Old 06-13-2021, 08:09 PM #16
theo_venchy theo_venchy is offline
theo_venchy is on a distinguished road
Hey! I’m having issues with my 2000 t4r, just installed this 3” rough country lift. Came with front strut spacers rear shocks and springs, installed everything with no issues and aligned perfectly fine, I noticed a substantial amount of rake and hoped that it would settle over night, check this morning and saw it was sitting about the same height, any ideas on what’s wrong?
theo_venchy is offline   Reply With QuoteReply With Quote
Old 04-07-2022, 02:19 PM #17
YouFools YouFools is offline
YouFools is on a distinguished road
Purchased 3" RC Lift
I put the 3" lift on mine with Freedom Offroad UCA's. I'm having weird issues with the LCA and LBJ at a very strange angle. And my alignment cannot sit right (about +2 camber and caster at about 1.3). going to make a post about this soon and see if anyone has had this issue. Not sure if it's a lift problem, UCA problem, or install issue really.
YouFools is offline   Reply With QuoteReply With Quote
Old 04-07-2022, 11:58 PM #18
revox92's Avatar
revox92 revox92 is offline
revox92 is on a distinguished road
revox92's Avatar
Too bad to hear about the issue. My brother is looking to get them for his new 4Runner project. Guess it is better to go OME. He's selling his Wrangler after we finish installing the last mods and the soft tops from 4Wheelonline next week. Hope he can wait to have a better budget.
2004 Toyota 4Runner SR5 4WD Auto
revox92 is offline   Reply With QuoteReply With Quote
Old 04-13-2022, 08:35 PM #19
hillkid21 hillkid21 is offline
hillkid21 is on a distinguished road
I purchased the Rough Country 3” lift kit with the front struts & spacers as well as Rear shocks & springs. I also got the FREEDOM OFF-ROAD UCA’s that have the Upper ball join. These are supposed to correct the angles that change when this lift is installed…
I am having issues with my sway bar hitting my tie rod ends and I’ve just noticed a torn tie rod end boot. I got some spacers to drop the sway bar down a little but I think I need longer sway bar end links maybe?
Also I’m wondering if I need to get some different control arms perhaps longer?
Sort of different question. Changed most of my front end components during this process due to the high miles. 250,000mi made it hard to justify putting these things back on knowing that they were all in the well used range.
Anyways I replaced both front axles in this process and after nearly 1500miles of driving I’ve looked under there to re-assess things.
I have found the axles have a gap between the INBOARD JOINT TULIP and the differential. With the wheels off I can using only my hand strength, I am able to create some side to side movement of close to 1/4 inch of play there… I’m thinking, this is not up to factory specs. Any input to the questions I’ve brought up summarized below will be greatly appreciated.
Thanks for your time in helping me with these puzzlers
1) needing longer sway bar end links w suggested place to find them.
2) needing upgraded/ longer rear control arms w suggested place to find them
3) Front Cv axle situation.
hillkid21 is offline   Reply With QuoteReply With Quote
Old 04-15-2022, 04:40 PM #20
blairracd's Avatar
blairracd blairracd is offline
blairracd is on a distinguished road
blairracd's Avatar
Originally Posted by Mikeyt View Post
Wanted to do a OME all out lift but can't really afford it.
If you can't afford it, should you be spending the money at all? Just save up for a better lift.
Living and breathing and bleeding Toyota
https://imgur.com/a/KvwQdyO
RIP my ‘96.
blairracd is offline   Reply With QuoteReply With Quote
Old 04-17-2022, 11:09 AM #21
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
1)Look up Mike Studt on here. He makes some bomb proof sway links. Or you can buy my set I have from him (there his first gen production). I don't use my sways anymore.
2) If you're 2wd like OP just get rear control arms off a stock 4x4 4runner as they are longer than the 2wd ones. That will be your cheapest and likely to correct your driveline situation you may be experiencing post lift. If it doesn't or you're already a 4x4 then use Rokmen or OptOffroad for extendable rear arms. IF you aren't having driveline issues after the lift don't mess with rear arms as this starts to change your diff flange and driveline angles and will cause vibrations. SO if you don't know what you're doing and don't have issues...don't touchy.
3) there is the ability to move the CV's by hand to some degree. How much I can't recall as it depends on many factors... vehicle put together and on the ground, on jacks with wheels on, on jacks with wheels off, on jacks with suspension parts loosened...etc
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 04-17-2022, 03:30 PM #22
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Did you fully seat the CVs when installing them? If not you'd be leaking diff fluid...
There is some play in the inner joint/sleeve, the boot actually restricts excess play because the inside needs to move in and out freely. I don't run stock CVs but 1/4" total (1/8" per side, play) may not be excessive.
Yes you need extended sway bar endlinks if you lifted 3" front and back. You also need an extended rear brake hose.
You can move your front end links to the back and either buy 1st Gen rear endlinks to install up front or buy aftermarket extended, like Mike Studt's, Opt Offroad sells them for $190 a pair
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 10-19-2022, 04:04 PM #23
4meI4run4fun 4meI4run4fun is offline
4meI4run4fun is on a distinguished road
What didn't you like about the RC 3 inch suspension lift?
4meI4run4fun is offline   Reply With QuoteReply With Quote
front , gonna , lift , moog , strut
FJ Rough Country 6" lift ry_034Runner 4th Gen T4Rs 3 08-08-2016 09:22 PM
Rough country lift thoughts? 97ls340 3rd gen T4Rs 11 01-22-2014 06:20 PM
Rough Country 3" lift yota-runner 3rd gen T4Rs 7 08-19-2013 11:53 PM
Rough country 3" lift kit ???? WANTSUM411 Classic T4Rs 1 05-30-2013 09:21 PM
Rough Country 3" lift Sandspur 3rd gen T4Rs 2 05-17-2013 01:01 PM
