Old 03-29-2019, 02:48 PM #1
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Rocker rust directly under front seatbelt tensioners
I have no idea where the water is coming from to do this. You can see the sponge that is under the passenger seatbelt tensioner. From the inside is looks fine just dirty. It's not coming from the sunroof or the washer fluid hose. The rest of the rocker panel is fine.
Maybe from the front of the running board mount where the undercoating has cracked??
The driver side has it too but not rusted through yet, and it's further forward on the rocker panel.
Driver side:
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 03-29-2019, 03:39 PM #2
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Rockers rot from the inside out on just about any vehicle, doesn't matter if you have a sunroof. Rockers hold water and condensation, there are drain holes in the pinch welds on the bottom of 3rd gen rockers, they clog, but doesn't matter regardless, you gotta spray some type of RP up in there, I use WD-40. Looks like your rocker pinch welds are taking a beating and not getting rust prevention. SEASONAL RUST PROOFING using WD-40 only
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 03-29-2019, 08:18 PM #3
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
That's an unusual spot for it to go i think. They usually eat through nearer the rear wheels where the water and crap lies and the paint gets damaged.
I wonder if there was some sort of damage to that point in the past that took off the paint and primer and started the rust process... Maybe it too is a spot where stuff gets trapped inside but I have not seen one rust there.
Actually, looking at photo 1 and 2 it totally looks like that spot has been sandblasted. There is damage to the paint and primer beyond the rust hole. And that running board bracket has a ripped hole, did your 4runner sustain some damage in that area?
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 03-29-2019, 09:04 PM #4
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
Might be sunroof, but I think it's just a bad weld or bad seam sealing. That's a really unusual place for the rocker to rust out, it's usually at the ends.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 03-29-2019, 09:47 PM #5
Not in the 13 years I've owned it but while I've been poking around I noticed the rear passenger door on that side doesnt have any Toyota stickers on it like the others do. And the only other body rust is around the driver side cargo area. The left cargo window has been replaced and on the underside below the left bumper there's places with a black coating/paint where white paint should be, and the pinch welds are all bent up.
99 SR5 v6 4WD
11 SR5 v6 4WD
Old 03-29-2019, 09:50 PM #6
Do you know if there's supposed to be one of those little bent out drain holes in that area like the rest of the panel? Because I can't see the remains of one it's just rust.
99 SR5 v6 4WD
11 SR5 v6 4WD
driver , mount , panel , rocker , side
Running Board Removal w/o Front Mud Flaps and Rocker Panel Corrosion/Rust 07V8 4th Gen T4Rs 8 09-29-2018 04:46 PM
Help me decide what to do about my rust rocker panels on a budget! (pics included) nalbertasr5 3rd gen T4Rs 14 05-04-2016 09:15 AM
WTB: 4th Gen passenger front seatbelt Powpowser Want to Buy/Trade 0 06-10-2015 11:14 PM
Midwest Rocker Panel Rust Tommy Argh 3rd gen T4Rs 1 08-20-2014 10:59 PM
