Old 04-02-2019, 01:09 PM #1
dsms4ever dsms4ever is offline
dsms4ever is on a distinguished road
Need advice on high mileage 3rd gen/build thread
Quick background here:
2000 limited 4runner with e-locker
223k purchased excellent condition $6500
Maintenance performed as preventative maintenance and some repair:
Full timing belt kit and water pump
New radiator
Toyota lower ball joints
Inner and outer tie rod ends
Ngk plugs and wires
New crossover exhaust gaskets
Valve cover gaskets and intake gaskets
Denso o2 sensors
Toyota tps
Cleaned mas
Seafoamed engine
Fuel filter
New 4 hole Denso fuel injectors
Power steering fluid flush, rack bushings, guide updated
Changed all gear box fluids to synthetic
New braided with sleeves brake lines
Rebuilt rear brakes, adjusted e brake
Replaced cv axle
New black carpet kit
Black digital fit weather techs
New battery
Rebuilt starter with new brushes/contacts
Upgrades:
Bilstein 6112 4runner front struts/springs
Tundra big brake upgrade from power stop with drilled/slotted rotors
Bilstein 5100 with ome springs in rear
Extended rear bump stops
Eimhart panhard drop/lower kit
E-brake bracket made for lift
Extended rear brake line
Front diff drop kit
1” wheel spacers
Mstudt extended heavy duty sway bar end links
Sway bar bushings energy suspension
2017 4runner wheels
255/75/17 duratracs sl 4 ply tires
Morimoto d2s projectors with 5k Morimoto hid’s
Satoshi grille mod
Pioneer car-play touch screen
Alpine rear flip down tv for kid movies
Pioneer 6.5” 2 ways front and rear
Rx8 leather front seats
Full color conversion to satin black interior with light gray upper half
Led bulbs in hvac and gauge cluster
In process of doing leather dye from Leatherique on all seats to black
Gray seatbelts swapped in.
Diff lock light up mod
Clock mod so green matches green led in digital hvac
Super clean, almost dent free, only a door ding here and there gets 16mpg city and 18 hwy, currently sits at 253k miles and I daily drive it 25 miles 4 days a week to work. Burns zero oil.
Here is what I need advice about: I hate how underpowered it is when I have my family of 5 in it and it’s loaded with camping gear trying to get over the mountain pass! My foot is basically floored to keep up with traffic doing 55moh/60mph, Toyota geared these horribly. It’s fine when your at say 3500rpm but then it upshifts and you lose all your power.
3 options to vote on please
Sell it and buy a v8 4th gen and start build over (I have no money left over to upgrade it cause of how much I invested in this one)
I found a 75k 2000 4runner with magnason supercharger installed for sale that was wrecked that I could buy just not sure how cheap I could get it for or how much that is worth and swap everything low mileage over with supercharger.
V8 swap mine with tundra/sequioa after mine blows up but then everything would be high mileage.
I want to put 285/70/17 ridge grapplers in it, savage off-road hybrid bumper/sliders, rear tire swing out, prinsu roof rack in the future which is going to add weight and all that will cost like 5-6k so keep that in mind when voting on option. Plan to overland some day with 2-3 people.
My boy is 12 and in 4 years I’d like to have the rig be his depending on a lot of benchmarks he would have to maintain...
I’m already upside down in value but am at a cross roads, do I dump another 8k into it over next 4 years to make it last many years to come, or cut my loses and buy something with lower mileage and newer with a v8 in it.
dsms4ever is offline   Reply With QuoteReply With Quote
Old 04-02-2019, 01:37 PM #2
Since this is worthless without photos....
Dsms4ever2's Library | Photobucket
Old 04-02-2019, 01:43 PM #3
toastyjosh toastyjosh is offline
toastyjosh is on a distinguished road
I would vote for the supercharger and exhaust, this will be the easiest option.
I would also look at regearing to 4.88s, a lot of the power suck is the auto trans.
Good luck
toastyjosh is offline   Reply With QuoteReply With Quote
Old 04-02-2019, 02:17 PM #4
cblock406's Avatar
cblock406 cblock406 is offline
Real Name: Christian
cblock406 is a jewel in the rough cblock406 is a jewel in the rough cblock406 is a jewel in the rough
cblock406's Avatar
My vote is keep and supercharge as well. Great looking rig, would love to learn more about your interior makeover.
