Old 03-25-2019, 03:06 PM #16
Dented Dented is offline
Dented is on a distinguished road
I take it this isn't a quick spritz of WD-40 can fix like it did for the exterior locks? Asking because mine is sometimes stiff.
Dented is offline   Reply With QuoteReply With Quote
Old 03-26-2019, 12:30 AM #17
Wasatch Rebel Wasatch Rebel is offline
Wasatch Rebel is on a distinguished road
Originally Posted by 96RedRunner View Post
@Wasatch Rebel , I have experienced what you describe with both my Runners 96Red 374k mi, 01 200k mi both still using original ignition lock. After trying WD40, graphite etc new key's cut from old. Once I had keys cut from VIN, Locksmith recommended 3 in 1 Dry Lock Lube which I used locks are smooth as butter.
Thanks!
Wasatch Rebel is offline   Reply With QuoteReply With Quote
Old 03-26-2019, 12:31 AM #18
No. I tried that.
Old 03-26-2019, 02:29 AM #19
Originally Posted by Wasatch Rebel View Post
No. I tried that.
Pull out the lock barrel with your old key while it still works and get a new key cut off the key code.
Spray the barrel with brake cleaner and put the new key in and out until all the plates operate easy and crisply without sticking. Using lock lube after no more dirt comes out of the lock with brake cleaner. I sprayed in the key hole to flood it and then ran my new key in and out.
If you can’t get this to happen then it’s already out and you can get a new ignition lock and either install it with the key they give you or get the new lock keyed to your new key you just got cut. I’ve always been able to get a new cut key to work. Two 4Runners and 2 S Series Saturn’s.
Old 03-27-2019, 01:56 PM #20
jaszmine9 jaszmine9 is offline
Real Name: Jaz
jaszmine9 is on a distinguished road
Real Name: Jaz
this happened to me also and turned out it was just my key being worn down also my steering wheel was locked as well
jaszmine9 is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 04:13 PM #21
I_bRAD I_bRAD is offline
I_bRAD is on a distinguished road
Originally Posted by Mtn. Runner View Post
If you want to keep your keys the same you can remove your ignition lock cylinder and take it to a locksmith and have the tumblers redone.
You can also just file the tumblers so either key works. Not the best scenario if you live where theft is an issue though. (although 4runners would be ridiculously easy to steal regardless)
1997 4Runner SR5 4X4 5MT elocker.
2005 Echo Hatchback 5MT.
1990 Volvo 740 Turbo sedan.
1991 Volvo 740 wagon.
2000 Mercedes E55 sedan.
I_bRAD is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 07:08 PM #22
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
can a locksmith cut from vin ?
Will a internet dealer cut from vin without proof you own the 4runner ?
As far as dealer,,,my local dealer wont price match internet... so I only use them when I absolutely have to or its nckle and dime and I don't want aftermarket..Id rather wait a few days to save 20% or more esp when most of my part orders lately go over 300..if I order a bunch of parts ( which I do need to do soon) will the internet dealer cut a key too ?
my ignition sticks off and on and I know my keys are well worn and copies made from old original I have , and those were made when the rig was about 15 years old when I bought it, now 19.. wow....in 2 years my 4runner will be old enough to order a beer
Old 03-27-2019, 09:18 PM #23
GangsterOfLove's Avatar
GangsterOfLove GangsterOfLove is offline
Real Name: Steve
GangsterOfLove is on a distinguished road
Real Name: Steve
I replaced the ignition lock with a new Toyota branded part I got on eBay. Used a YouTube video to figure out how to do it. 15 minutes, $65.
Now to attack the rear window switch.
A 2wd 3RZ boomer in a 4wd 5VZ millennial world.
GangsterOfLove is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 09:47 PM #24
bigcap76's Avatar
bigcap76 bigcap76 is offline
Real Name: Chris
bigcap76 is on a distinguished road
bigcap76's Avatar
Real Name: Chris
I use a lube called houdini. Its made for locks and works great.
bigcap76 is offline   Reply With QuoteReply With Quote
ignition , key , steering , turn , turns
Ignition Key won't turn!! ToyDiehard 4th Gen T4Rs 27 11-11-2021 10:57 PM
My key won't turn in the ignition Tanner Maintenance/Detailing 18 02-05-2020 01:33 PM
Ignition won't allow key to turn? mickeyt 3rd gen T4Rs 12 12-09-2017 01:58 PM
All of sudden, ignition won't let me turn the key all the way kolelt 3rd gen T4Rs 14 08-26-2017 04:00 PM
Ignition Key Will Not Turn Steve340 3rd gen T4Rs 7 01-02-2013 09:54 AM
