Old 04-05-2019, 01:34 PM #31
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Originally Posted by natedogg11c View Post
glad i could help someone with my frustrating situation. as far as climbing what do you mean? i climb a ladder occasionally but rock climbing is a negative. 11c is my MOS (Indirect Fire Infantryman) and it tends to make its way into my usernames lol
Got it, lol! That's a rock climbing grade which would make you a pretty hardcore climber is why I ask. BTW, thank you for your service sir
weekendclimber is offline   Reply With QuoteReply With Quote
Old 04-05-2019, 07:13 PM #32
SpenO SpenO is offline
SpenO is on a distinguished road
I had the same issue on my 96. Went through 3 starters trying to figure it out and would still just get one single click. It turned out to be a bad engine ground. When I pulled the engine ground off it didnt look dirty at all but I roughed it up with some scotch bright just to be sure and the thing fired right up. Havent had an issue since. I know you said you looked at your grounds but try scrubbing them up with scotch bright to see if it helps!
SpenO is offline   Reply With QuoteReply With Quote
Old 04-05-2019, 07:40 PM #33
Real Name: Scott
Real Name: Scott
Definitely will try that! Thanks for the tip
Old 04-06-2019, 12:29 AM #34
Real Name: Scott
Real Name: Scott
BOOYAH KASHAW!!!!!
Connected the jumper cables from the battery to the starter rerouting both the ground and the positive and it fired up like it wasn't even a thing. Totally appreciate all the help and the advice for things to check. Now I get to put it all back together this weekend. On the plus side, I've got an extra starter too:-/
Old 04-06-2019, 10:41 AM #35
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
Originally Posted by weekendclimber View Post
BOOYAH KASHAW!!!!!
So, what did you fix? Sounds like you verified it was either the battery to the starter connection or a ground from the starter to engine block to the chassis?
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 04-06-2019, 11:42 AM #36
Real Name: Scott
Real Name: Scott
So I went back to verify whether it was the battery to starter wire, or a bad ground.
First, I removed the jumper cable positive connection from the battery to the starter solenoid terminal. I left it for the negative battery terminal to the case of the starter to see if it was a bad ground connection. Tried to turn it over and only got the click again.
Reconnected the positive battery terminal to the starter solenoid terminal with the jumper cables and removed the other "ground test" cables. Tried to turn it over again and it fired right up.
So, it appears it was the battery to solenoid terminal connection all along. Going to go through it all today and check everything along that wire. I did the Big 3 upgrade a while back, as previously mentioned, so it could be just simply the terminal connection or maybe the wire is going bad.
I'll update the thread once I know specifically what it was.
Last edited by weekendclimber; 04-06-2019 at 11:43 AM. Reason: On mobile, so urumph
battery , click , contacts , motor , starter
Help! Overheating issues after new head gasket, can't figure it out 4runner15 3rd gen T4Rs 28 10-31-2023 12:06 AM
Starter Issues 4x4 Hoonigan 3rd gen T4Rs 3 01-08-2014 03:21 AM
STARTER ISSUES! Plz help Tbar94 Classic T4Rs 9 10-25-2011 04:39 PM
Starter Issues buzzie0013 Classic T4Rs 4 08-01-2011 04:20 PM
help me please I have a starter problem I can't figure out Cole McGinnis Classic T4Rs 4 05-04-2010 09:36 PM
