Old 03-28-2019, 02:18 AM #31
giguchan's Avatar
giguchan giguchan is offline
giguchan is on a distinguished road
giguchan's Avatar
Originally Posted by WeakSauz View Post
Just got mine from McGeorge. The cheapest one you'll find, btw.
I got outer tie rods as well, as you'd be crazy not to replace them at the same time.
Also, hate to say it, but you're almost in a position where you need to get the high pressure hose and return line as well. It's a 50/50 shot when you get in there that you'll need 'em.
The lines are not cheap from Toyota. ($375ish?)
All part of our trucks aging, my friend! Sorry to hear this is coming at a bad time
BTW, an independent shop should charge you about 4hrs labor on this job if you go that route. Or, you can use Timmy The Toolman's Youtube video to do it yourself
Thanks Man.... Lines are $375? damn....
TRD Exhaust, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade,LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 184K
Cheers
giguchan is offline   Reply With QuoteReply With Quote
Old 03-28-2019, 07:36 AM #32
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Originally Posted by giguchan View Post
Hey there!
Thanks for all of the information.... I was going to replace all of that too.. incl the hoses. To tell you the truth I never noticed any steering degradation . just the loud Noise.. when the wheel turned to either side.. did u do do an alignment at the end?
Thanks again!
Yes I did an alignment. If you count the threads on the outer tie rods before you take them off and match with the new ones you'll probably be pretty close to matching the prior alignment.
I didn't notice any steering slack before either, but once everything was replaced I did notice it felt much better. Also on hard braking it did pull to the right a tad even though it went down the road straight. My rig has well over 300K with a lot of original parts, so I'm not opposed to putting some fresh oem stuff in it for hitting the 600K mark.
On the loud noise on your current rack, make sure fluid is fresh. A couple months ago mine was making a really loud noise, I thought it was the pump. I changed the fluid, it went completely quiet after that.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 03-28-2019, 08:49 AM #33
giguchan's Avatar
giguchan's Avatar
Wow!
Our trucks did pretty much the same thing... I was pretty embarrassed about the fluid level. I thought it was the Pump as well... then it was suggested on here that i check the fluid. I thought it weird because there wasn't and giant spots on the driveway.. I found the level was low...
I added(not changed at this time) fluid and thought this was it. Believe it or not when i applied Brake the wheel did jerk to the right. I didn't think anything of it... thought thought it was out of alignment.
It will be sorted out shortly..
Thanks for the useful information...
Currently 184K
Cheers
Old 06-14-2019, 12:18 AM #34
giguchan's Avatar
giguchan's Avatar
Sorry i'm so late with an update..
All,
Thanks for all of the suggestions.... I had ALL the work done and this is the result.... No fluid in the driveway No strange noises and above all Peace of mind... which is worth it at ANY price. I'm good for the foreseeable future. There were some unexpected issues that added a lot on the bill.. some of the Lines need to be replaced(pressure/return) which were rusted beyond repair. Until the next crisis....
Again thanks for the help in this matter.
Steering rack  leak.. my turn..00 bill-scan047-jpg  Steering rack  leak.. my turn..00 bill-scan048-jpg  Steering rack  leak.. my turn..00 bill-scan051-jpg  Steering rack  leak.. my turn..00 bill-scan050-jpg
Currently 184K
Cheers
Old 06-14-2019, 12:28 AM #35
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is a name known to all gamefreakgc is a name known to all gamefreakgc is a name known to all gamefreakgc is a name known to all gamefreakgc is a name known to all gamefreakgc is a name known to all
Real Name: Jerod
Something tells me you will be keeping this vehicle for a looong time! That's a chunk of change you laid down. Here's to another 177K!
'98 4Runner SR5 - 4x4 5VZ-FE Supercharged - 222k miles, JDM engine @ 221k
AEM F/IC 6 Piggyback, 2.1" pulley at 11 PSI, Go-Fast Parts
Old 06-14-2019, 12:44 AM #36
giguchan's Avatar
giguchan's Avatar
I really like the truck.... to be fair... i'm not in a position to buy anything else so it was either spend the money or not. I'm hoping to get another 2+ years out of it.. The truck does not owe me dime one.... it's never left me stranded and it's only embarrassed me once when the wiper motor died DURING A RAIN STORM while on a first date(luckily she had a sense of humor) All it asks of me is to take care of it. I think the next thing might be less aggressive rubber..
Currently 184K
Cheers
Old 06-14-2019, 10:26 AM #37
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of
mtbtim's Avatar
Real Name: Tim
Well, if you're happy with paying that bill, that's good because most people on this forum would be shitting their pants seeing a bill like that. They charged you $900 to replace a freaking steering rack. That is highway robbery. And of course they incredibly overcharged you for all the parts. They overcharged at least $300 just for the steering rack. $250 labor to do front brakes? Unbelievable. $65 labor to flush the coolant - They opened the drain plug on the bottom of the radiator and refilled it. $135 labor to replace a thermostat - it takes maybe 15 minutes to remove the lower radiator hose and the (3) nuts that hold the water neck onto the water pump. I think the AC service was close to being fair because it does take special tools to do this right.
Wrenching isn't for everyone and I do realize there's the situation where people live in apartments or condos with no garage space to work in. But, when you have the space and time to do your own wrenching, you can save yourself an incredible amount of money. Wrenching isn't always easy and you're bound to run into snags and get frustrated but in the end it's worth it in my opinion. You literally could have saved yourself at least $2000 doing your own work.
