Old 03-29-2019, 11:24 PM #16
PetesT4R PetesT4R is offline
Real Name: Greg
PetesT4R is on a distinguished road
Real Name: Greg
Originally Posted by nobb View Post
How are you using the access port to loosen the brake shoes? The adjuster only goes one way. Due to the mechanism, it would take quite a bit of force to get the adjuster wheel to turn the opposite direction.
From Mtbtim above: When I can't seem to get a drum off, I take out the rubber plug on the backing plate, use a small screwdriver to push the self-adjuster plate away from the star wheel adjuster and then turn the star wheel a bunch of times to back off the shoes from the drum. After that, the drum comes off easily.
PetesT4R is offline   Reply With QuoteReply With Quote
Old 03-29-2019, 11:31 PM #17
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
You have to use a screw driver to push the adjuster away from the “adjuster” then turn it the other way. Once you have the brakes apart. You will be able to see what I mean. It’s hard to explain it.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 03-30-2019, 12:46 AM #18
mtbtim's Avatar
mtbtim mtbtim is online now
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Check out this video @JZiggy , @infamousRNR and I made for replacing the shoes on our drum brakes. We describe how everything works with these drum brakes in great detail.
mtbtim is online now   Reply With QuoteReply With Quote
Old 03-30-2019, 01:22 PM #19
nobb nobb is offline
nobb is on a distinguished road
Thanks. I'm very familiar with the rear drum setup but it did not occur to me that you could stick another thin screwdriver in there to push out the adjuster plate (which is what clicks with the screw adjuster). It's quite tricky to do since there's not much space in there and very difficult to get lighting in there to see what you're doing. I'm guessing you have to mostly operate based on feeling.
nobb is offline   Reply With QuoteReply With Quote
Old 03-30-2019, 01:54 PM #20
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I know it's a long video but at a minimum watch from playtime 18:37-23:03. I give you some helpful hints on how to do this with the benefit of seeing everything with the drum off, so when you're doing it blindly, you'll know what you're feeling for.
Old 03-31-2019, 08:03 PM #21
WWRD99's Avatar
WWRD99 WWRD99 is offline
Real Name: Rich
WWRD99 will become famous soon enough
WWRD99's Avatar
Real Name: Rich
Originally Posted by mtbtim View Post
Have you considered that setting it tighter might be causing your brakes shoes to be dragging all the time and then the shoes wear down to where they should be and then you overtighten them again. Sounds like a potentially counterproductive strategy.
Absolutely they would drag with the machine work the shoes and drums come with out of the box...using an old tool that used to be common on shoe replacement, the new shoes have no low or high spots and are perfectly round...I don't know to many people that even know how to do machine work on shoes anymore...getting old!!...but I used to use it on every shoe replacement I did...it was hooked to an old AAmco lathe...the reason why they need tightened every once in a while is that the factory stuff won't let it stay there after it wears a bit...meaning it will go back to the high click count...plus I'm extremely hard on brakes...wear out a set in 15k easy...everything is a race car!!
Bought this 99 in 01 and haven't let it go since! Valve dropped at 195k so I rebuilt it with reman heads, new rings and one new piston...tough to find the correct numbered one but I did...still had the original hatch...I soaped it and did a light hatch to help the new rings seat...that was in 2015...since then I did a basic lift and put some VTX 18x9 inch wheels with 0 offset...Ive grounded the rear locker, ran a diff extension into the gas cap, did the hood piston mod...GM Alternator...13WL brakes..30 year ASE Master Tech with more tools than sense, so I quit everything and work at home now.
WWRD99 is offline   Reply With QuoteReply With Quote
Old 12-02-2019, 10:56 PM #22
03V8Limited4Runner 03V8Limited4Runner is offline
03V8Limited4Runner is on a distinguished road
I am new to the page and suck at tech, so I need to ask for HELP.
