Does anyone know whether or not whiteline LCA bushings need to be re-lubed or if popping is normal?
At low speed and turning the wheels, I started getting a very loud popping noise and was able to have my wife drive around while I checked out the suspension from outside. I watched the lower control arm bind, then pop free.
I replaced the lower control arms and bushings in October and they just started popping this month. Cam adjusters are also new; SPC.
I removed the shock, end link, and LBJ from the LCA and it swings, but it’s rather tight/stiff. I couldn’t get it to pop or bind manually.
I lubed them when I installed them and spraying WD-40 silicone lubricant has helped some, but it still pops.
Any ideas??
