Old 04-08-2019, 01:17 PM #31
quatin quatin is offline
quatin is on a distinguished road
Originally Posted by 19963.4lsr5 View Post
There is a special procedure to adjust the ebrake bell cranks which effect the brake shoe adjustment.
Do you happen to know where to find that info? I've been googling all around and can't find the specific procedure. There's a nut inside the parking brake lever, plus there's a bell crank on the outside of each drum.
quatin is offline   Reply With QuoteReply With Quote
Old 04-08-2019, 01:38 PM #32
96RedRunner is a jewel in the rough 96RedRunner is a jewel in the rough 96RedRunner is a jewel in the rough
Page BR25 of FSM
Old 04-08-2019, 11:09 PM #33
Originally Posted by Nate_GB View Post
The parking brake and the hydraulic braking system are completely separate systems all the way up to the point of the actual brake shoe engagement inside the drums. So the fact that you say that parking brake use effects the situation leads me to believe that the brake shoes inside the drum are not installed correctly. There's lots of adjusters and springs and small parts that have to be in the correct place to function properly. I'd be willing to make a heavy bet that's where your problems lie. I'd start by removing your drums and comparing what your setup looks like to a known correct setup photo.
Post a photo of each side with the brake drum off and we should quickly be able to tell you if something is way off.
Adjusted the bellcranks tonight so I took some pictures. I didn't see anything out of place, but could use another set of eyes. I also notice my new shoes has some funny wear marks after 30 miles of driving already. I can now feel some light grooves in the drum that I'm not sure were there before. Guess I have to go get new drums or have them turned.
What is this thing? [SOLVED - Load Sensing Proportioning Valve]-driverdrum1-jpg  What is this thing? [SOLVED - Load Sensing Proportioning Valve]-driverdrum2-jpg  What is this thing? [SOLVED - Load Sensing Proportioning Valve]-driverdrum3-jpg  What is this thing? [SOLVED - Load Sensing Proportioning Valve]-passdrum1-jpg  What is this thing? [SOLVED - Load Sensing Proportioning Valve]-passdrum2-jpg  What is this thing? [SOLVED - Load Sensing Proportioning Valve]-passdrum3-jpg  What is this thing? [SOLVED - Load Sensing Proportioning Valve]-shoemarks-jpg
Old 04-09-2019, 10:45 PM #34
Nate_GB's Avatar
Nate_GB Nate_GB is offline
Nate_GB is on a distinguished road
Nate_GB's Avatar
Are those grooves worn in the new brake shoes or just streaks? The hardware looks to be set up properly from what I can see. The way I usually adjust the rear brakes is to turn the adjuster with a flat head screwdriver through the backing plate until there is just the slightest amount of drag on the drums. Assuming the brakes are setup properly, are you getting good fluid flow through the bleeder valves while bleeding?
Nate_GB is offline   Reply With QuoteReply With Quote
Old 04-09-2019, 11:58 PM #35
Those are streaks. I do the same thing on adjusting the drums, then I pump the hand brake until I don't hear the automatic adjuster clicking. I did get decent fluid flow eventually when I bled the drums. I have a brake bleeder hand pump, but we had to try the pump the brake pedal method a few times to get things going. (again a sign of a tripped valve?) I did notice the LSPV bled much easier than the wheels. I feel like the calipers bled easier than the drums too.
Old 04-14-2019, 01:01 PM #36
Update:
Replaced drums: No effect
I pulled the LSPV valve off and it appears the piston (red rod thing) is seized. I would assume some type of spring like response from it, since it is connected to a lever with the load spring. There's about 1/8''-1/4'' of play on the piston, but you need to press/pull hard. Once it's in, it stays in, once it's out it stays out. There's also a bypass valve that somehow rides ontop of this piston, so perhaps that part is seized too? Seems like I need to replace it regardless, so hopefully this is my problem.
What is this thing? [SOLVED - Load Sensing Proportioning Valve]-20190414_123039-jpg
Old 04-21-2019, 10:22 PM #37
Final update. Replaced LSPV and problem resolved. I'm still unsure how the system works, because even with a new valve, the lever is in a permanent up state, so I don't understand how it's supposed to adjust load, when a loaded chassis will make the lever go up even more?
Anyhow, for anyone replace theirs, remove the spare tire first or you can't see the brake line coming from the MC. I cross threaded the fitting for that brake line working blind. I had to chase it down with a die cutter. Turned a 20 minute job into a 2 day job.
Old 10-10-2019, 01:16 PM #38
cejaslocas cejaslocas is offline
cejaslocas is on a distinguished road
Quatin,
I know this thread is a few months old. I was wondering if you could provide the part number for the LSPV you replaced. My 2000 4Runner is having the same problem. But looking online, my LSPV looks different than the others I see out there. Yours is the only one that looks like the one I need. Hope you remember. Thanks in advance!!
cejaslocas is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 11:46 AM #39
Rsina89 Rsina89 is offline
Rsina89 is on a distinguished road
Rear Brake Proportioning Valve
reviving an older thread. I have a 1999 Toyota 4runner 2wd base model with the Rear Brake Proportioning Valve . my 4runner is lifted 2.5 inches and ive read that lifting a base model will cose the brake light to turn on and off. is there a way to fix this besides from pulling the light fuse? just kinda of annoying to see the light pop on and off lol.
also anyone tried the Revtek Rear Brake Proportioning Valve Relocate Kit for 1996-2004 Toyota Tacoma to fix this problem?
Rsina89 is offline   Reply With QuoteReply With Quote
Old 02-28-2021, 03:40 PM #40
Originally Posted by cejaslocas View Post
Quatin,
Sorry for such a late response. For future reference:
47900-35493 Pressure Metering Valve
$260 part and no aftermarket that I could find since it's rarely installed. I was able to revive the old valve by playing with the piston, so I kept it as a back up just in case.
Old 02-28-2021, 03:42 PM #41
I believe you add an extension arm to the existing lever arm. You probably have to make it yourself and play with the length until the lever is fully down unloaded.
Old 04-09-2021, 12:44 AM #42
2wdguy 2wdguy is offline
Real Name: Ray
2wdguy is on a distinguished road
Real Name: Ray
Can you Provide Detail on on how you revived Old Valve? I think i am in the same boat you were in. Can this be done while attached to the vehicle?
2wdguy is offline   Reply With QuoteReply With Quote
4runner , attached , brake , screw , thing
ABS / Proportioning valve Question SIN-Japan 3rd gen T4Rs 7 06-22-2017 08:16 AM
"Play" in throttle body valve thing. poser 3rd gen T4Rs 2 10-09-2014 03:05 PM
Load Sensing Proportioning and Bypass Valve So Many Roads 3rd gen T4Rs 1 03-09-2012 08:27 PM
Dynamic Rear Proportioning (aka EBD) Thai 4th Gen T4Rs 1 06-20-2011 09:24 PM
wtb: Load sensing and brake protioning valve jimbojones75 Want to Buy/Trade 0 07-20-2005 05:57 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