I have a 2003 4Runner V8 Limited and I freaking LOVE IT. I got it used 2 years ago (230 000kms) and it's been freaking awesome! BUT!! The emergency brake shoes seized up and I couldn't get the truck to move (had the e-brake on while parked on a hilly part of the driveway for a few weeks, seriously, that's it). My dad has rebuilt engines and does everything for all of our family cars (except bodywork), and he has been LOSING IT on this ridiculous e-brake system... So, we replaced the shoes (pads were literally STUCK in the rotors) so we replaced those, then all 3 cables, and now the rotors... And we have had the wheels on and off more than I can say, (and the shoes on and off trying to troubleshoot) and we've tightened EVERYTHING sooo many times.... We have adjusted the shit out of these up and down, at the star on the e-brakes, under the console, and at the pedal. We can't get the balance where the wheels will spin in neutral, but the e-brakes will stop the car when in motion. And before I changed the rotors today, (but had done everything else), we removed the old rotors (for the 40th time) and the e-brake had obviously been catching somewhat, because the new e-brake pads had created a shit-ton of dust all in them and look scratched, but still wouldn't stop the wheel when in motion. So new rotors, re-adjusting, and the truck still rolls when the e-brake is on. I think it's making him crazy, and I've been there for a while. If you have any ideas on how to set this thing, I'd love to try them. THANK YOU!! 🙂
03V8Limited4Runner is offline   Reply With QuoteReply With Quote
Old 12-03-2019, 01:03 AM #23
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
You’re posting in the wrong forum. Your 2003 is 4th gen T4R. You’ll have better luck there.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 09-30-2022, 05:46 PM #24
LOCOBEAR LOCOBEAR is offline
LOCOBEAR is on a distinguished road
Been a hell of a year.
Recently 8/4/22 had the rear emergency brake shoes replaced since during rear brake disc pad/rotor replacement they told me the springs "just broke", great almost $900 to replace the drum shoes and springs. Since he told me just don't use the emergency brake but you will hear a metal scraping noise until you repair it after job was done, it's safe to drive it. So after getting used to Not setting it I forgot to release it one day and drove not even a 1/4 mile feeling like I was going over a hump with every rotation of the tires, when I got to where I was going I could finally smell the burnt pads and realized I forgot to release the emergency parking brake. After swearing at myself since this was the day I got those repaired I could only hope it was fine. Today 9/30/22 I went to set the brake and it offered little resistance then went all the way to the floor and am hearing the same metal scraping sound not as bad, plus it's not holding the vehicle back without it going forward a bit. I'm hoping I haven't got myself another broken spring to replace and don't know if youtube videos saying they're self adjusting are the thing to do, don't want to make it worse. Find it hard to believe that's all it takes to break a spring. Is it possible they need cable adjustment?
Well, here's some thoughts. People don't use their e-brake. I see time and time again people allowing the parking pawl on their automatic transmission take the brunt of holding the vehicle instead of applying their parking brake to hold the vehicle. People with manual transmissions just put it in gear and let the gears hold the vehicle and also don't apply the e-brake. So, if you don't use your parking brake, your brakes will slowly go out of adjustment.
Another reason is things get corroded like the bellcranks. If they aren't actuating properly, they won't be pulling the cable enough to pull the parking brake lever which ultimately turns the self adjuster if the wheel can turn one or more clicks due to out of adjustment shoes.
All anyone needs to do is pull their parking brake lever over and over again and ultimately it won't adjust any tighter. The FSM says 7-9 clicks from the handle is what you should have if your rear brakes are adjusted properly. If you can get way more clicks than 7-9 and no amount of pulling the lever changes anything, something in the system is bound up and not working right.
LOCOBEAR is offline   Reply With QuoteReply With Quote
adjusted , adjusters , brake , brakes , rear
rear brake adjustment bigtimeweb 3rd gen T4Rs 15 11-17-2022 12:51 AM
Rear Brake Adjustment JRZEE2000TR4LTD 3rd gen T4Rs 0 05-31-2016 01:36 PM
Rear brake adjustment issues WallyWest 3rd gen T4Rs 5 05-12-2016 10:34 AM
3rd gen rear brake adjustment. Avwizz 3rd gen T4Rs 4 03-23-2015 11:49 AM
e-brake adjustment gonzo Maintenance/Detailing 14 07-20-2006 09:46 AM
