steady progress. I bought a Rola roof rack and welded the two halves together and cut down the supplied brackets and welded those on to make it low profile mount directly to factory rails without using the stock cross bars. I sanded down the flaking clearcoat off the roof and painted it. I purposefully made a few rust spots on the roof - there will be more on hood too.
Then I moved on to the suspension rebuild. I just finished the rear. Keeping stock height, I did the OME 60073 shocks with the softer valving, WhiteLine UCA and LCA poly bushings and Prothane sway bar bushings (end links look ok). I am amazed how much stuff of this I could get from Amazon. I bent up a C clamp pretty good pressing the upper arm bushing. So, I improvised a press from my Harbor Freight tubing bender to push the rest of the old bushings out. On the lower arms, I used a saws all on the metal part and pried that out with big screwdriver. Not pretty, but effective. Took me two full days...
post apocalyptic build thread-img_5014s-jpg  post apocalyptic build thread-img_5033s-2-jpg  post apocalyptic build thread-img_5056s-jpg  post apocalyptic build thread-img_5058s-2-jpg
Old 05-12-2019, 09:54 PM #7
Paint
I took a few days to prep and paint the rest of rig. First up was removing the rear bumper, running boards and the Limited cladding on the doors. I just cut along transition between the fender flare and the cladding on the rear door. I will make a piece out of steel to fill in the gap that is left between the flare and the door later. I think it looks much better without the cladding - I did keep the Limited trim over the rocker panels - I think that looks cool and blends into the fender flares. Then I sanded down all the failing clearcoat from the hood and removed the side mirrors and a bunch of the trim before paint. I decided to leave the flares on for the painting so the pads between the flares and body would get painted the same color - it looks good, hope it holds up well. I also got some .5" aluminum foil circles and covered the holes in the doors. They arrived halfway thru the paint job, so there is paint both over and under them. Turned out pretty good for a backyard paint job. Front suspension rebuild next...
post apocalyptic build thread-img_5064-s-jpg  post apocalyptic build thread-img_5065-s-jpg  post apocalyptic build thread-img_5074-s-jpg  post apocalyptic build thread-img_5078-2-s-jpg
Old 05-12-2019, 11:41 PM #8
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Immortan Joe approves this thread
post apocalyptic build thread-653feccf926e9f3f2edb49011bb75c26e70300355599924ef6196f43c4a09c2c-jpg
Old 05-13-2019, 03:57 AM #9
Kotletachka Kotletachka is offline
Kotletachka is on a distinguished road
subbing for headlights!
Kotletachka is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 09:45 PM #10
More Progress
After doing the rear suspension bushings in my driveway, I asked my mechanic friend to tackle the front control bushings and ball joints - did uppers and lower of everything because the front end felt pretty loose over bumps. It took him about a week and half with a bunch of interruptions - the upper and lower control arm bolts were really rusted in - glad I got help. The good news the truck is transformed - the ride is so much better. There is poly everywhere including the sway bar bushings.
Next I replaced the alternator with a high output one and did the big 3 wiring update per Performing the "Big 3" Wiring Ugrade on a 3rd Gen T4R - A How To - from BigFishAllDay. I flushed the power steering reservoir out, cleaned the screen and flushed the power steering system by turning the steering wheel with the engine off - seemed to work well. I cut the o-ring at the bottom of the reservoir when I put it back on. I got a new one from the local stealership so that is all good now. I replaced the radiator with a denso part from Amazon - wanting to avoid the dreaded pink milshake. It did not fit great, I had to elongate some holes in the core support to get the bolts to line up. When I was finishing filling it up, I noticed the nipple going to the overflow bottle was broken off - crap. So I ordered another one which fit much better and had all its appendages intact. I used to get upset when stuff goes wrong - not so much anymore - life would be boring if everything was easy...
Speaking of not easy - next up was the starter motor rebuild. I decided on the starter out the fenderwell method and followed Timmy The Toolman's excellent video YouTube Every bolt was rusty and hard to break away, but the worst was the transmission dipstick tube. The two parts were rusted together hard. I wound up getting a MAP gas torch on it and then vice grips to twist and finally got it apart - needed another o-ring from the stealership after that. I have the starter brushes replaced and am waiting for a new plunger before I put that back together.
So then I had some time to start looking at how to install the 5th gen headlights. I cut the hood down and mocked up how to put it together. The hood is a couple inches too wide, so I figured I could cut a section out of the center without creating much of a peak when I weld the two halves back together, but the headlights themselves require hacking out a bunch of the fenders and radiator core support. After looking at the work involved, I am going to skip it for this build. Kind of a bummer, but I have the parts and am going to put these lights and hood section on some future build - they are so cool looking. I am on a deadline for this truck - leaving to drive her to Oregon in less than a week and there is still a bunch to do...
