Old 02-14-2023, 03:22 PM #31
Originally Posted by JoeT4R View Post
I'm interested to hear how your friend was able to tackle it from the wheel well. Especially with the exhaust pipe right there! Lol. If only my truck was a Cali rig, I'd just unbolt the exhaust and go full send on it.
Its right there. I don't remember having much problem with the starter through the wheel well.
Exhaust in CA is still not guaranteed - I broke a stud on the downpipe thinking it would be easy...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-14-2023, 03:42 PM #32
Rebuild Alternator (W/ Pics)
I used a bunch of 1/2” extensions that reached past/through the crossmember
And a swivel socket or a ball universal and a 1/2” impact or breaker bar for the starter bolts. Every stinking 4Runner those bolts were nasty tight
Edit: that top bolt looks mangled. Good luck getting a good bite on it with a socket unless you can hammer a slightly undersized one onto it.
Old 02-14-2023, 04:28 PM #33
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
How I get thst bolt is 6 point sockets with a lot of extensions out past the crossmember like the other member suggested. Once loose you mostly can take it out with a hand wrench...
Old 02-14-2023, 04:36 PM #34
Texmax's Avatar
Texmax Texmax is offline
Texmax is on a distinguished road
Texmax's Avatar
Great write-up.
Me, I'd opt for the lazy man go to auto parts store and get one.
99 4wd limited w/ E/locker
3" RC lift-loaded struts. Sonoran Drop diff and adjustable rear Panhard.
JBA Offroad UCA's, Pro comp Raven 16x8 wheels wrapped in 265/75/16 Gladiator Mt ,APOC INDUSTRIES Rear Trailing arms.
RETIRED USCG Aviation Mechanic/Hc130h Flight Engineer/HH65-A Flight Mech.
SEMPER PARATUS
Texmax is offline   Reply With QuoteReply With Quote
Old 02-15-2023, 11:27 AM #35
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Originally Posted by Texmax View Post
Great write-up.
Agree Rebuild Alternator (W/ Pics), the OP did a fantastic job, however I'm with you, if the bearings on the alternator were bad I would replace the entire alternator.
That being said, swapping the brush holder literally took 5 minutes and at $20 cost for the Toyota oem part, I would go this route over a parts store alternator any day.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
alternator , nuts , phillips , remove , work
5th Gen Alternator Rebuild kit? (for DIY) nglayton 5th gen T4Rs 2 08-05-2017 01:19 PM
Free 97 Alternator (needs rebuild) JBurt Free 0 06-30-2017 07:54 PM
How do you rebuild an alternator?? 4Runner_101 3rd gen T4Rs 2 06-14-2014 03:28 PM
Alternator rebuild kit? Desert36 3rd gen T4Rs 0 06-20-2013 10:57 PM
a/c rebuild (for the a/c experts :) +pics Tom2000tr4 3rd gen T4Rs 1 01-09-2008 02:10 AM
