Old 03-26-2019, 11:04 PM #16
giguchan's Avatar
giguchan giguchan is offline
giguchan will become famous soon enough
giguchan's Avatar
Thanks for all of the helpful replies... and the Avatar? I wish i knew who she was..I'm sure she's married already. I've had that photo for ages....
The advisor quoted what the tech told him. I had to call back because I too that that description was a tad vague. in addition to the Rack leaking there was excessive play in the Tie rod -I just assumed that the 2 were related causing the main problem..
The good news is that i passed the NYS emissions.
Since i took her off the lot brand new in 97 this will be the biggest repair.. she's never left me stranded... And to make matters worse my backup shop(who did my brake upgrade) closed up or moved.. thats where i was going to go for a 2nd opinion.
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
giguchan is offline   Reply With QuoteReply With Quote
Old 03-26-2019, 11:35 PM #17
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
Nice rack... But it's time for a new one.
But the Toyota steering rack from Camelback Toyota ONLINE PARTS (those two words are super important) and get new outer tie rods because I don't think they come with the Toyota rack. You'll be looking at $700 plus the cost of the TREs so probably $900-ish. But the good news is Camelback does free shipping and they don't charge tax.
Replacing the rack and TREs is not that hard. It is probably 3 hrs work. You should be able to find an independent shop to do this for $300 in labor costs only.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 12:24 AM #18
giguchan's Avatar
giguchan's Avatar
Hey Brian,
Thanks for chiming in there.. I didn't ask if the Tie Rod ends came with the rack from the dealer... knowing me i'll bet they dont.
I'll have to hunt for another shop. There's an off road shop close by i'll inquire about them.
Currently 194K
Cheers
Old 03-27-2019, 07:45 AM #19
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
I was also at inspection fail this month due to rack. Here's my invoice from curious Mcgeorge. Ordered oem rack which includes inner tie rod ends, I also ordered the outer tie rod ends, which you should obviously do at same time.
I ended up needing both hoses also, which you can get from them.
The rack bushings I ordered Energy Suspension, They were like around $30.
Steering is much better, nice and tight.
Steering rack  leak.. my turn..00 bill-img_1179-jpg
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 08:25 AM #20
bigcap76's Avatar
bigcap76 bigcap76 is offline
Real Name: Chris
bigcap76 is on a distinguished road
bigcap76's Avatar
Real Name: Chris
Originally Posted by giguchan View Post
Well it's finally my turn. I failed NYS inspection.. I had a bad feeling about this time... The Dealer told me thats what it's going to cost to get it all sorted out. I thought it was going to be a PS pump.. Looking for alternatives. i'm told that the OEM Rack is really the best way to go on this.
I was told that there was excessive play in the steering and power steering leak. I think i made the mistake of mentioning it first because then they had something to zero in on.. Not that i could've hidden that problem.
I am just venting... I dont need this right now..
I actually just replaced mine and it wasn't too bad. I got my rack from camelback toyota I think it was $550 and I also put on new outer tie rods at the same time. The hardest part was the high pressure line. I couldnt get it loose so I ended up cutting it and getting a new aftermarket line for $75. Timmy the toolman on youtube has a great video that will show you how to do it. Good luck!
bigcap76 is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 09:48 AM #21
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
Just got mine from McGeorge. The cheapest one you'll find, btw.
I got outer tie rods as well, as you'd be crazy not to replace them at the same time.
Also, hate to say it, but you're almost in a position where you need to get the high pressure hose and return line as well. It's a 50/50 shot when you get in there that you'll need 'em.
The lines are not cheap from Toyota. ($375ish?)
All part of our trucks aging, my friend! Sorry to hear this is coming at a bad time
BTW, an independent shop should charge you about 4hrs labor on this job if you go that route. Or, you can use Timmy The Toolman's Youtube video to do it yourself
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 10:05 AM #22
Mudeprived Mudeprived is offline
Mudeprived is on a distinguished road
Not sure about the four hours of labor. My shop did it in two and it was just about $160 and we reused the hoses. It is also a rust belt truck.
