Old 09-21-2022, 12:09 PM #1
RobS10's Avatar
RobS10 RobS10 is offline
RobS10 has a spectacular aura about RobS10 has a spectacular aura about
RobS10's Avatar
Time for a transmission oil chance - question about brands of ATF
We have a '99 that just turned over 200K, and due for its 60K transmission oil change. I think the last time I did it I used Valvoline, but ended up with a few unused quarts of O'Reilly ATF from another vehicle. Is O'Reilly ATF a decent choice? It's the right type, and hate to dump unused ATF.
2022 Barcelona Red TRD ORP, KDSS, Moonroof
1999 4Runner SR5, bone stock, just turned over 200K
RobS10 is offline   Reply With QuoteReply With Quote
Old 09-21-2022, 12:12 PM #2
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
As long as it's Dexron III it will be fine.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 09-21-2022, 12:13 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Whatever transmission fluid you decide to use make sure it is Dexron III compatible. If it is backwards compatible to Dexron III then you can use it. I used Dexron VI in my auto 4Runner for the 3 years I owned it without any problems. I'm sure other people will recommend some other options that they have experience with.
Old 09-21-2022, 12:25 PM #4
RobS10's Avatar
RobS10's Avatar
Should be, but will definitely double check!
Old 09-21-2022, 01:14 PM #5
162435's Avatar
162435 162435 is offline
162435 will become famous soon enough
162435's Avatar
I know Toyota does not make its own transmission fluid, but that's all I've used over the years.
Complete fluid exchange every 100k miles, and a filter change around 400,000 miles simply because I was curious (the original looked fine). The truck now has 518,000 miles and shifts the same way it did when I bought it new.
Andreas
2001 SR5 4Runner 4WD, Dorado Gold, 546,XXX 1-owner miles
2002 4Runner, Dorado Gold, 226,XXX miles
1998 4Runner, Oxidized, 265,000 miles
2014 Audi A4 quattro, Monsoon Gray
1995 Porsche 993, Polar Silver
162435 is offline   Reply With QuoteReply With Quote
Old 09-21-2022, 01:20 PM #6
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I have been using Oreilly brand for my gear oil and ATF for a long time. I wouldn't worry about it. It meets the specs. Don't overthink it.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 09-21-2022, 01:27 PM #7
RobS10's Avatar
RobS10's Avatar
Andreas
518K miles?? Damn, good job, think yous takes the award for highest mile 4Runner I've run across .
Old 09-21-2022, 01:28 PM #8
RobS10's Avatar
RobS10's Avatar
Thanks, good to know .
Old 09-21-2022, 02:03 PM #9
162435's Avatar
162435's Avatar
Rob,
Yes sir. All maintenance/repairs/upgrades by me since day one. Just trying to get my money's worth.
Andreas
Old 09-21-2022, 04:14 PM #10
nissanh nissanh is offline
I think the valvoline ATF full synthetic is compatible with lots of ATF fluids. This is what the trans shop added into my 2000 LandCruiser transmission after it got its trans rebuilt.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 09-21-2022, 04:37 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
That's what I use valvoline that meets the dexron II and III specs. We have several threads in the 3rd gen section on this topic already. That's been discussed in great detail. Along with the tech bulletins from Toyota stating not to use T4 as isn't not a replacement for this particular transmission.
Old 09-21-2022, 04:58 PM #12
It’s got a drain plug. Use your flavor and do it often.
I do it every 30k miles. It’s always been 4qt removed so I don’t even bother checking the pain in the arse dipstick.
I’ve been using supertech from Walmart for years.
Old 09-21-2022, 06:51 PM #13
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Rob,
Andreas
I'm drooling over here... sheesh!
Sent from my SM-S908U using Tapatalk
Old 09-21-2022, 07:27 PM #14
162435's Avatar
162435's Avatar
Joe,
It has plenty of battle scars. But all original paint.
Andreas
Old 09-21-2022, 07:28 PM #15
RobS10's Avatar
RobS10's Avatar
Yes, the drain plug is very handy, unlike my old Dodge pickup where you have to drop the pan.
atf , oil , oreilly , time , transmission
1st Breakdown... Time to pull the transmission marcus clarkus 3rd gen T4Rs 6 08-27-2020 12:34 AM
Time for the weekly transmission drain/flush question gumbii Maintenance/Detailing 1 05-28-2018 11:39 PM
Question regarding seals/brands & timing belt yella 3rd gen T4Rs 22 03-03-2018 06:44 PM
Who else will be rebuilding their engine/transmission when it comes time? OldRigNewParts 3rd gen T4Rs 40 02-08-2018 03:40 PM
What happens when it is time for a new/rebuilt transmission? xcmountain80 3rd gen T4Rs 7 11-14-2012 04:11 PM
