03-26-2019, 01:26 PM
Steering rack leak.. my turn..$2300 bill
Well it's finally my turn. I failed NYS inspection.. I had a bad feeling about this time... The Dealer told me thats what it's going to cost to get it all sorted out. I thought it was going to be a PS pump.. Looking for alternatives. i'm told that the OEM Rack is really the best way to go on this.
I was told that there was excessive play in the steering and power steering leak. I think i made the mistake of mentioning it first because then they had something to zero in on.. Not that i could've hidden that problem.
I am just venting... I dont need this right now..
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
03-26-2019, 01:50 PM
Real Name: Jerod
Real Name: Jerod
Do it yourself. Toyota rack is the way to go, can be found for $600 online. There's not much to remove (sway bar and a few misc things) and can be done with hand tools and a hefty sized breaker bar for a couple of the large bolts. A standard floor jack with stands works fine.
You can replace other steering parts while you are at it but not necessary. Just go reeealllly slow and careful on the fluid lines and not mess up the threads. They strip really easily.
03-26-2019, 02:11 PM
Thanks for the reply...
I might have to hunt around for someone with those tools and the space to work in. I'm in a townhouse complex... not supposed to work on any cars here... The lady next door will report you for opening up the hood. I was able to install my lights though... she must have been outta town.. $600 isn't too bad.. The PN i have 4425035041
Thanks
Currently 194K
Cheers
03-26-2019, 02:18 PM
Or if you can't do it yourself find a quality independent shop to do the work (avoid the dealership like the plague). Buy the OEM rack and pay them to install it. Should be under a grand if you shop around (although I don't know what shops in NY charge, that would be fair price here in WI).
Another option if you want save some money is check out The Rack DR. $320 shipped to your door with a lifetime warranty. I've heard good things about them but OEM is obviously the best choice.
Toyota 4Runner Rack and Pinions
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
03-26-2019, 02:27 PM
I think i am going to go the OEM route. I got a price of $762... and i forgot to mention the Lines too.. This could not have come at a worse time.... but it's got to be done.
Thank you
Currently 194K
Cheers
03-26-2019, 03:18 PM
Real Name: Jerod
Real Name: Jerod
Thank you
Check out Camelback's prices, they have it for $557 with free shipping (double check your year and part number though): 1998 Toyota 4Runner Parts - Camelback Toyota Parts - Genuine OEM Parts - Free Shipping
03-26-2019, 03:27 PM
Thank you for the Link.... this is most helpful!
Currently 194K
Cheers
03-26-2019, 04:41 PM
Speaking of racks, nice avatar!
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
03-26-2019, 06:31 PM
Real Name: 3 Bears
Real Name: 3 Bears
agree
03-26-2019, 06:33 PM
Real Name: 3 Bears
Real Name: 3 Bears
Originally Posted by gamefreakgc
camelback advertises free shipping....read the small print...the rack will not qualify due to size
I like camelback....use them a lot...but don't count on free shipping if heavy or long/big
03-26-2019, 06:48 PM
The oem rack also comes with inner tie rod ends ($150 each) and boots.
Use TWpartz at camelback for a 3% discount.
Also, you're sure your rack is leaking and not engine oil dripping on the rack?
For sloppy steering new bushings and the rack guide might tighten everything up, I think parts will be around $100 for those.
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
03-26-2019, 07:11 PM
Partznet dot com out of Philly?
03-26-2019, 08:39 PM
Well, if he's got to spring for shipping, McGeorge lists that rack right at $500.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
03-26-2019, 10:29 PM
I don’t follow this at all. “Excessive play”? Could just be tie rods. Did they give you any more specific details?
As far as the leaks go, is the actual power steering fluid low? All kinds of grease and oil can end up on the steering rack.
2000 4Runner Sport - TRD&AEM SuperCharged
Solo Long Travel & KING 2.5 & bumps, 4th gen rear axle & KING 2.5 12's
F+R ARB's, 4.88 Yukon's, 295 KM3s
03-26-2019, 10:45 PM
Following this discussion as my steering rack is showing a fluid leak also, and there are some good suggestions here to check other things leaking or being loose as well. Keep 'em coming!
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