1999 Limited
265/75/16 AT51's
Bilstein 4600
Mudeprived is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 10:25 AM #23
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Originally Posted by 3bears View Post
camelback advertises free shipping....read the small print...the rack will not qualify due to size
I like camelback....use them a lot...but don't count on free shipping if heavy or long/big
I got free shipping on my radiator, it was light but was a pretty big box.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 10:37 AM #24
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
That’s where I got mine and it was the cheapest. I also ended up needing a rag joint. Which was another $100. But as far as tools. They are basic tools. Only special tool I recommend is possibly flare wrench and a torch.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 11:04 AM #25
silver4est silver4est is offline
silver4est is on a distinguished road
I paid 630 shipped for rack and outer tie rods from Graham Toyota in Ohio
I didn’t have any rust issues underneath, took about 1.5 hours to change out and bleed/add fluid. A shop should be able to do it under 2 hours
Steering Gear & Linkage for 2001 Toyota 4Runner | Graham Toyota Parts
silver4est is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 11:07 AM #26
Ahh- I should have re-phrased "no more than 4hrs". Anything additional I think would be excessive, but it all depends on the condition of the truck.
Forgot to mention for OP- he'll also need an alignment
Old 03-27-2019, 11:54 AM #27
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Originally Posted by 214K_02T4R View Post
Following this discussion as my steering rack is showing a fluid leak also, and there are some good suggestions here to check other things leaking or being loose as well. Keep 'em coming!
Remove one of the boots and see if it's filled with fluid or just on the outside. A common leak point for racks in the inner seals.
326WHP 347TQ
Old 03-27-2019, 12:06 PM #28
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
sometimes it is hit and miss, but I know when I ordered my springs, I had to pay shipping, yet on some packages over their limits I have not. I was just thrwoing it out as a warning.... people should confirm shipping charges when comparing if a good deal or not
this is their ( Camelback) website policy
Free Shipping: We will ship one 36" x 24" x 12" package or smaller for free (must meet the minimum purchase of $150.00). You will be responsible for additional,larger package fees or hazardous material fees. Offer is limited to the continental United States and does not include Alaska or Hawaii. Excludes oversized items. An example of oversized is but not limited to any body parts, bumpers, bumper cover, fender, hood, wheel liner, engines, wheels, transmissions, or any other oversized item larger than 36" x 24" x 12" or 25lbs and over. An example of hazardous materials would be an airbag or a seatbelt pre-tensioner. Free shipping is sent out as FedEx Ground shipping.
Old 03-28-2019, 02:11 AM #29
giguchan's Avatar
giguchan's Avatar
Hey there!
Thanks for all of the information.... I was going to replace all of that too.. incl the hoses. To tell you the truth I never noticed any steering degradation . just the loud Noise.. when the wheel turned to either side.. did u do do an alignment at the end?
Thanks again!
Currently 194K
Cheers
Old 03-28-2019, 02:15 AM #30
giguchan's Avatar
giguchan's Avatar
[QUOTE=Mudeprived;3259885]Not sure about the four hours of labor. My shop did it in two and it was just about $160 and we reused the hoses. It is also a rust belt truck.[/QUOT
So... $80 hr labor.... add another $40 here in NY... last time i looked.
Currently 194K
Cheers
leak , rack , steering , told , turn
Steering Rack Leak blaze17 3rd gen T4Rs 2 05-19-2017 08:02 AM
Power steering leak/steering rack SRQ-Runner 3rd gen T4Rs 1 10-25-2014 02:13 PM
Steering Rack Leak Aelfwine 3rd gen T4Rs 4 07-12-2014 09:39 PM
Possible Steering Rack Leak???? ryankmasuda 3rd gen T4Rs 5 01-30-2012 01:48 AM
Leak on the Steering Rack CT4R 3rd gen T4Rs 3 11-08-2011 06:04 PM
