12-12-2019, 10:25 PM
#91
Originally Posted by rickashay
No I did not. I'd love to get down to even 2.5" rear lift with all the weight/rear bumper and still be able to have the benefits of all that free height. The 675V is that a 4th gen Dobinsons spring? I wonder if we got a bunch of people together if
@ Crikeymike
could make a progressive coil designed for these types of applications. Considering the amount of people running Land Cruiser coils on their 4Runners, it seems like there could be a business case for a 4Runner/Surf specific coil that achieves what we want?!
The 675V is a 4th gen superflex coil. I know
@ Black798
is running the 210V from Dobs and they are the stock height LC coil. He said he was lower than the 861's by about .5" if I recall correctly. I'd have to sort through my IG dm's to find it.
The specs I have found are:
861's - 220lbs - 480/490 fh
210V - 160-239lbs - 475/485 fh
675V - 157-230lbs - 470-470 fh
Superflex - 210lbs - 495 fh
LC oem - 160lbs - fh varies
The 675V would be .2" lower than the 210V's, so that is headed in the right direction.
I think I read somewhere that
@ Crikeymike
could do a run if 20 were involved. My requests would be a long travel coil, max of 3.0" lift height, and designed for maybe an extra 100lbs of weight over stock. I personally no longer have the mindset of "I have to have a big lift to go over things" as plenty are proving that 1-2" of lift and 35's is enough and fun.
02 Sport
Toytec Boss/LJ - TRD Pro & 255's - TBU - 4:30's - Elocker
4xI - AED - Savage
12-14-2019, 03:38 PM
#92
Real Name: Addison
Real Name: Addison
@ Black798
@ Crikeymike
Great info, thanks for sharing. I actually ran the 675V on my 4th gen and was just double checking we were talking about the same thing. They rode great (on the 4th gen) and I was super happy with them. Funny, as I was thinking about trying them on my 3rd gen. I didn't know anyone else was running 4th gen coils on their 3rd gen. I might just have to be the guinee pig as I am totally in the same mindset - lower is better!
12-14-2019, 03:40 PM
#93
Real Name: Addison
Real Name: Addison
Colossal 2019 after-movie. Had a blast as always! Excited for the route we are already planning for next year!
12-14-2019, 10:27 PM
#94
Mike with Dobinson's is out of the country, so I sent an email to Dobinson's sales asking if it were possible to add another option to our platform if we had a minimum amount of orders.
Also since you are running 8 wraps, I would what the difference would be from those and the 675V's?
02 Sport
4xI - AED - Savage
12-15-2019, 12:44 AM
#95
Real Name: Addison
Real Name: Addison
Awesome. I'm down to help rally the troops up if something like this makes sense. Thanks for getting the ball rolling.
I am running 7 or 7.5 wraps. I wish I measured free height before I through them in but I did not. Whatever they are, I want them to be lower and I actually think that they are too soft. After having the progressive coils in the 4th gen (the 675V and Metal Tech LT springs before those) it makes you kind of spoiled having dual rate springs. I think it just makes sense to have them slightly firmer in the rear as they compress - helps with bodyroll in the corners and also allows them to stretch way out for those droopy situations.
12-15-2019, 10:36 PM
#96
This is what I emailed to them:
"Hello,
I'm wondering if its possible to request a coil spring with certain specs if I can get x amount of orders for them?
I have a 2002 4runner, and I know a lot of us are desiring a smaller lift than whats available but a longer coil so that it doesn't fall out during large articulation.
Something with 55-60mm lift in a variable or progressive rate and long travel. Some of us do have a steel bumper with swingout or carry some extra weight in the cargo area, so they would maybe need to be a medium load spring for some. Not sure if its possible to offer a standard load and medium load easily without changing the specs a lot...that is your level of expertise.
If this is possible to do please let me know and any details you can share.
Thank you,"
I wouldn't mind seeing the 675V about a .5" shorter for us
02 Sport
4xI - AED - Savage
12-16-2019, 02:49 PM
#97
4th gen / 5th gen / FJ rear OEM springs lift 3rd gens around 1" - so start there for your assumptions about fitting aftermarket rear springs.
The upper and lower coil diameters are also slightly bigger on the later gen springs, but fit well enough.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
01-10-2020, 12:56 PM
#98
Forgive me if I missed it, but where did you come by the projector headlamp replacements? I'm a newbie to the group, just acquired a '99 T4R, boring old 2WD 4cyl. as my new daily. My headlamps work so-so, but there is peeling of some film just behind the glass and the reflector portion is a bit hazy on both. Thought about hitting the boneyards to see what I could find, but I like the way projectors focus the beam more tightly...nice look for the vehicle too.
01-12-2020, 08:03 PM
#99
Real Name: Jeff
Real Name: Jeff
He builds them himself. He used to sell them, but not anymore. There a lot of good threads on projector retrofits.
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
01-13-2020, 10:16 AM
#100
Real Name: Patrick
Real Name: Patrick
96-02 4runner HID Retrofits | SRQ Fabrications if you don't want to build them yourself.
05-07-2020, 02:12 PM
#101
Real Name: Addison
Real Name: Addison
Yup, he nailed it. Sorry for the slow response... I am building lights again on a smaller scale. If you are Canadian especially, fire me a PM.
05-07-2020, 02:21 PM
#102
Real Name: Addison
Real Name: Addison
Not too many updates on the truck. Drove it all winter as a daily and that's about it.
Now that spring is here, I have a few projects on the go:
- make some adjustments to my sleeping platform and re-stain it. I decided to add a drawer on the low side that will hold my Cook Partner stove. The constant pursuit of making camp setup simpler.
- building my Eimkeith rear bumper. It's fairly complicated and I must maintain priority of rust proofing all the new steel and brackets so that seems to have made the process take longer than expected. I am about a week from actually starting to weld things together though
- Install my sPOD and winch and get the wiring all sorted.
In the meantime, here is a couple poser shots from the last few days:
_08I8079.jpg by Addison Rickaby, on Flickr
_08I8095.jpg by Addison Rickaby, on Flickr
05-07-2020, 03:50 PM
#103
Whoa, that clear rear wind deflector is trippy.
05-07-2020, 04:01 PM
#104
Lookin good. What skid plate is that?
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
05-07-2020, 04:02 PM
#105
I didn't even notice that invisible wind deflector. I see it now.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