Old 06-14-2019, 11:29 AM #38
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
No kidding Tim, I'd probably sell my 4R if the steering leak cost me 3k to fix. I'm a big fan of OEM toyota parts but I ended up buying some sonsong power steering lines when my started leaking, no way I was paying 600+ dollars on some lines.
I think something important to realize is that the return on value on these 4Rs are slightly better than average now but its highly unlikely it'll ever be a collectible anytime (maybe 100 years?) so I'd be careful to invest a lot of money into one.
APhelps is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 06:49 PM #39
giguchan's Avatar
giguchan's Avatar
Guys...
I typed up almost a paragraph on why i went the route i did... but for some reason when i went to submit the reply i was signed out...
Basically, I always use OEM parts and the local places were not too much cheaper."I have to bring in my Toyota guy" " I go to the same school as the Toyota guys so why should i charge less?". That kinda thing.
I also dont have the space(being in a townhouse) or time to do repairs... Pop the hood and you'll be written up.. The guy next door was busted for having a flat tire being in the driveway for a week.
I think i made the right decision. This way i have Toyota to yell at if i have leak or Prob #1
I do thank everyone who replied to my OP.
Currently 184K
Cheers
Old 06-19-2019, 09:18 PM #40
giguchan's Avatar
giguchan's Avatar
** In addition to the all fun.....
I get a call from the service advisor.... they forgot to add the towing fee onto the bill Since i had the Runner towed 3.5 miles...$110
I've had the truck towed there a few times since 97 NEVER had they ever forgotten before.. I just had to laugh...
Currently 184K
Cheers
Old 06-19-2019, 11:20 PM #41
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light
T4R2014's Avatar
LOL I love reading all these posts regarding parts and labor prices. From a DIY perspective totally logical. That said if some of you guys ran an auto repair business on that logic you wouldn't be in business for long. Time has no refund.
Old 06-20-2019, 12:21 AM #42
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Well, I guess it depends what you think your time is worth. If you make big money and have very limited free time, I could see paying high labor rates and overpaying for parts. But, if you don't have money burning a hole in your pocket and you're not short on time, why not turn a wrench and be smart by ordering your parts from an online seller.
The thing is, I doubt any of us commenting on this thread are looking to open a shop. We're commenting from our perspective as DIYers not looking to get bent over at a dealership. I don't give a shit that a dealership or shop has high operation costs. My local dealer's labor rate is $200/hour. I don't make anywhere close to $200 hour so it's a no-brainer for me to the avoid the dealership service department like the plague. Maybe the mechanics and other employees at these dealerships aren't making much money but I can guarantee the folks at the top are probably rolling in doe.
To each his own. People like me enjoy doing their own wrenching more than just for the money savings. The learning, the challenge, the sense of accomplishment, and the knowledge the job was done right are other reasons why I choose do do my own wrenching.
Old 06-20-2019, 02:34 AM #43
giguchan's Avatar
giguchan's Avatar
Hey Gang,
Yeah me too... I love hearing all about labor/parts costs and how they Vary across the country.. and even the world... after you do the calculations and exchange rate it's Very interesting...
Currently 184K
Cheers
Old 06-20-2019, 01:50 PM #44
T4R2014's Avatar
T4R2014's Avatar
Lolol triggered. Hence why I said logical from a DIY perspective. If you are running a business you BET time is valuable. Unfortunately Elaine the middle aged 3rd gen owner isn't waiting 8 days for a steering rack to arrive from Camelback Toyota, so she will have to pay $834 that the cheapest dealer in the area will charge. And the book states that a steering rack job is over 4 hours despite guys on a forum being able to change it at the speed of an F1 pit crew. It's all true, but business is business. $2300 is definitely high but I guess to an original owner this isn't much after this many years.
Oh and keep truckin OP.
Old 06-20-2019, 02:48 PM #45
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
No Dude, not triggered. LOL back at ya buddy. I'm just stating my opinion that I don't care what a shop's operation costs are. It's no concern to me whether or not they can pay their light bill. My local dealer has a line of cars waiting to get into the service department everyday. At $200/hour, I know this dealership isn't hurting. What I'm here to tell people is if they have an interest at all in auto mechanics and have the time and space to do it, it's a worthwhile pursuit for more reasons than the money savings.
My 98 4runner is heavily modified now. I paid $6500 for it and since then put another 10k easily into it from the maintenance, repairs and modifications I've done to make it more off-road capable. I can't imagine what I would have invested into it if I paid someone to do all the work, probably at least another 10k. I don't know about you, but 10k is a pretty good chunk of change to do something with.
There's things I gladly pay someone else to do for me. I thought about tearing off and installing my own roof recently, but decided the amount of labor it was going to take was going to be more than I wanted to take on. Weeks of physical work out in the hot sun didn't sound so great to me so I parted with a lot of cash instead.
By the way, Camelback Toyota will usually get you your parts in 2-3 days.
leak , rack , steering , told , turn
Steering Rack Leak blaze17 3rd gen T4Rs 2 05-19-2017 08:02 AM
Power steering leak/steering rack SRQ-Runner 3rd gen T4Rs 1 10-25-2014 02:13 PM
Steering Rack Leak Aelfwine 3rd gen T4Rs 4 07-12-2014 09:39 PM
Possible Steering Rack Leak???? ryankmasuda 3rd gen T4Rs 5 01-30-2012 01:48 AM
Leak on the Steering Rack CT4R 3rd gen T4Rs 3 11-08-2011 06:04 PM
