Old 03-26-2019, 11:59 PM #1
calicojax's Avatar
calicojax calicojax is offline
calicojax is on a distinguished road
MY GARAGE
calicojax's Avatar
MY GARAGE
Mysterious Tranny gremlins
First, 99 supercharged 3.4 automatic
At highway speeds, it feels as though the transmission is slipping. The engine randomly jumps up three hundred rpm. It won't slip under any other conditions. And it won't slip more than three hundred rpm. I started to think the torque converter. Then I turned off the ECT power and it also turned off the overdrive. The overdrive button won't function. Turned on the ECT and overdrive stayed off until I restarted the engine. The overdrive button works unless you mess around with ect.
So now I'm leaning towards the PCM. Has anyone else had this happen. Or have I been hacked by the Russians?
calicojax is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 10:35 AM #2
alumarine alumarine is offline
alumarine is on a distinguished road
If it's jumping up and down by 300 rpm it sounds like your torque converter is unlocking and locking.
They will do that if there's inclines. If it does it too much it will heat up the fluid. What are your trans fluid temps? If you have an OBDII reader you can check.
Is this a new thing?
Any gear changes or bigger tires?
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 12:24 PM #3
gamefreakgc's Avatar
gamefreakgc gamefreakgc is online now
Real Name: Jerod
gamefreakgc is a jewel in the rough gamefreakgc is a jewel in the rough gamefreakgc is a jewel in the rough gamefreakgc is a jewel in the rough
Real Name: Jerod
Highway speeds as in you're driving steady and it slips around? Or you go on the gas and it'll float up 300 RPM and not produce any power?
Sounds like your transmission is on its way out. For us supercharged folks, the transmission likes to stay in very low RPM's since we don't need a ton of throttle to get power.
'98 4Runner SR5 - 4x4 5VZ-FE Supercharged - 222k miles, JDM engine @ 221k
AEM F/IC 6 Piggyback, 2.1" pulley at 11 PSI, Go-Fast Parts
gamefreakgc is online now   Reply With QuoteReply With Quote
Old 03-27-2019, 01:54 PM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck will become famous soon enough Bad Luck will become famous soon enough
Real Name: Patrick
I second torque converter locking/unlocking. OD switch and ect switch positions may be normal operation. If you describe what you have turned on and won't work a little more clearly for me then I would be able to compare with mine.
Old 03-27-2019, 03:41 PM #5
calicojax's Avatar
MY GARAGE
calicojax's Avatar
MY GARAGE
Cruising at 65mph, flat ground. Rpm is 2300 then randomly jumps to 2600 for a second or so. The trans temp is 155-160
With ect off... overdrive switches on and off with o/d button
With ect on.... overdrive switches on/off w/button ...until you switch off ect. Switching off ect also turns off o/d, regardless of overdrive button position. Switch ect back on and overdrive stays off regardless of o/d button position until I restart.
Today my elocker light came on by itself for a few minutes and then went out.
I'm leaning towards an electric short, bad PCM maybe
Old 03-27-2019, 05:55 PM #6
Real Name: Jerod
Real Name: Jerod
Yeah that's not normal operation. I can turn O/D on or off regardless of ECT being on or not. ECT should not turn off overdrive.
Is your e-locker original or was it spliced in? I'd look at wiring first and then see if swapping out the ECU solves the issue. I agree though, now that you describe it a bit more it sounds more like an electrical issue than a mechanical transmission issue. I thought at first you meant you'd go on the gas and the RPM's would rise but nothing would happen.
Old 03-28-2019, 08:56 AM #7
Real Name: Patrick
Real Name: Patrick
I understand now. Thanks for clarifying, and that's not normal operation for me.
Old 09-09-2019, 09:28 PM #8
calicojax's Avatar
MY GARAGE
calicojax's Avatar
MY GARAGE
Okay a little follow up. The surging at highway speed turned out to be a bad tps. How ever the ect button interfering with overdrive still has me stumped besides being trans. Related what does one have to do with the other?
Old 09-10-2019, 02:07 AM #9
Real Name: Jerod
Real Name: Jerod
The ECT Power button raises the RPM shift point by a few hundred under moderate throttle. Even higher under heavy throttle, so it very much affects the transmission operation. Now HOW it raises the shift points I'm not sure, I'm not very well versed in automatic transmission repairs. They are made of unicorns and pixie dust.
ect , engine , overdrive , slip , turned
Help me with some electrical gremlins pbcolt 5th gen T4Rs 7 01-30-2017 10:56 AM
***3rd gen ELECTRICAL GREMLINS PLEASE HELP*** Jzxrunner Problems & Warranty Issues 0 11-22-2016 08:37 PM
Mysterious Oil Light, Gremlins? alphamikefoxtrot 3rd gen T4Rs 8 02-20-2013 10:19 AM
Electrical gremlins grndmstrb Classic T4Rs 6 01-19-2011 03:46 PM
95 4runner gremlins rdracer66 Classic T4Rs 5 10-10-2009 11:50 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