My other fabrication task was to make a new rear bumper. I looked at some options to buy, but they were pricey so I figured I would do something low buck. After agonizing about it for a few days, I decided to keep the low hanging bumper hitch. Because the low hanging spare tire is just a bad as the hitch and I was not up for relocating the spare to any of the possible options (inside, swing out or on top or freeballing with no spare). So then I mocked up some tubular tubular designs and I did not like the gaps they would leave to the hatch area. Then I stuck the center section old bumper back on and I kind of liked it. I trimmed the ends down of the center section and cut some pieces out of the side extensions to clean up the exposed ends and I cut down the plastic tread part which will be nice for Ava (dog) for jumping in and out. Welded that up today and just need some paint to finish.
And I mocked up the driving lights. I went with some big ass Hella Rallye 4000s. Then need to be mounted about 6" above the winch mount in the front bumper - bracket fab coming...
post apocalyptic build thread-img_5096-2-jpg  post apocalyptic build thread-img_5131-2-jpg  post apocalyptic build thread-img_5141-2-jpg  post apocalyptic build thread-img_5146-2-jpg  post apocalyptic build thread-img_5152-2-jpg  post apocalyptic build thread-img_5162-2-jpg
Old 06-05-2019, 11:39 PM #11
Ryance39 Ryance39 is offline
Real Name: Ryan
Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about
Real Name: Ryan
This is definitely getting interesting. I was excited to see the 5th gen headlights going on. Hope to see that in the future.
Continuing to follow this as it comes together. Props for making it your own and doing something’s different than most.
1962 Mercedes 220S Heckflosse
1999 Toyota 4runner Limited - Supercharged
2001 BMW M5
1999 BMW Z3M Roadster
2020 Super White ORP
Ryance39 is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 11:25 PM #12
ready to drive to Oregon
Been busy this last week finishing and redoing some things. The foil tape circles covering the holes from the Limited cladding were a bit too visible, so I painted on some aerosol can bed liner and then repainted that area grey. I also filled in the gap in the fender flare on the rear door with some sheet aluminium and big rivets - also put the bedliner over that to help it blend in. And I got a set F5 16x8 -25mm in matte gunmetal from SCS and Falken Wildpeaks 265/75R16. The tires are right out to the edge of the fender flares with that offset, so that worked out well alhtough I did have to trim the front fender flare and fender liner and bash the sheet metal seam back pretty far with a sledgehammer to get rid of the interference when turning all the way. I modified some motorcycle turn signals from Amazon to fit the 4runner bulb socket and JB welded them together - nice to keep the stock bulb so the blinkers work properly. And I am nearly done the driving light bracket - started with some 2x6 box steel. My last mod today was a stainless steel cat back system (and fixing leak at the flange between the cats) at a local shop. They screwed up the rear O2 sensor location and the wire was pulled tight. Threw the check engine and VSC lights on my way home - code is for the downstream O2 heater - nice. I am mounting all the lights tomorrow morning, heading back to the exhaust shop to relocate the bung and then heading west. I ordered a denso replacement sensor and am having it shipped to Oregon.
post apocalyptic build thread-img_5167-4-jpg  post apocalyptic build thread-img_5171-2-jpg  post apocalyptic build thread-img_5178-2-jpg  post apocalyptic build thread-img_5170-2-jpg  post apocalyptic build thread-img_5174-2-jpg  post apocalyptic build thread-img_5177-2-jpg
Old 06-14-2019, 09:09 AM #13
On the road
In Saint Cloud Minnesota this morning. The 4Runner is running well. The shop relocated the rear O2 sensor before I left, but the wire is broken, so I have a bunch of dash lights on. I had a denso sensor shipped to Oregon, so I will install that and a handful of other projects when I get there. Some 55W H1 bulbs for the driving lights are heading to Oregon - I am using the stock relay and wiring and just spliced the hella wiring connector on, so I don't want to run too much current through that circuit. Installed the turn signals and driving lights yesterday morning just before hitting the road. I had to paint the hella light covers - there will be no corporate logos after the apocalypse. At the rear, I got the painted bumper on, painted and installed the rear delfector, and cut down some mud flaps and put them on - the fender law in Oregon says they must be within 27" of the pavement - I was at about 31 and now the mud flaps are close to 25" above the ground. The Gobi ladder did not make it in time and is shipping to Oregon. And the big Mad Max skull decal arrived from Russia just before I left - will get that on the hood in Oregon.
post apocalyptic build thread-img_5190-3-jpg  post apocalyptic build thread-img_5201-4-jpg  post apocalyptic build thread-img_5215-2-jpg  post apocalyptic build thread-img_5228-2-jpg
Old 06-14-2019, 11:40 AM #14
Joelzy's Avatar
Joelzy's Avatar
i would have trouble going to the new headlights and hood from here, it looks really good as it sits
–02 bmw 540i6
–19 Highlander SE
Old 06-14-2019, 08:05 PM #15
ransack ransack is offline
Real Name: J
ransack is on a distinguished road
Real Name: J
keep it going man, subscribed!
ransack is offline   Reply With QuoteReply With Quote
apocalyptic , gen , grey , headlights , post
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
The Hell Is This? Can't Post Photos On My Build Thread cbielat General Discussions 8 08-17-2015 11:05 PM
Can't post in my build thread?? BenK General Discussions 8 03-18-2014 10:39 AM
Where would I post my build thread? 04LTtacoma Off Topic 5 05-25-2011 10:53 AM
