Originally Posted by msh03046
Thanks for the feedback turbodudey2! When I see these discrepancies in the specs I know that some are just straight up typos, but I wonder if there were changes made over the model years (especially with all the changes that were inner generation), and the FSM has them all mixed together.
Thanks for sharing this. This is not the first time a discrepancy like this have been found in the FSM. In my 2000 FSM, the same part diagram you showed has the torque value as 151 ft-lbs. Then, in the step by step pages of putting the steering rack on the vehicle, it specifies the spec as 141 ft-lbs and that's the spec we share in the video for that nut. With the other bolts at 123 ft-lbs, it's not a stretch to believe that big nut has a spec of 141 ft-lbs. Actually, 96 ft-lbs seems a little light for that size of a fastener.
With that said, I did experience what you mentioned with the torque value not being achieved when I was helping a friend with this job. I had done the job on two other rigs and was able to hit the 141 ft-lb spec no problem. But, on this occasion it kept going and I started wondering if my torque wrench was off so I stopped cranking on it.