Build Thread: http://www.toyota-4runner.org/3rd-ge...ce-thread.html
@projects_always
cblock406 is offline   Reply With QuoteReply With Quote
Old 04-02-2019, 02:36 PM #5
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of
Real Name: Jerod
Can anyone guess what my advice is?
You've put so much into the one you have, it would be a crying shame to let it all go. V8 swaps are few and far between, you'd have to do a lot of wiring and welding and may not play nice with your suspension setup due to clearances and the like. Supercharge it.
326WHP 347TQ
Old 04-02-2019, 02:55 PM #6
turbo8's Avatar
turbo8 turbo8 is offline
turbo8 will become famous soon enough
turbo8's Avatar
Putting larger\heavier tires on will make it slower. Regear and supercharge.
Also, your 4runner isn't high mileage.
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
turbo8 is offline   Reply With QuoteReply With Quote
Old 04-02-2019, 08:31 PM #7
Mzs14 Mzs14 is offline
Mzs14 is on a distinguished road
I'm in a similar situation and my supercharger is on the bench about to go in on my truck with 226,000 miles.
Mzs14 is offline   Reply With QuoteReply With Quote
Old 04-03-2019, 11:37 AM #8
zoombyu86 zoombyu86 is offline
zoombyu86 is on a distinguished road
I vote you keep it and make a freaking build thread so we can see all of your mods! I would love to see that interior makeover, including the RX8 seats.
zoombyu86 is offline   Reply With QuoteReply With Quote
Old 04-03-2019, 03:56 PM #9
Is the photobucket link not working? I need to order the photos as they are all over the place. Rx8 seats are very comfy, and the swap was easy. Just go to a junk yard and steal the factory seat floor brackets off some tore up ones and weld and grade 10 bolt them onto a piece of 1x2 steel tube attached to the Mazda seat brackets. The Mazda seat feet unbolt and then I just cut off the studs on the Mazda seat rails to make it mate with the 1x2 tube. Dimensionally they fit great in a 3rd gen. I am 6’ and have a couple inches of head room. If you are taller I would use flat bar and not a 1x2.
Old 04-03-2019, 04:01 PM #10
Smog-guy707's Avatar
Smog-guy707 Smog-guy707 is offline
Smog-guy707 has a spectacular aura about Smog-guy707 has a spectacular aura about Smog-guy707 has a spectacular aura about
I just supercharged mine. I felt no power loss once I added the 33s
It feels great.
My next 4Runner will have a v8, only because of I have always had v6 and I am ready for more power when towing. But I am happy with this one right now
I say keep it supercharge or turbo
Loading....
Smog-guy707 is offline   Reply With QuoteReply With Quote
Old 04-03-2019, 04:29 PM #11
luke481 luke481 is offline
Real Name: Luke Hinson
luke481 is on a distinguished road
Exclamation I need help
I don’t know that much about 4Runners. So I just made an account here. I was wondering if you could swap the engine from a 1997 forerunner that is rear wheel to 4Wheel drive 2001 4runner. I don’t know if it is worth my time to fix the 4 wheel drive 4Runner. But I need to fix it really bad because I need a way to get to College. Any help would be greatly appreciated !!
luke481 is offline   Reply With QuoteReply With Quote
Old 04-03-2019, 04:44 PM #12
As long as it’s the 6 cyl. It’s the same engine and will swap over.
Old 04-03-2019, 07:17 PM #13
Would there be a difference in oil pan or transmission?
Old 04-03-2019, 10:26 PM #14
The 4wd transmission is different than the 2wd transmission. Not sure about oil pan but being a v6 I don’t know why it would be. It’s always smarter to do a like to like swap if you aren’t sure. Go to car-part.com and search for engine for your vehicle and see what comes up.
Old 04-03-2019, 10:58 PM #15
Thank you. I will let you know how it goes.
black , brake , front , kit , rear
advice on high mileage purchase mschlee 3rd gen T4Rs 13 05-05-2016 08:51 PM
To buy low mileage or high mileage, that is the question DDeezenuts 3rd gen T4Rs 21 01-08-2016 03:22 PM
96 4Runner Build - High Mileage Downeys4Runner 3rd gen T4Rs 33 07-09-2013 06:41 PM
Mile high 4runner build thread mile high 4runner 3rd gen T4Rs 19 06-11-2013 07:41 AM
Need advice on 4runner purchase with high mileage GirlTruck4me 3rd gen T4Rs 11 01-26-2012 03:07 AM
